Can you add 2020 radio & push start to 2019?
Discussion in '2.5 Gen Tundras (2014-2021)' started by paulphilly, Aug 30, 2019.
  1. May 4, 2020 at 6:50 PM
    pillpusher84
    pillpusher84 New Member
    2024 Silverado High Country
    Custom wiring conversion harness is absolutely required as the connectors on the 2020 are all new, and not the standard Toyota has used for the last 15+ years. Took a little while to get all of the pieces and wiring pins needed, but all is working 100% like factory. Completed the conversion from my 2019 Navi unit to the 2020 Navi unit today.
    All in ~$1500 for the new components, and wiring harnesses, etc. Lots of work and wiring/soldering/heat shrinking ... but all solid wiring / professional conversion harness made and everything works as it came from the factory, plus can take out at any time and put back the old 2019 7" Navi unit.
    ninjajay likes this.
  2. May 5, 2020 at 6:25 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Does the remote start and everything work like in the 2020 model? I didn’t know how it would be with the Head unit Internet access as well with the different antennas required. Any change to the trim?
  3. May 5, 2020 at 3:26 PM
    yosh2000
    yosh2000 New Member
    Denver
    '17 MGM CM Tundra
    can you post info on the connectors and pins and where you purchased them? i would like to do the conversion one day and if you got it working 100%, would be very interested.
    Funny they changed the connectors finally after what, almost 35 yrs?! wasnt it like '86 or so that they started using those connectors?
  4. May 5, 2020 at 6:28 PM
    pillpusher84
    I only did the 2020 navigation retrofit. I'll live without the push button start. It can be done, but it is a huge PIA (looked at wiring diagrams and many new parts and wiring needed) and its not my everyday vehicle, so I can deal with using an old school key, even though for ~$50k and being a 2019 model, you would expect push button start!
  5. May 5, 2020 at 6:47 PM
    pillpusher84
    Yea ... 1987 to be exact :)
    The connectors you will need for the 2020 Unit are as follows, and all can be had via Russian/Japanese OEM Toyota Parts source @ www.megazip.net <-- fraction of what USA dealers charge ... just need to painfully await overseas shipping. Russian source (when available) is cheaper than Japan.
    Connector J202: 82824-52380
    Pins for J202: 82998-47010
    Connector J203: 90980-12731
    Pins for J203: 82998-47010
    Connector J204: 90980-12760
    Pins for J204: 82998-47010
    Connector J205: 90980-12C39
    Pins for J205: 82998-12A10
    Connector J206: 90980-12912
    Pins for J206: 82998-47010
    2020 Radio Wiring:
    J202:
    Pin 1 - Ground
    Pin 4 - Battery 12v Positive
    Pin 15 - Acc 12v Posiitve
    Pin 21 - Steering Wheel Controls SW1
    Pin 22 - Steering Wheel Controls SW2
    Pin 24 - Steering Wheel Controls SWG
    Pin 27 - SPD
    Pin 28 - Reverse 12v Positive
    J203:
    Pin 5 - CNH1
    Pin 6 - CNL1
    Pin 13 - CANH
    Pin 14 - CANL
    Pin 15 - Illumination +
    Pin 16 - Illumination -
    Pin 17 - Amplifier trigger
    Pin 19 - Ignition
    Pin 20 - Parking Brake
    Pin 21 - Mic MIN +
    Pin 22 - Mic MIN -
    Pin 23 - Mic MACC
    Pin 24 - Mic SGND
    Pin 25 - SNS2
    Pin 27 - Camera CGND
    Pin 28 - Camera Video +
    Pin 29 - Camera Video -
    Pin 30 - Camera CA+ (6v+)
    J204:
    Pin 7 - SUP - J206-Pin 21
    Pin 19 - RST - J206-Pin 22
    Pin 22 - SI+ - J206-Pin 6
    Pin 23 - SI- - J206-Pin 7
    Pin 25 - MCO+ - J206-Pin 13
