2019 tundra transmission thermostat location
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jtundra81, Mar 21, 2019.
  1. Aug 29, 2019 at 9:23 AM
    Jtundra81
    Jtundra81 [OP] Just a member
    Joe
    2019 cement tundra crewmax
    After multiple trips this summer towing close to 4500lb , I can say that I'm Averaging 215 transmission temp with torque around 217 seeing up to 230 when stopping and accelerating and goes back to 215-217 .
    pickeledpigsfeet likes this.
  2. Aug 29, 2019 at 9:53 AM
    timsp8
    NY
    Has your trans temp light ever come on? Like the times when you were stopped at a light?
  3. Aug 29, 2019 at 9:56 AM
    Jtundra81
    Joe
    No that only comes up around 280 I believe , did you have any incident where the light came on ?
  4. Aug 29, 2019 at 10:14 AM
    timsp8
    NY
    I was just wondering. In my 2010 it came on around 240 I think, maybe 250. That truck had trans problems though. Haven’t towed with the 2018, but it stays around 188-194 usually. Sometimes goes up to 200-205 when accelerating up a hill at highway speeds.
  5. Aug 29, 2019 at 11:54 AM
    Jtundra81
    Joe
    Same for me without towing , I see similar readings .
    I will have dealer service transmission at 60k per the service manual of the truck ( if towing )
  6. Oct 3, 2019 at 1:20 PM
    matthew1992ya
    matthew1992ya New Member
    Matthew
    Louisiana
    2015 sr5 4x4 tundra
    Level sequoia wheels I like factory mods don't care to much for aftermarket
  7. Oct 3, 2019 at 1:30 PM
    Jtundra81
    Joe
    What year is this for ? We don't have the oil hoses in 2019 nor 2020 , i have photos at the beginning of thread
  8. Oct 4, 2019 at 3:33 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Just purchased a 2019 Tundra and am just now finding out about the missing trans cooler. As far as temp warning light is there one? I can't seem to find anything about it in the manual. I previously had a 2008 that had a temp guage. Thanks.
  9. Oct 4, 2019 at 3:38 PM
    Jtundra81
    Joe
    Yes there is one , some claim it comes up at 245 , other say higher , i have been towing all the summer my travel trailer 4500 lb and always managed to keep temp between 215 and 217 that towing with s4 and tow/haul on with torque seeing up to 230 while stopping on tolls and In traffic for very short period and never had the light come on me
    sask3m[QUOTED] likes this.
  10. Oct 4, 2019 at 4:15 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Finally found the warning light info in this damn book, lol. I tow a 6500lb 5th wheel and the temp guage always stayed somewhere just over half way on the guage my 08 had. I always used 5th gear though and towhaul unless I was crawling some mountainous areas. I guess 4th gear couldn't hurt though, sacrifice a little gas for the tranny. Thanks again.
    Jtundra81[QUOTED][OP] likes this.
  11. Oct 4, 2019 at 4:19 PM
    Jtundra81
    Joe
    The RPM was not that bad add that higher RPM more coolant flow to the trans cooler on our 2019 , just keep an eye on the temp , heard that the gauge on 2007 till 2013 was not that useful and always remained at half
  12. Oct 4, 2019 at 4:35 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    How do you monitor the temp though, isn't there only the warning light?
  13. Oct 4, 2019 at 5:11 PM
    Jtundra81
    Joe
    Get an odb2 reader and download the torque app , you need to configure the pids for the trans temp , look at the beginning of this thread I have a screen capture for the pids you need to configure,trans 1 is the temp at the pan and trans 2 is at the torque
  14. Oct 4, 2019 at 5:32 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Yeah, I've been doing more reading about these odb "gizmos". Would the scanguage ll do the same job just more pricey cause it doesn't use an app?
  15. Oct 4, 2019 at 5:36 PM
    Jtundra81
    Joe
    Yes ,lot of people use it and It is accurate .
    If you get to install one , let us know your readings while towing
  16. Oct 4, 2019 at 5:43 PM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Thanks. If I get one I'll post numbers, unfortunately likely won't be till next summer. Canada, eh. :)
    So are odb readers pretty much plug and play or is there more to it than that?
  17. Oct 4, 2019 at 5:47 PM
    Jtundra81
    Joe
    Yeah , I'm done towing for the season myself .
    Yes , You can find a cheap one on Amazon and all what you have to do is download the torque app to your phone or tablet ( I use a small Samsung tablet) and just create the 2 pids entry following the formulas In the screen shot I have and your pretty much done , no wires no nothing , will use Bluetooth to communicate with the torque app and it is pretty much as accurate
  18. Jul 20, 2020 at 8:58 AM
    PaulSidiro
    PaulSidiro New Member
    2020 Crewmax
    Hi all,
    Restarting an old but pertinent thread- I'm having the same concerns on my 2020 Crewmax.
    On a recent 400 mile trip, towing a 6000lbs trailer, I got a transmission temp temp just as we entered the town. It was about 80degrees that day and I was careful not to push things going over the high altitude passes.
