2003 Corolla "Virus"
Discussion in 'Other Toyota Vehicles' started by Tundra2, May 23, 2021.
  1. Nov 13, 2021 at 9:33 AM
    #211
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    I've found either the scissor is binding up or the nylon wheel is worn/broken & popping/popped out of the track. Usually one of those two. Once I found the bolt holding the bottom of a track had come loose letting the whole track wobble, but that was an oddity.
    Tundra2[QUOTED][OP] likes this.
  2. Nov 17, 2021 at 6:06 AM
    #212
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Changed engine oil with filter 200 miles early today because the weather was beautiful. No pics. Most likely last "good" day of the year 2021.
    Also changed downstream oxygen sensor because weather.
    Pre-fab on the extra fouler piece. Went ahead and threw this on because I'm not totally convinced the catalytic converter is bad, but didn't want to waste such a good day for another CEL for the same thing.
    Removed trapped crunchies. Surprisingly felt gnarly, but very little came back on the chaser. No pics of it out.
    Pics of the old sensor. Looks like it has some build up on the seal, and some white soot on the shield for the sensor.
    The only writing this had on it was a big red check mark, and "KAY".
    Not sure what brand this is, but went back in with denso. Part number in first picture of this post.
    Fishing the wire through the floor board, and seating the grommet was the most tedious part of this for me.
    Easy peazy.
    TRDGen likes this.
  3. Nov 18, 2021 at 6:28 AM
    #213
    Tundra2
    Noah
    Western Kentucky
    Happy to report 115 miles with no CEL for the P0420 code. Now if something major does pop a code, I'll notice the light instead of just ignoring it like I was doing.
    NUDRAT likes this.
  4. Nov 24, 2021 at 10:55 PM
    #214
    Tundra2
    Noah
    Western Kentucky
    First big issue with the virus. Drivers side window out of track on my commute into work.
    Pulled into work, and took the door panel off in the parking lot with a pry tool, and my multitool.
    Will be attempting repair immediately after work because I will be the last one out the door. Parking lot should be empty.
    Following along with this video on a matrix
    https://youtu.be/aTcvFOTs0QA
    Looks like two common causes for this are the silicone holding the window mount to the mount breaking, and a bolt falling out of the mount for the window.
    Will be cleaning the window track also, and lubing with Loctite LB 8801 Silicone lubricant found at work from my tool box.
    Hoping it's just a bolt that had fallen out of the window, and I can replace after cleaning window track, and lubing. If so, 90 in.lb thread lock will be going in with the new/old bolt.
    More to come on my el-cheapo repair.
    The story so far as it has unfolded can be found on the Best Gen lunchtable thread here. More posts below that by me. Just click the arrows to follow along.
  5. Nov 24, 2021 at 11:43 PM
    #215
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    97% of the time it’s the bolt.
    Tundra2[OP] likes this.
  6. Nov 25, 2021 at 3:12 AM
    #216
    Tundra2
    Noah
    Western Kentucky
    I can't get a good picture of it, but the scissor is bent inside the door. Not sure if I Cann just straighten it out, and get by or if I need to replace the one piece that's bent.
    Leaning towards bending back straight if I can get my Goliath hands up in there.
  7. Nov 25, 2021 at 4:21 AM
    #217
    Tundra2
    Noah
    Western Kentucky
    Drove home sitting sideways using my body to block the rain from the seats, and interior as much as possible.
    Walked down to the ten of pain, and saw that the wind has flipped it on its roof. :eek2: Tried to flip, and it was way too heavy for me with leaves, and constant rain.
    Went inside, and gathered old shower curtain. Stuffed under the windshield wiper, the light bar mount, and added another magnet to it.
    Formulated a plan coming home. Take the speaker out. Opens up hand room. Find something to use as a spacer/bend point such as a 1x1 wood block, and tie a rope to the end of the arm that's bent. Hold spacer and have someone else pull the rope until straight. Hoping that the wheel in the scissor track doesn't come out.
    Unsure of how that will go, but also unsure of cost just to replace regulator or tracks. Or even the correct terminology here.
  8. Nov 25, 2021 at 6:54 AM
    #218
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    if you ever feel like you need to build a giant boat, im willing to come help. You called it.
  9. Nov 25, 2021 at 9:29 AM
    #219
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Perhaps, remove glass, extract scissor from door, bend in a warm space?
    I'm thinking bending in door will stain the wheels at the track, potentially snapping a wheel off or bending the wheel fastener so it always drags in the track.
  10. Nov 25, 2021 at 6:08 PM
    #220
    Tundra2
    Noah
    Western Kentucky
    And it was absolutely the worst weather day it could have happened on.
    Found a new regulator on RA. Will order a new one if I can't bend the old arm straight. Been cold, and pissy all day. Will drive the V6 the next coming days, and try to mend it soon...
    Been resting my body. Happy turkey day.
    NUDRAT likes this.
  11. Nov 27, 2021 at 12:21 AM
    #221
    Tundra2
    Noah
    Western Kentucky
    Directory added, and updated to my liking on the first post. May edit later.