    Pin 26 - MCO- - J206-Pin 14
    J205:
    Pin 1 - Front Right Speaker +
    Pin 2 - Front Left Speaker +
    Pin 3 - Rear Left Speaker +
    Pin 4 - Rear Right Speaker +
    Pin 6 - Front Right Speaker -
    Pin 7 - Front Left Speaker -
    Pin 8 - Rear Left Speaker -
    Pin 9 - Rear Right Speaker -
    J206:
    Pin 6 - VOI+ - J204-Pin 22
    Pin 7 - VOI- - J204-Pin 23
    Pin 9 - SPD - J202-Pin 27
    Pin 10 - Battery 12v + - J202-Pin 4
    Pin 13 - MIC+ - J204-Pin 25
    Pin 14 - MIC- - J204-Pin 26
    Pin 19 - REV2 - J204-Pin 28
    Pin 21 - SUP - J204-Pin 7
    Pin 22 - RST - J204-Pin 19
    Pin 23 - Ground - J202-Pin 1
    2019 Radio Wiring:
    J133:
    Pin 3 - Accessory 12v +
    Pin 4 - Battery 12v +
    Pin 5 - Front Right Speaker -
    Pin 6 - Front Left Speaker -
    Pin 7 - Ground
    Pin 9 - Amplifier Trigger
    Pin 10 - Illumination +
    J134:
    Pin 1 - Rear Right Speaker +
    Pin 2 - Rear Left Speaker +
    Pin 3 - Rear Right Speaker -
    Pin 5 - Illumination -
    Pin 6 - Rear Left Speaker -
    J135:
    Pin 1 - Ignition
    Pin 2 - Reverse
    Pin 4 - Microphone - MACC
    Pin 5 - Microphone - Min +
    Pin 6 - Microphone - SNS2
    Pin 9 - CANH
    Pin 10 - CANL
    Pin 15 - Parking Brake
    Pin 17 - SPD
    Pin 18 - Microphone - SGND
    Pin 19 - Microphone - Min-
    Pin 23 - Steering Wheel Controls SWG
    J136:
    Pin 3 - CNH1
    Pin 4 - CNL1
    Pin 11 - Camera + (6v+)
    Pin 12 - Camera Video +
    Pin 23 - Camera Ground
    Pin 24 - Camera Video -
    For vehicle-side female connectors - use Metra standard quick harnesses for aftermarket radio installation on J133 & J134 (Metra 70-1761). J136 you can use a 24-pin toyota camera retention harness (Metra AX-TOYCAM3). J135 you can use a 28-pin toyota steering wheel retention harness (Metra AX-TOY28SWC) ... you may need a few extra pins for the total of 8 pins needed on this connector.
    I sourced the new 2020 radio USB connector from the ebay seller that I purchased the 2020 radio from, so i do not have that part number to share, however the additional harness you will need to connect this 2020 usb to the usb wiring behind the 2019 radio is the Metra (AX-TOYUSB).
    2020 Navigation Radio & Navi ECU: https://www.ebay.com/itm/293336662235
    jtwags likes this.
  6. May 12, 2020 at 3:04 PM
    kentran5397
    kentran5397 New Member
    Dallas. TX
    2014 Tundra 1794 Edition
    2019 Trd Pro LED Headlight 2019 1794 Grill LED Interior and Reverse Light LED Bedlight Vled Footwell LED Driver Side Grab Handle Bullet Fender Flares MX4 BakFlip Start X Remote Start Dual USB ports for the front and rear KO2 A/T Tires 275 60 R20 *Future Mods* TRD Rear Sway Bar Leveling Kit 38 gallon fuel tank swap
    I have a 14' 1794 with the JBL sound system. Do you think this may work on my truck?
  7. May 15, 2020 at 10:16 AM
    Xr0ckstar
    Xr0ckstar New Member
    2020 quicksand
  8. May 15, 2020 at 11:27 AM
    pillpusher84
    This should work with your JBL unit that you have now. You of course will need to create a custom wire harness to convert from the 1987-2019 connectors to the new 2020 connectors at the back of the new radio. My non-JBL has an external amplifier, so essentially it is the same as far as wiring goes from the new unit to the amplifier and speakers
    I no longer have an active TIS subscription, however if you do a 2-day subscription to the techinfo.toyota.com site nad grab me the navigation wiring diagram for your year and JBL system, i can review it against the 2020 system and confirm for sure for you.
