Coachbuilder Shackles Etc...
Discussion in 'Ekstrom Design' started by TruckyTruck, Jul 23, 2014.
  1. Jul 23, 2014 at 1:05 PM
    TruckyTruck
    TruckyTruck [OP] Dumbest Username
    Gary
    I am collecting parts for my mid-travel setup. David Ekstrom, owner of Ekstrom Design, makes several pretty quality things for our trucks. He goes by Coachbuilder on other forums and maybe we will have him here one day. Im just a happy customer and passing the info to you guys.
    Instead of blocks or an add-a-leaf, you can get pretty nice shackles. A lot of you probably know what shackles are, but if you don't, they are the part that goes in between your rear leaf springs and frame. I bought his +3's, which actually give between 1.5 and 1.75 inches of rear lift. Also I picked up polyurethane bushings and half inch strut shims. He sends you a carrier bearing drop kit with the shackles too. The shackles and poly bushings get rid of our trucks bead bounce and solidifies the rear end ride quality.
    I plan on doing 3.5 inches of lift for the front and decided to use half inch shims with coilovers. I didn't want to have to crank the coilovers up all the way and loose ride quality. Anyway, here are some pics. Some beefy shackles!
  2. Jul 23, 2014 at 4:06 PM
    Mac-ak
    Mac-ak New Member
    Jeremy
    2013 RW DC
    De-badged,tint,bedliner,remote start,21' Blitz pro,14 inch stubby,Rigid D2 Fog Conversion, powder coated RW rings, leveling kit, Wet Okole fronts, weathertech mats F&R
    Beefy is right holly crap! Shackles are a better option than blocks imo and are cheaper than a new leaf pack. If you dont mind how much do they run?
  3. Jul 23, 2014 at 4:11 PM
    TruckyTruck
    Gary
    The shackles, bushings and carrier bearing drop was 250 and the shims were 15 per shim. Shackles alone were 195. Shipping was included and shims and shackles were powder coated.
  4. Jul 23, 2014 at 4:16 PM
    Mac-ak
    Mac-ak New Member
    Jeremy
    2013 RW DC
    Can't beat that, I was just looking at his stuff very impressive for sure.
  5. Jul 23, 2014 at 4:19 PM
    TruckyTruck
    Gary
    Yeah I looked at all the options for rear lift and this was the best I've found. If I'm going to change the factory suspension, I felt like I wanted something solid.
  6. Jul 23, 2014 at 4:27 PM
    Mac-ak
    Mac-ak New Member
    Jeremy
    2013 RW DC
    Sounds like we are trying to accomplish about the same thing as far as lift goes. will look into these when its time for sure. My other thought was to go with the 3 leaf progressive pack from ICON.
    TruckyTruck[OP] likes this.
  7. Jul 23, 2014 at 4:44 PM
    TruckyTruck
    Gary
    I looked at that too. I almost went with the icon pack, but decided if I ever get a wild hair to lift with the zone 5 inch, I would already have shackles and could just add the icon pack for a full 3 inches in the rear. After reading about bed bounce and the improved ride with the bushings I figured I'd do this. Plus I wanted a less body roll without a sway bar. I like the icon pack though. It's the only other way I would go.
  8. Jul 23, 2014 at 4:48 PM
    Mac-ak
    Mac-ak New Member
    Jeremy
    2013 RW DC
    Interested in hearing if it does infact cure the bed bounce.....so hurry up and install them already ! Haha
  9. Jul 23, 2014 at 5:56 PM
    TruckyTruck
    Gary
    That's what everyone says, but I can't wait to see for myself!
  10. Jul 23, 2014 at 7:05 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    I have priced out a set of these with David. Great guy, runs them himself and has tons of information about set-ups for our trucks. I will definately be going this way when I do a lift!
  11. Jul 23, 2014 at 7:08 PM
    TruckyTruck
    Gary
    Yeah I left him a message and 5 minutes later he called and spent about a half hour talking about the shackles and the best ways to go with lifting the truck. Good guy
  12. Jul 23, 2014 at 10:34 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I am between these and new full leaf packs from Alcan. Let us know how these are after you install.
  13. Jul 23, 2014 at 11:13 PM
    TruckyTruck
    Gary
    I sure will. It may be a bit though. I've been going back and forth on different coilovers. It is looking like a set of kings will be what I go with, but I'm just going to wait a bit longer for Sean to find out what's going on over at toytec.
  14. Sep 2, 2014 at 10:04 AM
    jedi926
    jedi926 New Member
    Any update? I have looked at the CB+3 shackles versus the RL 2" block kit. let us know. Thanks. Jedi
  15. Sep 2, 2014 at 12:49 PM
    TruckyTruck
    Gary
    Shackles are the best way to go in my opinion. No chance of axle wrap and these with poly bushings are supposed to almost eliminate bed bounce. I haven't done the install yet because I'm debating between coilovers.
  16. Sep 2, 2014 at 12:56 PM
    jedi926
    jedi926 New Member
    Sorry in advance. Axle wrap?
  17. Dec 30, 2017 at 9:10 AM
    Air2Ground
    Air2Ground This summa bitch is gonna scream!
    Michael
    Herndon, Va
    Building this brick by brick.
