2018 OEM LED Headlights
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Aug 21, 2017.
  1. Aug 21, 2017 at 9:43 AM
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    ***EDIT***
    Starting to get a LOT of emails, so I figure I better update the OP in this thread for everyone to include all the information we have currently. Links to both headlights in the store are at the bottom of this post. It will take quite a while to receive them, so expect AT LEAST a few weeks if not longer (most likely longer). Also, no one has produced and started selling a working wire harness to convert your 2014-2017 style headlamps, but I will update this as soon as one is made. I will not have any affiliation with whomever produces this harness, and will assume no responsibility for anything to do with that part. Physically, the LED headlights appear to be the exact same as the older style as far as mounting them, so I don't think we will have any trouble there, BUT I won't know for 100% certain until someone bolts them up. Sorry, but it's the law student in me who has to speak in non-absolutes to cover my rear. :D
    Got one side in over the weekend, so I took some shots to compare the new LED headlamps to the older style headlamps.
    New headlamp
    Old headlamp
    Here are couple of links to them in the store:
    Black housing
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-rh-811100c210
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-headlamp-assy-lh-811500c210
    Chrome housing
    https://parts.toyotaofcoolsprings.c...mbly-right-hand-led-chrome-housing-811100c140
    https://parts.toyotaofcoolsprings.c...embly-left-hand-led-chrome-housing-811500c140
  2. Aug 21, 2017 at 9:44 AM
    Roman
    Roman
    Franklin, TN
    It looks like only the headlamp bulb wiring harness is going to have to be changed in some kind of way.
  3. Aug 21, 2017 at 9:45 AM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
  4. Aug 21, 2017 at 10:02 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    These things are sweet!
    BlueBottle likes this.
  5. Aug 21, 2017 at 10:49 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    You are the man Roman! You know what we want and what we need haha!
    Someone needs to create an adapter harness so there is a plug and play option and Roman can sell a lot of these babies.
    I would assume, only assuming here, there will be input for DRL, low, and high beam in that harness. Tundras like my SR5 without OEM DRL's won't have a factory output for the DRL's so that harness would have to be a bit more custom.
  6. Aug 21, 2017 at 10:53 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Think I'll trade my retrofit in for a set of these once someone works out a plug and play solution
    Mstager, LKSR5-14 and HBdirtbag like this.
  7. Aug 21, 2017 at 10:54 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    now I just need a 3rd gen!
  8. Aug 21, 2017 at 11:24 AM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Those are nice.
  9. Aug 21, 2017 at 12:03 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    but is the output any good?
  10. Aug 21, 2017 at 12:13 PM
    Roman
    Roman
    Franklin, TN
    Another big question. I'll have to wait until we get a new Tundra in to figure that one out.
    SouthBoundSteve likes this.
  11. Aug 21, 2017 at 4:35 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    @Roman can you get the female portion of the headlamp plug? If you can I'm sure @TundraTex can make us a harness! Hint hint! Looks very doable though. Just a matter of figuring out which pin is which on that connector. I'm excited lol.
    Inquiringone and MotoTundra like this.
  12. Aug 21, 2017 at 4:46 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Oh hell gyeah
  13. Aug 21, 2017 at 7:50 PM
    finn
    finn New Member
    Ryan
    Want!
  14. Aug 21, 2017 at 9:35 PM
    TRDpro619
    TRDpro619 Follow My Build on Instagram:TRDorcaTUNDRA
    San Diego
    TRD Pro CM
    Damn all I see is $$$$ signs in my future
    Blueknights75 likes this.
  15. Aug 21, 2017 at 9:39 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Yeah every time I log into tundras.com I see $$$$$$ lol
  16. Aug 22, 2017 at 3:37 AM
    MikeyMTBs
    MikeyMTBs New Member
    Promising. I'll be interested to find out if that headlight ties into the CANBUS system of the 2018 model. If not, it'll be a lot easier to figure out how to make it work.
  17. Aug 22, 2017 at 5:19 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Roman
    Will the leveling motor remain unaffected if swapping these becomes possible?
  18. Aug 22, 2017 at 6:59 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I looked into this a bit. The 2016 electrical wiring diagrams indicate effectivity for vehicles "before Aug. 2017 production". I havent seen the Late 2017 or 2018 diagrams yet, and I'm reading between the lines a little bit here, but I'm wondering if the late 2017 might be wired the same as the 2018 vehicles. Don't know that for sure though.
    Switching control for the 3rd Gen. comes from the Main Body ECU to the Headlight relays. From there it's a straight shot to the headlight assemblies. I'm guessing again, but I think any LED driver circuitry would be contained within the headlight assembly rather than the harness. If my assumptions are true it should be fairly straightforward to create an adapter harness.
    We'll see...
  19. Aug 22, 2017 at 7:05 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    From the pictures, it looks like the motor connector is the same.
    BlueBottle and Tacotundra like this.
  20. Aug 22, 2017 at 7:54 AM
    Roman
    Roman
    Franklin, TN
    Yep, all of the connectors look to be the same, except for the headlight beam itself, of course. I may be able to get the connector from the harness once the EWD for the 2018 becomes available. I'm surprised it isn't out yet, but Toyota recently changed our catalogs again to not include the 2018 parts, so that may have something to do with it.
  21. Aug 22, 2017 at 9:16 AM
    KC7905
    KC7905 New Member
    Ferd'z
    Grey '14 4.6 DC SR5 Limited
    aFe CAI, unichip, Black FUEL 20” wheels, Nitto Terra Grappler G2
    I want one pair when every part needed for the change are available. I'm just wondering what are the tag price for this headlight assemblies so I could start saving some pennies for all of this. @Roman, please update us sooner.
  22. Aug 22, 2017 at 9:19 AM
    Roman
    Roman
    Franklin, TN
    I updated the OP with links to them in the store.
    KC7905[QUOTED] and Tacotundra like this.
  23. Aug 22, 2017 at 9:31 AM
    KC7905
    KC7905 New Member
    Ferd'z
    Thanks Roman for the quick reply, any update on the 2018 grill assembly and its installation, alteration and all that?
  24. Aug 22, 2017 at 9:32 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Roman are the signals led or regular bulbs? Connector looks the same.
  25. Aug 22, 2017 at 10:50 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    These look like OEM may finally be snazzy! :ohsnap:
  26. Aug 22, 2017 at 10:54 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    They could use the same connectors and still be LEDs. Im guessing the headlamp connector is different because the LowBeam and High beam both need their own drivers with their own circuits - which means more pins. In the conventional headlight, the beam elements share a common ground so there are only 3 pins required.
    mdavis likes this.
  27. Aug 22, 2017 at 11:21 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  28. Aug 22, 2017 at 11:33 AM
    SleeperTRDPro
    SleeperTRDPro The small package good things come in
    Austin, Texas
    Just got my bonus at work, I'm ready to place my order!!
  29. Aug 22, 2017 at 11:50 AM
    jdm ctr '00
    jdm ctr '00 New Member
    los Angeles, CA
    2016 Tundra TRD PRO
    Looks great!!! I would swap over as soon as I know it would work. They are dark chrome inside like the Pros, right?
    Flyinryank likes this.
  30. Aug 22, 2017 at 12:46 PM
    Roman
    Roman
    Franklin, TN
    It's hard to see in the pictures, but they do use normal bulbs for turn signal/clearance lights.