  9. Aug 14, 2020 at 11:56 AM
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Cold air intake, LED upgraded lights, 295/70/18 Toyo Open Country M/T.
    If anyone is interested in a 2020 HU, I had it only one month in my truck and swapped for after market. Perfect condition. I do not know any of the details above about fit for older models, but $750, shipped any where in the lower 48. Better than the $1500 on EBay
  10. Aug 14, 2020 at 12:04 PM
    kentran5397
    Dallas. TX
    Do you have the JBL model, or the non-JBL model ?
  11. Aug 14, 2020 at 12:34 PM
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    sorry, forgot that part. It is with the JBL premium system
  12. Aug 14, 2020 at 1:15 PM
    Elduder
    Elduder New Member
    This. I just sold a break out harness with an amp to a guy with a 2020 Tacoma, it didnt work out. All the 2020 unit have new connectors, Metra doesnt have anything available yet either, so to make it work you'd be cutting the wires and re-pining them.
    Its a bummer that Toyota changed the, since they have used the same connectors for so long, and they were even the same from Tacoma to 4Runner to Tundra.
  13. Mar 23, 2021 at 6:09 PM
    pillpusher84
    sold my tundra ... so up for sale is my 2020 navi unit with pre-2020 conversion harness for a plug-and-play setup ... posted to the for-sale thread/forum
  14. May 13, 2022 at 3:07 PM
    pillpusher84
    no, this sold a year ago :(
  15. May 13, 2022 at 3:09 PM
    sgtfluffy16
    sgtfluffy16 New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    Dang, im looking for something.
    After driving my 19' TRDpro for 2500 miles in less than a week. I absolutely hate the infotainment system. I bought the truck new 3 years ago. Always had a company vehicle, until recently. I want wireless Android auto / carplay but I don't want to take away from any of the factory features my truck offers. Steering wheel controls, Bluetooth, backup camera, nav. I do not want to install a new backup camera or a new microphone for the Bluetooth. I looked on Crutchfield website and didn't find many aftermarket options. You guys have any suggestions on where to look? Looking for something that fits in the dash and sits behind the radio bezel trim and slightly bigger screen is prefered as well. Probably going to put some speakers in the truck to top it off. Please drop links and or pictures if you have them
  16. May 13, 2022 at 3:16 PM
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Look at the kenwood echelon's...1007or 1057. Works great on my 19 tundra...swapped out all speakers and added a JL amp and subwoofer.
    TundraTEX518 and 1UP like this.
  17. May 13, 2022 at 3:21 PM
    sgtfluffy16
    Corey
    Stock
    Thanks for your picture, however this sticks out past the dash. Exactly what I don't want, as i stated a above
  18. May 13, 2022 at 3:49 PM
    pillpusher84
    you're only going to get approximately 8in screen max (ie Kenwood DNX997XR) if you want one that fits as a double-din radio into a Scosche or Metra dash kit
    The Kenwood above and the equivalent JVC (my preference, as it has no large knob) are very similar to what Toyota's most recent offerings look like. I installe this in my friend's 2019 Tundra a few months back. Replaced speakers and amp, etc. as well .... much better sound than original Non-JBL stock system, and Wireless CarPlay! :)
  19. May 13, 2022 at 3:56 PM
    #49
    Wixo
    Wixo The Best Member
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    I do miss the remote start, keyless entry and not having to reach in my pocket for keys, but I enjoy making ecoboost piss out their oil when I rev up the 5.7L next to em.
  20. May 13, 2022 at 3:59 PM
    #50
    Wixo
    Mawr
    RGV
    5.7L 4x4 CrewMax SB
    Tint
    Toe Poppers are my favorite FLOD for intruders.
