2018 LED Headlight PNP Wire Harness Sales Thread (eledobleu)
Discussion in 'EleDobleU's Retrofits' started by eledobleu, Sep 29, 2017.
  1. Sep 29, 2017 at 10:57 AM
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    **HARNESS UPDATE** (https://www.tundras.com/threads/updated-2018-pnp-conversion-harness-no-repin-lower-price.24037/)
    Thanks to @thomasbus337 , I will begin producing the wire harnesses for 2018 Tundra LED Headlights. These will be PNP via Morimoto Relay harness. The only exception is with the stock turn signal harness. As thomasbus337 mention, the pins on the harness has to be switched around in order for them to work with the new turn signal bulb socket
    Harnesses can now be ordered directly from my website (http://retrofitwholesale.com/product/pnp-conversion-harness/)
    Use coupon code "tundras10" for 10% off!
    The harnesses will include the following depending on trim models:
    SR, SR5, TRD PRO, Limited
    • Morimoto H4 Relay Harness (for High/low beam fuction)
    • Conversion harness (to fit on H4 Relay)
    • PNP LED harness (for DRL via ignition fuse *high power/bright mode all the time*)
    **DRL DELETE MOD REQUIRED**
    1974, Platinum
    • DRL conversion harness (with stock high/dim function)
    I will begin accepting orders once parts arrive. They will begin selling between 1-2 weeks. These harnesses will be exclusive to Tundras.com members only!
    Harnesses are warrantied for 3 years
    Email me at eledobleuretrofits@gmail.com for questions and to order.
    ***I made the harnesses as simple as possible. ***
    1 (white conversion) Harness for each Light (Driver/Passenger)
    1 DRL PNP Harness with fuse tap
    1 MotoControl Harness
    INSTALLATION INSTRUCTIONS:
    1. Low Beam (Red/Black)> Ballast (On Relay Harness)
    2. High Beam (White)> High Beam
    3. LED (Green)> DRL Harness (Driver/Passenger)
    4. Fuse Tap (DRL Harness)> Ignition Fuse in fuse box (Engine Bay). Remove Old Ignition fuse (IGN) and replace with fuse tap.
    5. Done.
    Headlights Removal Video https://www.youtube.com/watch?v=qOgOFHcWYOk
    RE-PINNING OF STOCK TURN SIGNAL HARNESS (REQUIRED)
    Thanks you @thomasbus337 , here is his guide on how to re-pin the stock turn signal harness for them to be functional with new 2018 turn signal bulbs.
    DRL DELETE MOD
    1. Location flasher relay(J29) inside cab. It is located behind the panel where the mirror controls and level adjuster are.
    2. Cut the small gray wire on the flasher relay (Left side of relay. NOT BIG GRAY WIRE ON RIGHT SIDE SHOWN IN PICTURE)
    FUSE TAP INSTALL FOR DRL (NONE PLATINUM/1974)
    THERE IS NO GROUND ON THE PNP DRL HARNESS FOR 2018 LED HEADLIGHTS. SO IGNORE THE GROUND IN THE PHOTO
    JoshuaA, JRPro, X09 and 14 others like this.
  2. Sep 29, 2017 at 11:25 AM
    BayRunner
    BayRunner New Member
    2017 Tundra Platinum
    Good to hear. Patiently waiting...
  3. Sep 29, 2017 at 2:45 PM
    phm14
    phm14 New Member
    Peter
    '18 SR5+ 5.7L 4x4 Double Cab
    Bilstein 6112s, TRD exhaust, 285/65-18 on 18x9 +18
    I have a 2018 SR5 that came with standard headlights. Do I need the harness to upgrade to the OEM LEDs?
  4. Sep 29, 2017 at 4:25 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    2015 Tundra SR5, 5.7, 4X4
    Tow Mirrors, 275/60R20 Toyo AT2's
  5. Sep 29, 2017 at 4:36 PM
    boloson
    boloson New Member
    @eledobleu when do u think you'll have the 2018 vs mled comparison pics? Thanks
  6. Sep 29, 2017 at 4:37 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    @phm14 do you have pics of the standard 2018 headlights?
    Jsena likes this.
  7. Sep 29, 2017 at 6:45 PM
    eledobleu
    Orlando, FL
    Yes, if you have the standard lights and want to upgrade to the LED headlights you will need the harness.
