2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Nov 21, 2017 at 11:27 AM
    #331
    Prerunnertundra15
    Prerunnertundra15 New Member
    Socal
    2015 Sr5 crew max
    Dealer sparksparts toyota
  2. Nov 21, 2017 at 1:06 PM
    #332
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    @Roman at Toyota Of Cool Springs he is a tundras.com member his thread have all the links with parts needed
    https://www.tundras.com/threads/2018-oem-led-headlights.15733/
    Here are couple of links to them in the store:
    Black housing
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-rh-811100c210
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-lh-811500c210
    Chrome housing
    https://parts.toyotaofcoolsprings.c...mbly-right-hand-led-chrome-housing-811100c140
    https://parts.toyotaofcoolsprings.c...embly-left-hand-led-chrome-housing-811500c140
  3. Nov 24, 2017 at 8:47 AM
    #333
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Order headlights from Roman: Toyota of Cool Springs, He has the best pricing on them.
    tinyt1553 and rarce19 like this.
  4. Nov 24, 2017 at 8:52 AM
    #334
    Vector W8
    Hi Eledobleu,
    I have a quick question for your regarding the tap. For those of us who have a Supercharger on our truck this fues is already being tapped in to for triggering the water pump for the supercharger. Is there another location that can be tapped in to under the hood so we don't overload this fuse?
  5. Nov 24, 2017 at 9:09 AM
    #335
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
    With a test light and ignition on Check the other fuses and see what fuse gets 12 volts with ignition on and off with ignition off and you can use that location.
  6. Nov 24, 2017 at 9:11 AM
    #336
    Retched1
    Retched1 New Member
    Aaron
    2017 Tundra Sr5 CrewMax
    Go ahead and pull the supercharger off, it is incompatible with these headlights... I'll cover shipping to my house to dispose of it for you.
    dradd and tinyt1553 like this.
  7. Nov 24, 2017 at 10:55 AM
    #337
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I have a 2016 crew cab sr5 tss option I would like to know if I can get on list to order needed parts.my lights are all stock so please send price for required harness I would like to upgrade to 2018 tundra headlights and would like to order all needed parts and harnesses. Please send cost and payment info
  8. Nov 24, 2017 at 8:35 PM
    #338
    Vector W8
    Hi Retched1, I took your advice, I pulled off the SC. I only ship with UPS, so I cant guarantee that the SC will actually make it to you, as I have ordered several items from Sears this holiday season only to have smashed boxes with their contents missing show up at my door step. I do applaud UPS though for having the balls to actually leave a box on my door step that only has a invoice and a lot of crappy tape holding the packing material inside the box. They are very quick to leave my property when a box that should weigh 11 lbs only weights about .5lbs.
    Good luck and let me know if it ever shows up at your door step. ;-)
    tinyt1553 and inferno_pro_satx like this.
  9. Nov 26, 2017 at 1:36 AM
    #339
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    2017 White SR5 Crewmax
    Bakflip g2 cover Trd pro grill/bulge Nerf bar steps
    For some reason my turn signal isn’t working. Any ideas? I did not install middle purple wire.
  10. Nov 26, 2017 at 4:12 AM
    #340
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    Never mind looks like I just had a loose pink wire.
  11. Dec 1, 2017 at 2:27 PM
    #341
    DIablo_AD
    DIablo_AD New Member
    Diablo
    2014 double Cab
    Alright, i had an electric guy who work on my 2015 sr5 and he was able to make them work without the harness. Am not really sure what he did but my amber lights are on on DRL. Do i need to get the whole harness kit?
  12. Dec 3, 2017 at 7:54 PM
    #342
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    You need to do the "amber DRL delete mod" to disable the stock DRL. Instructions is in first post
  13. Dec 3, 2017 at 7:57 PM
    #343
    eledobleu
    Orlando, FL
    **Now through New Years Day, Get 20% off Harnesses. Use coupon code "holiday20". **
    inferno_pro_satx and geno0506 like this.
  14. Dec 3, 2017 at 8:14 PM
    #344
    geno0506
    geno0506 New Member
    Michael
    How much for the Harness for a 2017 SR5 CM 4X4, before 20% code!
  15. Dec 3, 2017 at 8:19 PM
    #345
    eledobleu
    Orlando, FL
    $230. With coupon $184 with free shipping.
    geno0506[QUOTED] likes this.
  16. Dec 3, 2017 at 8:20 PM
    #346
    geno0506
    geno0506 New Member
    Michael
    Thanks,
    I will read your starting post in the tread, but do I need to buy the MotoControl from that store!
  17. Dec 3, 2017 at 8:22 PM
    #347
    eledobleu
    Orlando, FL
    Everything is included. You dont need to buy anything else.