  21. May 13, 2022 at 4:23 PM
    #51
    sgtfluffy16
    Corey
    Stock
    I just don't like this screen protruding out of the dash. I think it looks out of place and trashy. From what I can tell it in and possibly some nine inch will fit behind the– trim. Looking at the Alpine Halo F509. Going to do some more digging. I would do an aftermarket amplifier but I don't feel like running all of the additional wires. Unless our trucks are already wired up and we just need to upgrade the components themselves
  22. May 14, 2022 at 4:16 AM
    #52
    dkrou
    dkrou New Member
    dan
    2019 tundra
    For what its worth I like mine more than the latest big screen offering which almost looks too big for the dash...I'm sure if you called James @tech12volt he can come up with a HU that will fit in the old space.
  23. May 14, 2022 at 7:30 AM
    #53
    sgtfluffy16
    Corey
    Stock
    I did check his website for the last few days. It doesn't really offer anything of what I'm looking for. Or do I need to contact him physically?
  24. May 14, 2022 at 12:07 PM
    #54
    dkrou
    dkrou New Member
    dan
    2019 tundra
    Call him give him what you are looking for and a budget....he is great and does a ton of business off this forum
  25. May 14, 2022 at 10:37 PM
    #55
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    @panicman and @OGDark Knight have some nice setups with the Pioneer DMH-WT8600NEX getting it as close to the dash as possible (hopefully they’ll throw up some pics). This is the route I’m going as well and will see how close I can get it.
  26. May 15, 2022 at 8:56 AM
    #56
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Here is how I installed the Pioneer…
    BlueSpartan1597 and sgtfluffy16 like this.
  27. May 15, 2022 at 9:16 AM
    #57
    sgtfluffy16
    Corey
    Stock
    Okay. This! This is VERY clean. I want to do so e so that I don't have to run a new GPS module or a new Bluetooth microphone. But I don't want to lose any functionality of the truck itself. I don't want to lose any of the instrument cluster information. I don't want to lose The Back-up Camera. I don't want to lose steering wheel controls.
  28. May 15, 2022 at 10:14 AM
    #58
    panicman
    Eric
    With the Pioneer, you’ll also install the Maestro RR adapter. That will retain all factory dash and steering wheel functions.
    Now, the Maestro has a lead that plugs right into your OBD. Rather than losing any data readout, you actually gain data that you would need an OBD reader to access. I set up a custom towing dashboard on the Pioneer so I can have a constant chase/trailer view, and monitor transmission temp.
    This unit will give you wireless CarPlay and the Android equivalent.
    You will need to run a wired microphone. I followed another users advice and ran it up the driver molding and across the headliner to the stock location in the ceiling console. I tucked the factory mic out of the way and hot glued the new mic in place. That took maybe 20 minutes. Sound quality is greatly improved when I talk on the phone.
    For GPS I primarily use Waze over CarPlay, or Google Maps. You don’t need anything installed in the truck for GPS, you just need your phone. Likewise if you are a fan of XM, just download the app and you can use it seamlessly through CarPlay.
    This head unit totally eliminated the hiss I discovered when I added a 5ch amp, sub, and all new speakers.
    This unit allows you to precisely adjust your sound, through enhanced bass and loudness, seat position presets, an adjustable equalizer, adjustable crossover, fader and balance, and finally, through an easy to use volume control for each speaker.
    If anyone has any questions, I’m happy to answer.
    The detailed installation thread is here:
    https://www.tundras.com/threads/new...600nex-into-a-2018-sr5-entune-non-jbl.100157/
    RegGex likes this.
  29. May 15, 2022 at 10:22 AM
    #59
    sgtfluffy16
    Corey
    Stock
    does the OBD2 port have to be plugged in? I already have a setup that i only use when towing.
  30. May 15, 2022 at 10:41 AM
    #60
    panicman
    Eric
    You could unplug it and you’d only lose access to data. Function would not be effected.
    But, what are you plugging in when you tow?
    You may be able to monitor everything you are currently monitoring, but now it will be on your head unit.
