2019+ External Transmission Cooler
Discussion in '2.5 Gen Tundras (2014-2021)' started by Genuine Cooling Systems, Oct 17, 2019.
  1. Dec 6, 2019 at 7:41 AM
    #121
    Genuine Cooling Systems [OP] New Member Vendor
    I measured the fitting its 1/2 inch. I just need to find good 1/2 NPT to 3/8 barb elbows with one with a 12 inch extension if possible since I'm mounting the cooler vertically. I also receive my gates transmission hose and Toyota thermostat today.
  2. Dec 6, 2019 at 7:49 AM
    #122
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
    Interested to see bracket.
  3. Dec 6, 2019 at 7:54 AM
    #123
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Check inside the fitting to make sure there is no smaller flare taper. Measure the threaded ID of the fitting. Diameter will be slightly different depending if you measure root of thread or the peak, but that level accuracy is not important. Compare measured ID of fitting to the pipe outside diameters given in table below (~5/8" = 3/8" NPT, ~7/8" = 1/2" NPT):
  4. Dec 6, 2019 at 7:59 AM
    #124
    It does come with a 1/2 to 3/8 adapter.
  5. Dec 6, 2019 at 8:02 AM
    #125
    JohnLakeman
    That appears to be an AN to NPS (national pipe straight) adapter. Which end threads into the cooler?...I'm betting it's the untapered end.
  6. Dec 6, 2019 at 8:06 AM
    #126
    Big end goes to cooler which is 1/2. The smaller end (3/8) will go the the fitting and hose.
  7. Dec 6, 2019 at 8:10 AM
    #127
    JohnLakeman
    You can simplify the connection by skipping the adapter entirely, and using a hose barb elbow like the one you showed in an earlier post; i.e. elbow threaded end (1/2" NPS ?) with o-ring seal directly into the cooler, and hose barb to fit whatever hose you're using.
    It is ALWAYS better to use the manufacturers specified threaded fitting size rather than guessing or measuring...might want to double-check the manufacturer spec.
  8. Dec 6, 2019 at 8:14 AM
    #128
    Okay fellas, I guess it's a early morning. The connection is 1 inch to 3/4. I'll have to verify with the hayden website after work to make sure before I order.
  9. Dec 6, 2019 at 8:46 AM
    #129
    timsp8
    NY
    That looks like the one I put inline in my 2010. I’m pretty sure I used the adapter that came with it with no leaks. Don’t think the atf fluid is under much pressure at the cooler.
  10. Dec 6, 2019 at 5:11 PM
    #130
    I need some help finding some 90 degree elbows that have 3/8 barb end connection. I can't find the right size. Below are the stats on the cooler HD777.
  11. Dec 6, 2019 at 6:10 PM
    #131
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The video of the guy changing the atf fluid on youtube via the cooler hoses looked pretty low pressure.
  12. Dec 6, 2019 at 6:24 PM
    #132
    What do you all think of this setup?
  13. Dec 6, 2019 at 6:46 PM
    #133
    JohnLakeman
    I see nothing here on cooler model HD777, unless it's that Model 243777 on the last chart. I've never worked with AN tubing fittings and I am unfamiliar with AN fitting descriptions.
    Your best bet is to talk to technical service where you bought the cooler. Tell them the cooler model number and what you are trying to do. Maybe they sell adapter fittings that they know will work.
  14. Dec 6, 2019 at 6:53 PM
    #134
    It is the 243777 model. After some research AN fitting (Army-Navy) are for high performance applications due to the seal from the metal to metal contact. Based on the fitting type (12an) I'm just going to order these parts and hope they fit. I'll let everyone know how it goes!
  15. Dec 10, 2019 at 6:45 PM
    #135
    What do you guys recommend I do to secure the transmission hose? Are there curtain brackets someone recommends? Also, anyone recommend I install a filter like the one below?
  16. Dec 11, 2019 at 3:24 AM
    #136
    timsp8
    NY
  17. Dec 17, 2019 at 9:52 AM
    #137
    Anyone have the torque specs on the atf cooler bolts?
  18. Dec 17, 2019 at 10:33 AM
    #138
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Im late to the party. Did you get your fittings figured out? I am familiar with all the thread and fitting types shown/ listed above, and how the sizes are listed. The cooler looks to have -8 (1/2") Female ORB fitting Some general info:
    AN is also known as JIC.
    Straight thread with the O ring is also known as O Ring Boss or ORB.
    ORB and JIC have the same thread. You can slide an O ring on a JIC flare fitting and use it in place of an ORB if needed.
    They make conical seals for the JIC (AN) fittings if you have leaks, but hydraulic use they usually aren't needed. Make sure you torque to proper spec, other wise it can deform from over tightening and not seal as well.
  19. Dec 17, 2019 at 10:37 AM
    #139
    I got it figured out. They are 10AN o-ring fitting for the hayden. I got 6an 90° and 45° for the hose fittings.
    HappyGilmore[QUOTED] likes this.
  20. Dec 21, 2019 at 10:48 AM
    #140
    Does anyone have the torque specs for the 32970-34030 cooler assembly bolts?
  21. Dec 21, 2019 at 12:39 PM
    #141
    blaserdude
    Eugene
    none
    I don't but it's o ring sealed so it won't take much.
  22. Dec 21, 2019 at 1:07 PM
    #142
    Yeah, I figure I'll just snug them up tight. I am planning on getting the cooler installed the following Monday after Christmas.
  23. Dec 21, 2019 at 6:02 PM
    #143
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Looking at the pics of the warmer/cooler and the thermostat again. Is it simply the o rings on the warmer squeezing against the thermostat body that stops cross contamination of coolant and trans fluid?
  24. Dec 21, 2019 at 6:24 PM
    #144
    From what I understand the warmer is just a closed system that acts as a warming plate. The o-rings are for the spacer or cooler assembly.
    sask3m[QUOTED] likes this.
  25. Dec 21, 2019 at 6:37 PM
    #145
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Yeah sounds more likely, hard to imagine just a couple o rings doing the job, lol. Anyways I'm closely watching your progress and will likely be following suit as I use my Tundra for a decent amount of towing but only put on 5-7k a yr and planned on keeping this for a fair while. Traded my 08 in and never gave a second thought about no flippin external cooler, guess you can't take anything for granted these days.
    Rabidllamas likes this.
  26. Dec 22, 2019 at 9:38 PM
    #146
    JohnLakeman
  27. Dec 29, 2019 at 3:36 PM
    #147
    Made it back home. The mount came out perfect. Now just waiting on the stainless hardware to arrive to bolt it on.
  28. Dec 31, 2019 at 8:51 AM
    #148
    sask3m likes this.
  29. Dec 31, 2019 at 3:07 PM
    #149
    @Roman do you happen to know the part number for these zip ties? I am going to use them to secure my transmission line since the same size oval holes are on the frame. The second picture is the hole its self its 1/4" x 1/2".
  30. Jan 12, 2020 at 9:19 AM
    #150
    Quick question, hope you might know. When I remove the warmer and spacer plate, will ATF start spilling out? If so, how much do you think? If it will spill out a bunch of ATF I'm thinking of just jacking up the right side of the truck to shift all the fluid to the left side.
