Adjusting rear drums.
Discussion in '1st Gen Tundras (2000-2006)' started by Pucks18, Feb 21, 2020.
  1. May 29, 2021 at 6:12 AM
    Professional Hand Model
    Hand Protectors
    You may need to slightly break free the ‘Bushing’ Bolt (Pivot #1) with heat or lots of penetrant. Mine was not seized. The other Pivot #2 on mine was seized. This caused a condition where my Parking Brake Cable was ‘Self Adjusting’ only the Pass Side Wheel. The lever wasn’t ‘Equalized’ in its self adjustment.
    None of this is in the FSM which I followed to the T (per brake adjust), but could never understand why I could not get it right. The Equalizer Mystery (for my case) was solved when a member here decided to replace his Bushings and broke the Bolt during removal.
    I never knew there were Bushings in there. Once I started messing with mine I discovered Pivot #2 actually was a pivot. It looks like a welded piece and mine was seized until I started investigating. Broke it free and lubed hard. Ordered 2 new bushings and installed. Both rears drums self adjust Equally, now.
    Jack McCarthy and FirstGenVol like this.
  2. Jun 11, 2021 at 11:24 PM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    Luckily I was able to to take off the bolt that mounts it to the frame bracket. Cleaned up the bolt with a dremel and painted it with a rust converter. The bolt was not fully threaded. After the bolt head it has a shank that fits just snug enough to rotate inside the two polymer bushings. No clue what material it is made of. Got the bushings $2.50 ish for the pair and two tube of red rubber grease for $8 each was free pick up at the dealer. I thought I could use the bolt that came with the aftermarket cable which was a fully 3/8-16 thread bolt and serrated flange nut. Unfortunately it seems that nut on the mount bracket is welded and it's something between a M6 or M10, my guess it's a M8. Had I known that I would had gotten the Toyota bolt too, it was under 2 bucks. Placed my order before trying to take off the bolt.... Now when engaging the park brake operates and turns both star adjusters on the rear drums. And now I can properly perform procedures in the FSM.
    ToyotaDude and Jack McCarthy like this.
  3. Jun 12, 2021 at 6:08 AM
    Hand Protectors
  4. Jun 12, 2021 at 8:22 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
  5. Jun 24, 2024 at 7:52 AM
    defyreality
    defyreality New Member
    toronto
    2003 Tundra AC T3 edition 4.7L 2wd
    bit of necromancy here, but some followup info as this post has lots of good info and pics. Toyota changed the rear drums around September of 2002. so anything built after that should have a slightly different shoe, and the self adjusting setup is different. the secondary "lever" on the front shoe that engages the star adjuster is removed and a different one is on the rear shoe. the parking brake does not adjust these ones post 08-2002. the old reverse and jam the brakes does (you should hear it clicking). other than that, same same, but different, still same same kind thing :)
    shifty` and FrenchToasty like this.
  6. Jun 25, 2024 at 8:24 AM
    3bears
    3bears New Member
    Joshua
    fairbanks alaska
    2002 acess cab
    none yet
    thanks for this explanation on how to adjust
  7. Jun 28, 2024 at 5:07 PM
    BluegrapeVr6
    BluegrapeVr6 New Member
    J
    02 SR5 RC Desert Sand- ARB'd 4x4
    BOSS head Unit, Track Rack, Tint. MT Baja Legend EXP 16x9, Pro-Comp 69, Icon Titanium Rebound 17x8. Cant decide on Lift. ARB Rear. Bash Fab Sliders.
    Damn brothet. Thank you. U just pointed out my issue. Expexpt me passenger wad not adjusting.
  8. Jul 2, 2024 at 8:41 PM
    Jedgar
    Jedgar New Member
    2006 SR5 Double Cab 4WD, V8, forest green w/ topper
    None (no lift, don't want one), Bilstein 4600 shocks soon. Bigger Michelin tires soon.
    What are good/best replacement shoes? Source for good value cylinders and drums?
  9. Jul 3, 2024 at 6:48 AM
    Advics brand is OEM front and rear I believe, but buying Advics brand cost significantly less than OEM from Toyota, stick with Advics to get OEM performance.
    OEM drums, unless you like warped drums straight out of the box. This is true for front rotors also.
    Cylinders, only replace if they're not functioning, just service and lube. This is 2x as true with the adjusters, if the stars aren't worn down, follow the FSM / factory service manual (downloadable via link in THIS THREAD, 4-5 paragraphs in) for servicing instructions.
    For drums, assess whether the springs are uniform and in good shape, if not, get a kit to replace them.
    Avoid major chain store brand parts, in a nutshell. You'll be shooting yourself in the foot.
    w666 likes this.
  10. Jul 3, 2024 at 4:11 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Learn a new word and all of a sudden you hear it everywhere! While searching for rear drum cylinders I discovered Advics (OEM is unrealistically expensive!). Turns out that Advics is Aisin!
    https://www.advicsaftermarket.com/product-lines/
    shifty`[QUOTED] likes this.
  11. Jul 3, 2024 at 8:12 PM
    Jedgar
    Jedgar New Member
    Pulled a drum off this afternoon: cylinder, adjuster, drum, and all hardware look really good, shoes eccentrically worn but look like they still have a few thousand miles left on them, believe all are original. Cleaned everything up real good and put a little lube on the adjuster threads. Truck, 2006 DC, has 87k miles on it, has lived in Florida it's entire life. Think I'll buy a set of shoes just to have them on hand. Will pull other drum, inspect clean up. Will free up (as necessary) parking brake cables and bellcranks and adjust. Will check and adjust load proportioning valve. Will adjust to make sure shoe contact has no slack.
  12. Jul 3, 2024 at 11:22 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
  13. Jul 4, 2024 at 9:04 AM
    Jedgar
    Jedgar New Member
    Thanks for the link! Ordered a set of shoes and a set of pads.
    ToyotaDude likes this.
  14. Jul 4, 2024 at 12:00 PM
    ToyotaDude
    ToyotaDude Member
    Rotors end up a good deal too if they need replaced (but have had sets take multiple pad sets before replacing) - and with free shipping that is important due to weight when buying online.
  15. Jul 4, 2024 at 6:41 PM
    USERidiculousNAME
    USERidiculousNAME ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    Didn't read every comment but seems you could try pressing and releasing parking brake a bunch of times, assuming like myself you rarely use it until you have to jack up the truck or something
  16. Jul 4, 2024 at 8:05 PM
    Jedgar
    Jedgar New Member
    I use my parking brake semi-frequently while launching and loading my boat, at least a couple of times a month.
  17. Jul 5, 2024 at 1:30 AM
    ToyotaDude
    ToyotaDude Member
    The drum brakes often need manual adjustment. Mega thread here.
    shifty` likes this.
  18. Jul 6, 2024 at 11:42 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    I think not only works that way on certain years according to a comment in here. I was always under the impression that it worked for all first gens that way.
    PNW15 and ToyotaDude like this.