    I will have light output pics of the 2018 headlights sometime next week. Soon to follow will be the MLED. So hopefully within the next two weeks. I will compare the Profile LED's as well as they seem to be a much cheaper option while still bring really bright.
  8. Sep 29, 2017 at 8:23 PM
    Tophergt99
    Tophergt99 Back in black
    Weston, Wisconsin
    2015 SR5 Black TRD Crewmax
    In progress....
    What will the price be if I have a motocontrol already for an sr5.
  9. Sep 29, 2017 at 10:47 PM
    Mariobejar831
    Mariobejar831 New Member
    I will take one for an sr5.:thumbsup:
  10. Sep 30, 2017 at 8:49 AM
    eledobleu
    Orlando, FL
    It would be $180 for SR5 if you have the morimoto h4 harness.
  11. Sep 30, 2017 at 8:52 AM
    Tophergt99
    Weston, Wisconsin
    In progress....
    Ok, yes I have a Morimoto H4 HID kit.
  12. Sep 30, 2017 at 9:22 AM
    eledobleu
    Orlando, FL
    Ok just remind me once you are ready to place an order
  13. Sep 30, 2017 at 10:36 AM
    eledobleu
    Orlando, FL
    So everyone will know, I will be making about 10 harnesses within the next 2 weeks. Mid to late October, stock will increase to around 50.
    DavidB, Lilly and zwillz like this.
  14. Sep 30, 2017 at 10:55 AM
    JonChambers
    JonChambers New Member
    Jon
    2015 Tundra CM
    What’s your turn around time if I order today? Just found out my lights will be in mid next week so I either need to get stuff to make one or order from you to save me time.
  15. Sep 30, 2017 at 11:00 AM
    Bable985
    Bable985 New Member
    2014 silver sky limited trd
    I’d like a set also for a 14 limited... I’ll send an email
  16. Sep 30, 2017 at 11:50 AM
    eledobleu
    Orlando, FL
    Theres no specific turn around time, as parts arrive, the harnesses will be produced (1-2 weeks). Once parts arrive, I will begin taking orders.
    As a courtesy to other members, if you are still waiting for you 18 lights to arrive, allow the ones who have recieved their lights to order the harness as the first batch will be limited. Like I said, the stock quantity around mid October will be around 50.
    I am taking note as to who's emailing first and will produce the harnesses based on that order.
  17. Sep 30, 2017 at 12:57 PM
    inferno_pro_satx
    inferno_pro_satx New Member
    Roger
    2016 Tundra TRD Pro
  18. Sep 30, 2017 at 3:14 PM
    phm14
    phm14 New Member
    Peter
    Will pm a link to some ASAP.
  19. Sep 30, 2017 at 8:35 PM
    sartod01
    sartod01 New Member
    2017 Black 1794
    Definitely interested...just ordered my lights today!
  20. Sep 30, 2017 at 10:21 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    Me too!!!
  21. Sep 30, 2017 at 10:23 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    I got a 2014 limited, I'm late to this game, so all I need is this PNP harness and the 2018 limited headlights from Roman and I'm good ????
  22. Oct 1, 2017 at 12:07 PM
    phm14
    phm14 New Member
    Peter
  23. Oct 3, 2017 at 9:23 PM
    TrdPro86
    TrdPro86 New Member
    Cheng thao
    2016 Toyota Tundra TRD PRO
    I need a set for my Pro. Pm me thanks
    inferno_pro_satx likes this.
  24. Oct 4, 2017 at 9:20 AM
    eledobleu
    Orlando, FL
    **UPDATE**
    Still waiting for parts for first batch. Hopefully they come by next week. The first 10 on the list will be contacted by email once the harnesses are complete.
    Second batch should be expected by end of October.
  25. Oct 4, 2017 at 10:28 AM
    Snb_Yo
    Snb_Yo New Member
    2015 Trd Pro
    If I’m not late, Put me down for second batch
  26. Oct 4, 2017 at 10:34 AM
    eledobleu
    Orlando, FL
  27. Oct 4, 2017 at 11:04 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  28. Oct 4, 2017 at 1:31 PM
    texbambam
    texbambam New Member
    Tundra TRD PRO sand
    Sign me up...I need one for a PRO my lights are sitting here waiting.
  29. Oct 4, 2017 at 7:25 PM
    Mariobejar831
    Are you going to be putting people in order as they have been contacting you by email?
    First come first serve?
  30. Oct 5, 2017 at 6:50 PM
    eledobleu
    Orlando, FL
    Yes I am!
