Anyone change up their decals/badges... Location, colors, etc?
Discussion in '2.5 Gen Tundras (2014-2021)' started by wiretwister, Sep 6, 2020.
  1. Sep 7, 2020 at 1:14 PM
    Kanobi13
    Kanobi13 New Member
  2. Sep 7, 2020 at 1:38 PM
    Zero One Actual
  3. Sep 7, 2020 at 1:43 PM
    Nice but I can't tell what brand of truck you have.....
  4. Sep 7, 2020 at 1:45 PM
    Jerry Te37
    Jerry Te37 New Member
    Jerry
    Lapalma ca
    2014 2wd white tundra cm
    Jdm volk racing 20inch te37 Level rear end Morimoto headlight
    Black Wolf likes this.
  5. Sep 7, 2020 at 1:47 PM
    Nice....but you left the crappy TRD bed sticker on......as you mentioned
  6. Sep 7, 2020 at 1:47 PM
    Kanobi13
    Kanobi13 New Member
    Clear as day bad a$$ truck!
  7. Sep 7, 2020 at 1:49 PM
    Jerry Te37
    Jerry
    Lapalma ca
    Thanks!
    That’s my next project..
  8. Sep 7, 2020 at 1:55 PM
    wiretwister
    wiretwister [OP] Sorta new guy
    NJ
    '22 SR5 CM
    Zero One, you're on 285-75 18s right?
  9. Sep 7, 2020 at 6:29 PM
    Zero One Actual
    That is correct. I had the SCS Ray 10s with a plus 25 offset and Cooper AT3 XLT and sold those to a friend and went crazy and got gold Method 315s with a plus 18 offset and Toyo AT IIIs. Total Chaos UCAs and Bilstein 6112s on top setting.
  10. Sep 7, 2020 at 6:31 PM
    Zero One Actual
    Just check my debit card gas purchases and you will.
  11. Sep 11, 2020 at 9:35 AM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    EAG Grill and I added the TRD logo.
  12. Sep 11, 2020 at 10:40 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Just went to debadge my truck but the dental floss wasnt cutting. Im gonna have to pick up some fishing line and try again this weekend.
  13. Sep 11, 2020 at 10:44 AM
    18" TRD Off Road Wheels
    Did you heat the badge first? I've not done it, but the usual recommendation is to warm it up with a heat gun, or leave it in the sun.
  14. Sep 11, 2020 at 10:47 AM
    CaptainGrumpus
    Maine
    Im paranoid about taking a heat gun to anything near the paint. Im gonna try some fishing line this weekend but if that doesnt work, Ill get out the heat gun. I really want the SR5 badges off more than anything else.
  15. Sep 11, 2020 at 10:47 AM
    jclaffee
    jclaffee New Member
    Durango, CO
    nice looking rig.
    Backslider[QUOTED] likes this.
  16. Sep 11, 2020 at 10:49 AM
    Fishing line won't work any better if you don't soften the adhesive. Those badges hold on for years through weather and washes. You'll have to warm it up a bit to soften it. If you don't you might pull hard enough on the adhesive to lift the paint under the badges, and that'll be way more of an issue.
  17. Sep 11, 2020 at 10:51 AM
    CaptainGrumpus
    Maine
    I didnt even think of that possibility.. Thanks for the insight. :thumbsup:
  18. Sep 11, 2020 at 10:52 AM
    jclaffee
    jclaffee New Member
    Durango, CO
    Try squirting 3m adhesive remover behind them so it soaks into the foam adhesive backing for a while. Then use the floss or fishing line. You shouldn't need heat if you do that.
    on edit: the 3M stuff is paint safe (I've been using it for 20 years). But watch the off brands. I used another brand on the wife's Jeep years back and it immediately started taking paint off.
  19. Sep 11, 2020 at 10:57 AM
    #49
    CaptainGrumpus
    Maine
    I think ill try that first.
  20. Sep 11, 2020 at 10:59 AM
    #50
    jclaffee
    jclaffee New Member
    Durango, CO
    Should work, good luck.
    What part of Maine are you in? I grew up in "The County".
  21. Sep 11, 2020 at 12:05 PM
    #51
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    That's why all mine came off.
  22. Sep 11, 2020 at 2:39 PM
    #52
    CaptainGrumpus
    Maine
    I’m in York county. The current center of COVID outbreaks. What a scene right now with school
    BravoDeltaRomeo likes this.
  23. Sep 11, 2020 at 2:46 PM
    #53
    CaptainGrumpus
    Maine
    So i ended up spraying some WD-40 behind the SR5 badge and let it sit. I had run out of dental floss so I tried using some plumbers tape and it worked pretty good. I took a long piece and twisted it to give it some strength. It started out slow but then cut thru the adhesive like butter. The WD-40 allows me to pick the rest of the adhesive off with my fingernail. I then washed the area with a combo of Dawn and water and then hand buffed it with some Griots correcting cream. Looks pretty good. I only did the passenger side though lol. I’ll have to get to the driver side this weekend.
    Steelerjax likes this.
  24. Sep 11, 2020 at 2:48 PM
    #54
    I thought that dawn was a no no for cars because it breaks down the wax and protection?
  25. Sep 11, 2020 at 2:57 PM
    #55
    BravoDeltaRomeo
    Bruce
    MB Canada
    Hot day, blow drier on LOW from 12" away, plastic kitchen pot scraper to get corner up, keep working blow drier, slowly lift.
    No Dawn for me for the reason you posted or WD40. I rubbed excess tape off with thumb and blow drier heating, then Auto GooGone (GoofOff for you USA guys and gals), then Car Wash Soap and polish over the area
    @CaptainGrumpus
    The fishing line and dental floss never worked for me. I used a kitchen scraper, thin, pliable.
    https://www.tundras.com/threads/debadging-a-new-tundra-need-advise-and-encouragement.53633/
  26. Sep 11, 2020 at 3:21 PM
    #56
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I relocated my badges from the truck to the shed door. Started with 20 lb test, but quickly moved to 80. Alcohol, my thumb and light use of a paper towel took care of the residual.
    GODZILLA and BravoDeltaRomeo like this.
  27. Sep 11, 2020 at 4:44 PM
    #57
    CaptainGrumpus
    Maine
    I used dawn and water clean the area before the griots and then some p&s beadmaker. It’s good enough for now. I’m gonna do a full detail before winter.
