Coachbuilder Shackles Etc...
Discussion in 'Ekstrom Design' started by TruckyTruck, Jul 23, 2014.
  1. Mar 21, 2018 at 6:01 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    With the TRD PRO suspension there is no "lift" in the rear. And to fit the tire/wheel combo I needed to bump the front up an additional inch for a total of 3" up front. From past lifted trucks, it has been my experience to never "block lift" the rear whenever you can. I called David @ Ekstrom designs and talked about my truck. He had the perfect solution for the Pro suspension... Single spacer up front and the BEEFIEST rear +3 shackles that yeilded 1.675" rear lift. Plenty of height, with undoubtedly enough strength for towing. Also, I'm utilizing his carrier bearing drop to correct the drivshaft angle, and his steering kit to overcome the increased tie-rod angles up front. When i tow, everything sits level, and braking is not compromised from hitch sag. The only other option for a rear lift while maintaining control would be a new spring pack (AAL or Icon), but I felt this was unnecessary after seeing these shackles, and I didn't need any extra height. This machine is lighter than your toyhauler, but I also have a 7500# mini excavator, and with trailer, that puts me at near full capacity without any issue. I do not tow far distances however, so I cannot speak for the Long haul. This set up suits me perfectly, and I retain the smooth ride wether or not I'm towing. Packs tend to stiffen up the unloaded ride too much for my liking.
  2. Mar 21, 2018 at 4:53 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Does this mean that the shackle you replaced with the exact same length as the Coachbuilder?
    Based on the loaded photos it looks like you got some lift out of the rear, no?
    Coachbuilder1 likes this.
  3. Mar 21, 2018 at 6:29 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    As I said above...
    "The +3 shackles yeilded 1.675" of rear lift".
    That's the point of putting them on... To level up with the TRD PRO front. These things are monsterous!
  4. Mar 22, 2018 at 4:58 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    This was what confused me.
  5. Mar 23, 2018 at 7:06 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
  6. Mar 23, 2018 at 7:42 PM
    408Tundra
    408Tundra New Member
    Will
    2017 Tundra TRD Limited Crewmax 4x4
    Thanks. I'm redoing mine
    Toyotoholic likes this.
  7. Jun 12, 2019 at 6:44 AM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
    Hi how much does that skid steer weight with trailer do you know how much squat do you get whit this or with that 7500 mini machine
    Toyotoholic[QUOTED] likes this.
  8. Jun 12, 2019 at 8:46 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    The whole trailer and machine is about 7500# with the mini skid steer(5500#) It is not alot of squat but depends on how you load the machine. You can balance a smaller machines over the trailer wheels to minimize the tongue squat. The bigger machines are a different story. When I tow my 7500# excavator, I get quite a bit more squat but still no issue towing, even though I'm pretty much maxed at 9500# for gross
  9. Jun 12, 2019 at 10:26 AM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
  10. Jun 12, 2019 at 10:31 AM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
    Thx for the reply so I guees it does work pretty well I don’t want to add anything up front so it would probbly be even better because I would have more rake I was thinking about road master active suspension or this i front know which way to go because I don’t want to stiffen the suspension does any one have rodmaster active suspension on their Ted pro ?
  11. Jun 12, 2019 at 1:00 PM
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    I just bought a set of +1s and I'll be installing rtx icon springs with them. So I guess I'll put my +3s up for sale when I get that done.
  12. Jun 12, 2019 at 2:29 PM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
    This is how my look with around 8500 lbs
    HatOwner likes this.
  13. Jun 12, 2019 at 2:31 PM
    Dareckii
    Dareckii New Member
    2015 tundra trd pro
    I don’t have the picture of it but even this empty trailer make my truck go down like 2 inches which weight 2500 lb
  14. Feb 28, 2020 at 2:01 PM
    chrisvuc
    chrisvuc New Member
    2019 TRDPRO
    can you please give me the tire and wheel specs on this truck?!? Love the set-up!
  15. Feb 28, 2020 at 4:40 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Thanks!
    Mickey Thompson wheels and tires.
    275/65/20 Baja ATZP3
    MM 489. 20x9 +18 offset
    I love them but the wheels are very NOT fun to clean... Lol.
    chrisvuc[QUOTED] likes this.
  16. Mar 4, 2020 at 5:47 PM
    Kolotous_701
    Kolotous_701 New Member
    I currently have 2.0 fox shox. I want to lift it up a little higher. Can you provide details on installing the shackles would make a difference? Any pictures would help. And pricing as well. Thanks
  17. Jun 10, 2020 at 6:08 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Im interested as well. My Readylift has my rear end shaking and the front tires look positive camber. Ive had it aligned and it clears out but notice im getting outer wear on my tires.
  18. Mar 20, 2021 at 4:35 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    I'm new to truck ownership but I've spent years setting up drag cars and rally cars.
    Shackles really play havoic with leaf spring function, not allowing them to flex as they were designed.
  19. Mar 20, 2021 at 5:27 PM
    #49
