5.7L Transmission Cooler Kits
Discussion in 'Genuine Cooling Systems' started by Genuine Cooling Systems, Jan 19, 2020.
  1. Jan 19, 2020 at 6:06 PM
    Genuine Cooling Systems [OP] New Member Vendor
    Genuinecoolingsystems.com offers transmission coolers for 2019-2021 Tundra's. As some of you know, the 2019-2021 Tundra does not come with dedicated transmission cooler from the factory. There is no better way to protect your transmission then adding a transmission cooler to prevent ATF degradation and premature transmission wear. If you are seeing "high transmission fluid temp" on your dash (which many have), this means the ATF in your transmission pan has reached 302° F (NOT GOOD).
    Every transmission cooler from Genuine Cooling Systems comes with a CNC steel powder coated bracket designed to bolt directly onto factory locations on your truck. Additionally, the kits utilize GENUINE TOYOTA factory plumbing from the transmission to the front of the truck where the cooler is mounted. Genuine Cooling Systems only utilizes high quality parts from Setrab/Susa to include Susa hose rated at 300 PSI, AN fittings, adapters, and brackets. With over 500 Genuine Cooling Systems transmission coolers on Tundra's today, you can rest assured this is a proven product with results that will maintain your transmission fluid temperatures within Toyota’s specified operating range (68-221° F).
    Tools Required:
    - Socket Set (Metric) 10-14mm and 24mm
    - 6" sock extension or 5" with a 12mm deep socket
    - Allen Key (5mm)
    - Pliers
    - Step Hole Drill (1.25") Amazon sells cheap ones for around $11.
    - Hose cutters or sharp knife
    - Hydrophilic Jack and Stands
    - Level (For ATF Check) or someway to verify your truck is level
    - Torque Wrench able to read 15-30 lb-ft (recommended)
    Where to Buy: Head over to genuinecoolingsystems.com
    Reviews: https://genuinecoolingsystems.com/pages/reviews
    Install Instructions:
    https://genuinecoolingsystems.com/support/
    https://youtu.be/Ep5CNhdMnhE
    How to Monitor Temps: Cheapest option is to buy the app "OBD Fusion" on your phone and input the custom PIDs for the pan and torque converter temperatures (see below). You will also need the bluetooth OBD adapter. There are many brands but here is one of the cheaper options.
    https://genuinecoolingsystems.com/support/#Monitoring
    In order to input the pan and torque converter custom PIDs on your OBDFusion app go to "settings" then "User-Defined PIDs". Copy the information below. Leave everything the same besides what I am telling you to change.
    ATF Pan
    Description: ATF Pan
    English Units: F
    Min Value: 0
    Max Value: 300
    OBD Mode: 21
    PID Number: 82
    Equation: ((((A*256)+B)*(7/100)-400)/10)
    Torque Converter
    Name: Torque Converter
    Description: Torque Converter
    English Units: F
    Min Value: 0
    Max Value: 300
    OBD Mode: 21
    PID Number: 82
    Equation: ((((C*256)+D)*(7/100)-400)/10)
    Check out a recent customers review Genuine Cooling System’s Setrab Series-9, 15-Row transmission cooler on his 2021 Tundra TRD Pro!
    https://youtu.be/KGwOyHpkXp4
  2. Oct 10, 2020 at 2:29 PM
    Ok, we are going to try this again.
    This is a modified post, in this section for visibility, but treat it as a for sale ad and all rules apply.
    Before you pop off in this thread, might I recommend you look at the BST rules. Questions about the product or services are acceptable.
    You have been warned.
  3. Oct 10, 2020 at 3:24 PM
    Dodger46
    Dodger46 New Member
    2019 Silver Sky Metallic SR5 Crewmax
    I have this kit and it’s awesome. I had my dealer install it so as to not void my warranty. The tech who installed it was super impressed. It even has Toyota clamps. If you are going to tow and want to keep your transmission temperatures the same as they have been since 2007. This is the kit!
    Mike59, bulldog93, hANNAbONE and 8 others like this.
  4. Oct 10, 2020 at 3:30 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Great product that chasenicholas93 offers and a must add for the 2019 -20 Tundra for those that tow. The only complete kit I've seen to add an ambient cooler.
  5. Oct 11, 2020 at 7:04 AM
    Paulismydog
    Paulismydog New Member
    2020 Black Limited Double Cab
    To anyone who installed kit: any torque specs for the puck/thermostat bolts? I seem to be getting a little weeping but don't want to risk snapping bolts. Thanks.
  6. Oct 11, 2020 at 7:36 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Just to be sure, did you move the O-Rings from the spacer to the thermostat housing? That’s critical. I hand tightened enough to compress the o-rings and no weeping. Somebody did post torque specs but they were removed.
  7. Oct 11, 2020 at 8:12 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    The 2015 tundra manual that is on the forums somewhere said 15 ft lbs. for those three bolts.
  8. Oct 11, 2020 at 8:21 AM
    Wallygator
    75 inch pounds is 6.25 ft.lbs. Quite a difference from 15 ft.lbs.
  9. Oct 11, 2020 at 11:56 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    The correct torque for the three warmer/thermostat bolts is 15 ft-lb. I suspect those bolts are M10, rather than M6. Over torque would be considerable, and is more likely to strip threads in the aluminum case rather than snap off the heat-treated bolts.