  18. Dec 3, 2017 at 8:29 PM
    #348
    geno0506
    geno0506 New Member
    Michael
    Cheers :cheers: PM'D
  19. Dec 7, 2017 at 11:44 PM
    #349
    Trevman2
    Trevman2 New Member
    What is the current wait time for 2015 Platinum harness? I just hit a deer earlier this week and my truck is in the body shop. I'm going to upgrade to the 2018 lights but I don't have much time.
  20. Dec 10, 2017 at 9:54 AM
    #350
    rarce19
    rarce19 New Member
    Socal
    I’m about to start installing my headlights. Mind sharing the video?
  21. Dec 10, 2017 at 10:48 AM
    #351
    tinyt1553
    tinyt1553 New Member
    Tom
    Cypress, TX
    2017 1794 CM - Magnetic Gray
    Exterior: POP & Lock Power Tailgate lock BakFlip MX4 Tonneau Cover Rhino Bed Liner Swapped OEM Halogen Fogs with Formula-J87 LED 6000k bulbs Rough Country 60" Tailgate LED lightbar 6" rubber stub antenna Interior: Front Emblem Camera with anytime backup cam, Crux Vimty-05 for Vehicle in Motion Override Center console wireless charging Verizon Hotspot in center console Chromecast to OEM head-unit display ESP Rear Seat 3 Compartment Storage 5% Ceramic tint on rear window and rear doors 18% Ceramic tint on front doors Weathertech rear seat cover (try to take Hank (boxer/pointer mix) with me everywhere I can) In The Works: Upgrade to 2018 OEM LED Headlights VLEDs throughout the rear (turns, brakes, highmount 3rd brake and cargo) GRT Lighting LED's to replace all interior bulbs Future Wishlist: Swap OEM Head-unit with Kenwood DNX994S and use iDataLink Maestro RR to integrate OEM backup cam, OEM USBs, OEM Aux input, etc AMP-Research Power Sidesteps Train (air) horn
    20171210_125216.jpg 20171210_125142.jpg Just finished my install, took about 3 hours, went slow plugged everything in, made sure it worked, disconnected everything, mounted the morimoto relay, set the wires in place, cable tied everything, reconnected all of it, and reassembled the truck! Lol went to take some pictures with my Samsung Galaxy Note8 and thought something was wrong, then I remembered that the Note8 has 2 rear cameras, seems they cycle during live view making it look like the leds are in a chasing pattern (see video). Switched to single view and everything looks great. Thank you @Roman for getting me the leds so quickly and @eledobleu for the harnesses, made everything so easy. https://youtu.be/IBMOG229-0w
    Roman and geno0506 like this.
  22. Dec 10, 2017 at 11:36 AM
    #352
    geno0506
    geno0506 New Member
    Michael
    Glad they came out good. Lmao on the chasers I would have been dumbfounded if I saw that. :rofl:
    tinyt1553[QUOTED] likes this.
  23. Dec 10, 2017 at 1:21 PM
    #353
    rarce19
    rarce19 New Member
    Socal
    My fuse tap connector came undone some how as I took it out from packaging. Anyone know how to fix. Can’t seem to keep it locked.
  24. Dec 11, 2017 at 3:21 PM
    #354
    eledobleu
    Orlando, FL
    you can open the hole on the fuse tap using a flat head screwdriver, strip the yellow wire and recrimp.
  25. Dec 11, 2017 at 5:33 PM
    #355
    sohcenrubbish
    sohcenrubbish New Member
    Toby
    Wondering the same thing! Any luck with this?
  26. Dec 11, 2017 at 5:41 PM
    #356
    eledobleu
    Orlando, FL
    Any fuse tap thats on when ignition is on. Most accessories like the cig lighters can be used.
  27. Dec 11, 2017 at 7:23 PM
    #357
    sohcenrubbish
    Toby
    Sorry, kind of new to this, but does this mean I have to run the fuse tap into the fuse box in the cab because I don’t see the fuse tap for the cig lighter in the fuse box in the engine bay.
  28. Dec 12, 2017 at 5:29 PM
    #358
    rarce19
    rarce19 New Member
    Socal
    So it’s been 2 days since I installed my headlights. Today the driver side turn signal began to hyper blink. Any idea what could be causing this? It worked fine until now
  29. Dec 12, 2017 at 6:31 PM
    #359
    eledobleu
    Orlando, FL
    If you re-pinned correctly there will be no hyper blink. If re-pin was correct, you could have a blown bulb.
  30. Dec 12, 2017 at 6:45 PM
    #360
    rarce19
    rarce19 New Member
    Socal
    Just got a chance to take a look and the cause was that the plug was loose. Perhaps during the re-pin the inside tab may have cracked.