    K&N CAI Series 77 Banks Monster Exhaust Stage 2 Icon suspension SPC UCA's Coachbuilder Shackles +2's and poly bushings Coach Builder Front Bump Stops Steel Braided Break Lines by ToyTec Icon 6 speed 17" Wheel 315/70/17 BFG Goodrich KO 2's Tekonsha Trailer Brake AirRaid Throttle Spacer Slotted/Drilled Rotors by StopTech w/ stock pads Pioneer AVIC 8100 Receiver/Focal Component Speakers (4) JL Stealthbox JL Audio HD series amps 500/4 and 750/1. Complete Dynamat of cab Python Alarm/Remote start Linex sprayed front billet grille with "T" logo Linex sprayed bed Retrax Bed Cover 6" powder coated step bar High End 3M 5% tint PIAA Fog Lamps DIY Superman trailer hitch "S" WeatherTech Mats TRD Shift Knob Upcoming Mods: debagging Future mods: Front/Rear bumper winch supercharger and rebuild (blueprint) engine new lights in and out headlight/taillight combo Skid plates Cat Back Exhaust and Long Tube Headers.....? (Still deciding most optimal way) I NEED A SOLID TUNE!!!! Etc....
    Hi guys, I just visited this post and wanted to add a couple things and get some feedback. First, I just installed my Stage 2 Icon kit. I have the front sitting at about 2.5" that puts me maybe at a .5" rake. LOVE THE RIDE. However, I put on the 6 speed wheels for better offset etc to fit a bigger tire and I put on 315/70/17 BFG KO2's. I had to eliminate the front wheel liner and the splash guard and still have some rubbing going on. I really didn't want to remove anything because now I have exposed fog lights etc underneath, but that is what we did. I regret that. Now, I am thinking of raising the front another .5" to .75" in front and add a 1" shackle in rear to keep my rake relative to its current stance. What are your suggestions with my particular setup? Which shackle? Also, I really want to add my wheel liner back on too. Please help.....
  18. Jan 2, 2018 at 3:49 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    You have a few options, We build a front bumper shim kit that will slide the bumper forward .50".. this will take everything with it, plastic fender liners, fog light covers ect. I'll post a pic of the kit installed.
    You can use a few of our coilover shims to increase ride height by .50" per shim. you're able to use up to 2 shims per side and normally use 2 shims on the driver side and 1 on the passenger to level the truck out side to side correcting the tundra lean. This will also allow you to keep the preload on the coilovers the same on each side. When shimming Id def recommend using our front bump stop extension kit as well.
    In the rear our +2" Coachbuilder shackles provide 1.25" of total lift and will set the truck up to look very close to live but will measure just a touch higher in the rear.
    * Adding the shims up front will not increase preload keeping your ride quality the same.
    Our Rear shackles and poly bushings will greatly improve ride quality and the functionality in the rear suspension. Hope this helps.
    We have forum pricing setup and will gladly pass it on, If you have any other questions or would like to get parts headed your way feel free to contact me direct. David 801-635-4872
    mvetrox, Beesta, speckmon and 8 others like this.
  19. Jan 22, 2018 at 6:19 AM
    bummedkaauTRDPRO17
    bummedkaauTRDPRO17 New Member
    STOCKTON, CA
    2017 TUNDRA TRD PRO
    I'm interested on the front bumper shim kit, any installation pictures?
  20. Jan 22, 2018 at 10:23 AM
    TruckyTruck
    Gary
    Nope. Sorry. It's a pretty easy install though
  21. Jan 22, 2018 at 12:16 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Here is a before and after
    ^^^ TRD PRO suspension ^^^^
    ^^^ TRD PRO Ekstrom style^^^
    These are 1/2" bumper spacers. You don't even notice the difference and it made room for my tires. They do not rub at all. Easy install. Two guys ~20-30min for the bumper shims. I did +3 shackles for towing.
    THANKS DAVID!!!
  22. Jan 22, 2018 at 3:49 PM
    bummedkaauTRDPRO17
    STOCKTON, CA
    2017 TUNDRA TRD PRO
    Toyotoholic likes this.
  23. Jan 22, 2018 at 3:54 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    No prob.
  24. Feb 19, 2018 at 6:41 PM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    Would you please PM me a quote for shims (I guess 4), a set of shackles (undecided on size) and a bump stop kit?
    Thanks.
  25. Mar 13, 2018 at 12:05 PM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    the bumper spacers, if you use those, is there no trimming on the front to run 35" tires ?
    if lifted up front 2.5"-3".
    Toyotoholic[QUOTED] likes this.
  26. Mar 15, 2018 at 7:18 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Minor plastic rework and lose both mud/splash guards, no CMC. My tires are 34.4" and I have no rubbing whatsoever. I can take some pics of the plastic if you want. All this does depend on tire size/width, and wheel off set and width too. And definitely 3" minimum lift for 35's.
  27. Mar 15, 2018 at 4:06 PM
    TOTU17
    TOTU17 New Member
  28. Mar 20, 2018 at 8:29 PM
    408Tundra
    408Tundra New Member
    Will
    2017 Tundra TRD Limited Crewmax 4x4
    Can you post pics of your plastic rework. Any trimming or just pushed in?
  29. Mar 20, 2018 at 8:55 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    This is the only shot I currently have. I'll take some more when I get a chance... Nor'easter coming tomorrow. As far as I know, the bumper side black plastic was trimmed and pushed forward... very clean, and just the mud flap on the cab side was removed.
  30. Mar 21, 2018 at 4:34 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Very interested to know how you like the shackles considering the load you tow. I am still processing all options to remove my 1" block and go with a better option.
    What made you go with the shackles in the rear?
    Did you conisder an AAL or the Icon Pack?
    I pull a boat and a 28' toyhauler. Toyhauler weighs around 8k full. I'm looking for the best rear suspension option for regular towing.
