3rd Gen Tuner
Discussion in '3rd Gen Tundras (2022+)' started by Rwaters, Mar 5, 2022.
  1. Sep 11, 2022 at 6:25 PM
    #211
    Tundrafarm
    Tundrafarm New Member
    22 hybrid limited 4x4
    Between the oil pan and the electric motor
  2. Sep 11, 2022 at 6:26 PM
    #212
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Seems to be a common problem amongst hybrids
    Booyashakalaka! likes this.
  3. Sep 11, 2022 at 6:38 PM
    #213
    Tundrafarm
    That’s what it looks like I only seen one more here on the forums with the same issue.
    it sucks because with my Tacoma I never was worried about leaks or looking for things like I do with the tundra.
  4. Sep 12, 2022 at 5:23 PM
    #214
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    I had the same thing on my hybrid, see my post here. Unfortunately, I never addressed this issue and eventually traded the truck back in to the dealer, waiting on my '23 now.
    If you don't mind, please let us know what the dealer finds/think it is, I'm curious to know!
    4wd TRD PRO likes this.
  5. Sep 12, 2022 at 8:15 PM
    #215
    Tundrafarm
    Truck is in the dealer since last Thursday and they opened a case with Toyota and doing some test to see what’s going on, I looked at your post but mine is only leaking on the front and no grinding or creaking noises, I’m gonna wait and see what they find.
    for what it’s worth my cousin works there and he said a non hybrid sr5 (I know hybrid is not an option on sr5) had the same issue but he said the guy never came back, his guess is he traded the truck for a different brand or at a different dealer.
  6. Sep 13, 2022 at 7:05 PM
    #216
    RaceHauler
    RaceHauler New Member
    Joseph
    2022 Tundra SR5 OR
    Distribution Hitch
    How is this for towing? Torque bump?
  7. Sep 13, 2022 at 9:47 PM
    #217
    mass-hole
    mass-hole New Member
    I would keep it stock towing. Its possible they are estimating various temperatures, like EGT’s and Cat temps, and because its spoofing the air load it may be miscalculating them. Its fine for daily driving but i would be worried about it under sustained high load like towing.
  8. Sep 14, 2022 at 8:10 AM
    #218
    eddiefromcali
    Eddie
    100% Stock
    Towed about 5k with E30 blend and the highest boost map. No problems. The JB4 hooks up to your obd2 port and does not estimate anything. It takes those readings into account and will decrease the commanded psi accordingly, just like the stock ecu does as well. You could always drop it down to map1 for a mild bump in psi if you're scared. I wouldn't worry about it since the oem fail safes are still active and will kick in if needed by pulling timing and/or dropping commanded boost.
    Taikowaza likes this.
  9. Sep 14, 2022 at 11:01 AM
    #219
    OnThaLake
    OnThaLake New Member
    JB4 leaves the OEM fail-safes untouched.
    It tricks the ECM into making more power through modifying a few sensor values. Importantly, it is not modifying the a/f nor any temp sensors, which an ECM will use to verify proper operation.
    The JB4 just pushed the ECM deeper into it's pre-programmed mapping for more power. The extra power being made is actually within the parameters of what Toyota loaded into the ECM.
    eddiefromcali and jeosbor1 like this.
  10. Sep 14, 2022 at 1:42 PM
    #220
    mass-hole
    But, take the Ecoboost for example. Its exhaust manifold temperatures and some of the exhaust temperatures are calculated based on air load and RPM. If it thinks the air load is lower than it is, then it is calculating the wrong temperatures and those OEM fail-safe as effectively lifted just like the manifold pressure. Those temperatures are used to control AFR and load to help protect the engine and cats.
    Mayde the Tundra uses actual sensors, IDK, but unless you and Eddie are experts in the finer elements of the iforce tuning, then you cannot say with any certainty that the failsafes are untouched. As far as the engine is concerned it is operating completely stock and acting accordingly.
  11. Sep 14, 2022 at 1:44 PM
    #221
    mass-hole
    You missed my point about estimating. I am not talking about the JB4, I am talking about the PCM.
  12. Sep 14, 2022 at 1:50 PM
    #222
    OnThaLake
    Fair enough (BTW I have owned boosted vehicles with JB4 previously) I don't care to get into pedantic online arguments anyway.
    I don't own JB4/Berger Tuning so it's no skin off my back
  13. Sep 14, 2022 at 1:59 PM
    #223
    mass-hole
    Was it in a truck hauling a trailer up a hill under high load for minutes straight?
  14. Sep 14, 2022 at 2:04 PM
    #224
    OnThaLake
    I'm no 2022 Tundra expert. And I suppose neither are you, or are you?