  12. Dec 3, 2021 at 2:11 PM
    #222
    Tundra2
    Noah
    Western Kentucky
    The corolla Virus hath returned. Bruce continues to win my business!
    That window has never been this shmoooov!
    NUDRAT likes this.
  13. Dec 17, 2021 at 2:50 PM
    #223
    Tundra2
    Noah
    Western Kentucky
    146,123 miles!
    New shoes today. Very pleased with the price. Hope they last because I'm gonna rack the up some fuckin Mike's with these bad boys!
    Need better pictures...
    NUDRAT likes this.
  14. Dec 22, 2021 at 5:47 PM
    #224
    Tundra2
    Noah
    Western Kentucky
    Just discovered unleaded 88 petrol in my home town. 15% ethanol verus the 10% in regular unleaded. A few cents cheaper than reg gas.
    The placard says flex fuel vehicles, and also 2001 and newer. Did not fill up with this because I was unsure, but could I run this?
    I'm enticed by the cheaper cost, but is it worth it or can I even run it? Unsure. Figured I'd ask.
    Thrown for a loop!
  15. Dec 22, 2021 at 6:03 PM
    #225
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    It's a virus after all ....
  16. Dec 22, 2021 at 7:14 PM
    #226
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I've seen this in other states but not around here. Always wondered why it was cheaper but the extra ethanol makes sense.
    Owners manual should say the maximum ethanol content. Some newer toyotas say it on the factory gas cap.
  17. Dec 23, 2021 at 6:40 AM
    #227
    Tundra2
    Noah
    Western Kentucky
  18. Dec 23, 2021 at 6:58 AM
    #228
    empty_lord
    05 rollover special
  19. Dec 30, 2021 at 3:07 AM
    #229
    Tundra2
    Noah
    Western Kentucky
    CEL this AM. I don't have my code reader with me, so not sure if it's minor or major. Light isn't flashing so I'm gonna run it till I get home.
    Maybe it will turnover when I get off work. Lol
  20. Dec 30, 2021 at 6:22 PM
    #230
    Tundra2
    Noah
    Western Kentucky
    I think I will start with a gas cap, and if that doesn't fix it then oh well lol
  21. Jan 17, 2022 at 6:26 AM
    #231
    Tundra2
    Noah
    Western Kentucky
  22. Jan 17, 2022 at 6:40 AM
    #232
    Redcon41318
    Redcon41318 New Member
    I miss my 04’ corolla, use to get 40mpgs, 30mpgs all day.
  23. Jan 27, 2022 at 5:59 AM
    #233
    Tundra2
    Noah
    Western Kentucky
    Almost had some clobberin time this AM.
    Can you see the deer in this next one?
    Let me zoom in for you.
    Damn good color match I tell you hwat...
    Brownsfanhere likes this.
  24. Jan 27, 2022 at 6:19 AM
    #234
    All I see is jerky waiting to happen.
  25. Jan 28, 2022 at 4:55 AM
    #235
    Tundra2
    Noah
    Western Kentucky
    Finally broke over 300 miles to a tank on thus new commute. Official number was 330.9 miles. An average of just under 30mpg. Still learning this new route.
    Driving on the interstate means I'm keeping up with traffic longer, and running the engine harder than I did when I was commuting on 2-lanes.
    Usually for the first 51 miles of my commute I can control my speed. Seems like if I keep it under 65mph is when my mpgs are greatest.
    The remaining 18-ish miles of my commute is like driving in madmax. Constantly fighting other drivers for my place on the road. This really cuts into my mpgs. There isn't really an alternate way I could go unless I moved.
    Kinda toughing out with the car right now
  26. Jan 28, 2022 at 5:02 AM
    #236
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Take a spot in the right lane and let it eat. I like to cruise 8-10 lengths behind an 18 wheeler, anyone that merges in front of me quickly moves. And you dont have to pit anyone.
  27. Jan 28, 2022 at 5:08 AM
    #237
    Tundra2
    Noah
    Western Kentucky
    Also, for accurate information, and a better picture of real world conditions. Sometimes working nights there will be frost on the car when I get off work so I have to let it warm up so I can see to drive. That's been happening a lot lately even if I crack all four windows.
    Not really sure how often or how long until I decide that I can see enough to drive. Changes every time that happens. Anyways, what I'm getting at here is that there is some fuel use while not in motion.
  28. Jan 28, 2022 at 6:12 AM
    #238
    NickB_01TRD
    Nick
    KY
    I just keep an ice scraper. Start the car turn on rear defrost scrape and roll out as soon as I'm back in.
  29. Jan 28, 2022 at 5:44 PM
    #239
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    0 gallons per hour.
  30. Jan 29, 2022 at 12:42 PM
    #240
    Tundra2
    Noah
    Western Kentucky
    Starting to think there's something else wrong with the corolla. A third of a tank should have gone more than 80 miles... really sucking it down.
    Hmm
    NUDRAT likes this.