    I would double-check the o-rings. O-rings will seal with only slight compression (subject to fluid pressure). If you're still leaking with any more than slight torque, you either lost the o-rings on assembly, or they've been damaged (cut). Good practice advises to always replace o-rings during reassembly. O-rings are cheap; having to go back in to replace them is painful.
    There should be four o-rings in the AB60 transmission thermostat/warmer assembly: Two o-rings came with the thermostat to seal it the transmission case, and there were two existing o-rings to seal the warmer to the thermostat. It may be necessary to use some grease or petroleum jelly to keep the o-rings in the grooves while you're fumbling with the thermostat assembly.
  10. Oct 11, 2020 at 12:40 PM
    Thanks John. If you have damaged one of the o-rings you will have 2 spares that came off of the spacer to use.
  11. Oct 11, 2020 at 1:31 PM
    First post updated with the transmission torque specs.
  12. Oct 11, 2020 at 3:03 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    If you need a transmission cooler this is the set-up you want. Top notch components. Excellent write-up and top notch parts. By the time you assemble the parts, hunt for the fasteners, pay for shipping, the value of your time, your cost will exceed what this cost and this is one stop shopping! You can piecemeal one together with less quality components but you may very well smoke your transmission.
    BR73, hANNAbONE, Squirrel2021 and 6 others like this.
  13. Oct 11, 2020 at 4:38 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You sure its leaking and not residual oil left from the install? I also thought I might have a little leak but after a proper clean up everything was good.
    BravoDeltaRomeo likes this.
  14. Oct 11, 2020 at 5:22 PM
    @Paulismydog private messaged me. It was just residual ATF that didn't get wiped up after the install and he does not have a leak.
  15. Oct 11, 2020 at 6:39 PM
    Install instructions updated on the bottom of the first post.
    Leo's first and Joe333x like this.
  16. Oct 11, 2020 at 6:50 PM
    When the original post is updated, I will clean up the thread to minimize repeat questions and having a 45 page thread that information is hard to find.
    So far, this is going well. Thank you for not commenting on price or parts used if you do not like the kit.
  17. Oct 11, 2020 at 7:39 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Called it! :D
  18. Oct 11, 2020 at 9:19 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Thanks for the kit! Looking forward to get it insatlled.
    ColoradoTJ likes this.
  19. Oct 12, 2020 at 11:15 AM
    TheBigTimpin
    TheBigTimpin New Member
    I really appreciate all the info. Just got a 2020 and we tow a 34' trailer. OBD 2 sensor going in today to monitor temps.
  20. Oct 12, 2020 at 1:46 PM
    East tn tundra
    East tn tundra New Member
    2020 trd
    I'm afraid you will be buying one like the rest of us.
    Ruggybuggy and Wallygator like this.
  21. Oct 12, 2020 at 1:57 PM
    I will now offer partial kits that will include all the aftermarket parts needed for an install (see first post). I also am now receiving a wholesale discount from Japan due to the amount of money I spend on parts. Due to this, the price for a complete kit will be lowered to $790. Complete kits are not expected to ship until late October due to lead times from Toyota due to the large quantity of parts I requested. If you have reserved a complete kit and would like to order a partial kit instead and order your own Toyota parts, please PM me. It may be faster for you to install the kit this way.
    EasyMoney, coldcanuk, booya69 and 5 others like this.
  22. Oct 12, 2020 at 2:20 PM
    TheBigTimpin
    Just curious how much Toyota charged to install? My local Toyota just quoted my $700. Seemed high.
    Squirrel2021 and kenomouth64 like this.
  23. Oct 12, 2020 at 2:22 PM
    Holy cow! I wouldn't pay more than $200. It's a 2-hour job (max) for a Toyota Tech.
  24. Oct 12, 2020 at 5:25 PM
    Dodger46
    Dodger46 New Member
    I paid $300-$400 I can’t remember...or so? I don’t think it’s too hard to do. I just wanted to have it covered. I would negotiate? How do they know how long? Tell them 2 hours. Maybe call around?
  25. Oct 12, 2020 at 5:33 PM
    Blue Thunder
    Washington
    Nice...how much additional transmission fluid does this add to the system (and the installer has to buy)?
  26. Oct 12, 2020 at 6:05 PM
    18" TRD Off Road Wheels
    He has the fluid listed under the Toyota parts included in the first post. Part of the kit, as I understand it.
  27. Oct 12, 2020 at 6:10 PM
    The complete kit includes everything you will need to install the cooler, including the ATF. You will only need between 1-1.5 quarts of ATF and the kit includes two quarts.
  28. Oct 12, 2020 at 10:08 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That 's the issue. Because there is no labor rate for installing the cooler your at the mercy of the service writer or manager and most don't have a clue. I would insist that a tech be asked how long it would take to do. Personally it should take less than 2.5 hours. Multiply the time by the shop rate.
    bulldog93 likes this.
  29. Oct 12, 2020 at 10:27 PM
    AZBoatHauler
    So.Arizona
    Less or more?
    ElNopal likes this.
  30. Oct 12, 2020 at 11:36 PM
    Blue Thunder
    Washington
    Frak...thanks. I was looking for "fluid" as a keyword and totally skipped over it. Sorry for being "that guy"