    I want to check the transmission fluid level to ensure the factory fill level is correct, but I can't find the thermostat like the OP mentioned. Is the consensus that the 2019/2020 do not have a thermostat at all? In this case do we just check as per the previous models bit not worry about the thermostat pin?
    I did check the level as is at 120f and there was overflow so I'm not sure if I'm free and clear at this point.
    Thanks for your feedback again.
    Paul
  19. Jul 20, 2020 at 9:34 AM
    #49
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    Did you mean to say you got transmission overheat light or message ?
    Sounds like you could use to retrofit your truck with a transmission oil cooler . 2019+ tundras do not come from the factory with one anymore . ( Toyota cost cutting measures ). Feel free to check out and research your way through this thread - https://www.tundras.com/threads/2019-transmission-cooler.60550/
    sask3m likes this.
  20. Jul 20, 2020 at 9:43 AM
    #50
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Your transmission is probably low on fluid now. There should be overflow if you remove the check plug at 120 degrees. The fluid level check has to occur within a specified temperature range (99-111 degrees 2014-2018 AB60). Transmission fluid expands as the temperature increases, so if the level was correct at the lower "check" temperature range, then it will have expanded further at 120 deg and should overflow the check pipe. During the fluid level check procedure, you're supposed to shut the engine off and let the fluid cool if the fluid temp gets above 111 degrees.
    I have read a couple of sources that said the fluid temperature warning light on Gen3 Tundras comes on at 302 degrees, which is too hot even for full synthetic fluid (WS is a blend). If you got a warning light, then you probably began cooking the fluid. I would probably let my Toyota dealer change the pan volume, and check the fluid level for you. Maybe they'll agree to do that after you describe your warning light, and your attempted diagnosis. Typically, dealer service will argue with owners wanting a fluid change prematurely.
  21. Jul 20, 2020 at 9:58 AM
    #51
    PaulSidiro
    2020 Crewmax
    Thanks, yes the "High Temp Warning" came on for a couple seconds and I let it cool at that point.
    When I checked the fluid at 120F, there was overflow. So I'm thinking the level is correct if we don't have a cooler. I'll be bringing it to the dealer for a check regardless. Thanks again!
    jordoncloutier likes this.
  22. Jul 20, 2020 at 9:58 AM
    #52
    jordoncloutier
    Jordon
    Alberta , Canada
    That's for sure the way to go in the meantime , however the trans will over heat again the next time he tows . Installing a External Cooler system is the ONLY real solution to the problem
    sask3m likes this.
  23. Jul 20, 2020 at 10:03 AM
    #53
    PaulSidiro
    2020 Crewmax
    Yes I'm a bit disappointed in the lack of an oil cooler. My 2010 was amazing and I was under the impression that the 2020 would be even that much better. Oh well, time to save up for a trans cooler.
  24. Jul 20, 2020 at 10:04 AM
    #54
    JohnLakeman
    Oh, yes, I completely agree that everyone that tows heavy with a 2019+ IS going to have transmission problems eventually without the cooler retrofit. This @PaulSidiro case is the perfect illustration. But...I didn't need to get into that, you had already covered it.
  25. Jul 20, 2020 at 10:19 AM
    #55
    jordoncloutier
    Jordon
    Alberta , Canada
    Is @PaulSidiro the only one on here that has had the over temp warning come up when towing ?
  26. Jul 20, 2020 at 10:26 AM
    #56
    JohnLakeman
    I don't know, maybe one other. There seems to be confusion on when the warning actually occurs. @PaulSidiro had almost all the parameters for a really good test of towing without a cooler and we saw what happened: Heavy (6000lbs), mountainous terrain, distance (400miles). The only thing missing was the ambient temp was only 80 degrees (must have been the mountains) and not 110 degrees!
  27. Jul 20, 2020 at 10:49 AM
    #57
    PaulSidiro
    2020 Crewmax
    Yes, it was in the mountains. So temps were hovering 80f-85f overall.
  28. Jul 20, 2020 at 10:59 AM
    #58
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    According to infostream the trans light will come on at 302F as already stated. If you do have the light come on I would be changing out the fluid. At that temperature the transmission fluid is already deteriorated. On my '20 I reached 245F pulling my 5.5K trailer in 5th. When I was installing my trans cooler I noticed the trans fluid had a slightly darker color to it and the truck only has 20,000 kilometers on it.
  29. Jul 20, 2020 at 11:05 AM
    #59
    jordoncloutier
    Jordon
    Alberta , Canada
    Same here , my fluid was darker when I dropped the pan and did the cooler install . Id say it was almost a Black Cherry Color :(
  30. Jul 20, 2020 at 11:05 AM
    #60
    PaulSidiro
    2020 Crewmax
    Yes that's a great point. I did sample the fluid and it doesn't smell burnt or have anything but a bright red color, nonetheless I will be changing it.
    I wish Toyota used a full synthetic, and I'm not about to us anything but the dealer since I'm only at 4000 miles.