    Have you owned JB 4 product before? Had one on my GTI and now on my Q60.
    I managed to destroy the DSG transmission at 20k miles staying in boost frequently over a big mountain pass. Broke the transmission, not the engine. Not a JB issue.
    I'll let actual Tundra techs chime in, but you bring up Ecoboost and I bring up other vehicles. It just seems like bickering to me.
    Henry1jg and eddiefromcali like this.
  15. Sep 14, 2022 at 2:07 PM
    #225
    mass-hole
    No I am not an expert, but I also told the guy not to tow with the JB4
  16. Sep 14, 2022 at 2:44 PM
    #226
    OnThaLake
    Gotcha, I didn't even think about towing when someone mentioned fail-safes.
    Like I said, I broke a JB4 equipped GTI DSG in the mountains, so I'm definitely not going to suggest someone run JB 4 in the mountains, towing.
    I still don't think it'll hurt the motor, I'd be more concerned with getting to cocky with extra boost while towing and either overdo the brakes or transmission.
  17. Sep 14, 2022 at 8:15 PM
    #227
    FREEDOMcomesatacost
    FREEDOMcomesatacost Go ahead, pull my finger…
    Just call me Easy
    Louisiana
    2022 SR5 Crewmax supersonic red
    Too much to list…
    I have been running the jb4 tune on my 2022 sr5 non hybrid for weeks now and love it. Will never take it off map5, highest map available for now. Yes you need to mix some fuel at the pump but how easy is that? I have a “Dragy” device in my truck too and the zero to sixty and quarter mile times have dropped pretty nicely. Don’t want to give out my specific numbers in case I am next to one of you knuckleheads at a red light!! :bananadance:
    jeosbor1 likes this.
  18. Sep 15, 2022 at 5:45 AM
    #228
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    That’s why I come to this thread, we need the hard numbers! Now spill the beans. :p
  19. Sep 15, 2022 at 7:00 AM
    #229
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Oh yea I see you got that nice slick add on, the ole supercharger!! I bet it gets after it especially on the v8. NICE!! All my other trucks have always been v8’s this is my first v6 and first turbo…:mudding:
    Silver17[QUOTED] likes this.
  20. Sep 15, 2022 at 9:18 AM
    #230
    Silver17
    Eastern PA
    To avoid derailing the thread, I’ll just say it moves pretty good for its size. Everything is going turbo 4 or 6 it seems. I’m gonna live out the glory days a while longer, but am interested in how the new V6s perform with the JB4. I wish someone had some dragy times to post so I’d have a better idea….:rolleyes:
  21. Sep 15, 2022 at 10:11 AM
    #231
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Obviously not a TRX, but for a huge arse heavy truck the 2022 Tundra’s twin turbo v6 is much smoother and quicker than I expected. I am not one for having stock anything so hopefully when someone comes out with a twin turbo upgrade kit I will be a buyer. Will be interesting to see how the engine block/trans/rear end stand up to much more power. Guess we will all find out sooner or later……
  22. Sep 15, 2022 at 4:42 PM
    #232
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    Yea, the grinding and creaking was not the issue, it turned out that the front diff self-destructed, but regardless, it was still leaking oil.
    Let me know if/what they come back with, definitely not normal I'd think! Unless its residual oil from the assembly.
  23. Sep 15, 2022 at 4:43 PM
    #233
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    Do we know if the JB4 works on the Hybrid version as well?
    Other than the JB4, are there any tuners out there for the '22+ Tundra?
  24. Sep 15, 2022 at 6:55 PM
    #234
    eddiefromcali
    Eddie
    100% Stock
    Yes. Vr tuned
    jproy12[QUOTED] likes this.
  25. Sep 23, 2022 at 12:47 PM
    #235
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    Anyone have any performance to report? Specifically with the pump gas tune Map 2. I emailed Burger asking if Map 3 is safe with 93 pump gas and haven’t heard back. I’m guessing they won’t know for sure until they get logs from users for them to review.
    FREEDOMcomesatacost likes this.
  26. Sep 23, 2022 at 12:55 PM
    #236
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
    Hope this helps and probably what they will send you;
  27. Sep 23, 2022 at 1:03 PM
    #237
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    What's the 0-60 minus the 1ft runout at least :D
  28. Sep 23, 2022 at 1:06 PM
    #238
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
  29. Sep 23, 2022 at 4:16 PM
    #239
    Silver17
    Eastern PA
    xwarcat and FREEDOMcomesatacost like this.
  30. Sep 23, 2022 at 4:25 PM
    #240
    FREEDOMcomesatacost
    Just call me Easy
    Louisiana
    Too much to list…
