04 Sequoia’s 150 amp Alternator Swap on a 00 Tundra + The 3 Big upgrades
Discussion in '1st Gen Tundras (2000-2006)' started by joseph_sal, May 14, 2020.
  1. Aug 28, 2021 at 4:59 PM
    daveeasa
    David
    What about batteries? Can we fit a group 31 in? And then do we have to do some diode hack to get proper charging voltage?
  2. Aug 28, 2021 at 5:03 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    For the proper charge voltage on an AGM yes you’ll need a diode. But you have to order the one crash has linked on TW. Then GM diode won’t fit our trucks
  3. Aug 28, 2021 at 5:09 PM
    daveeasa
    David
    Thanks. And max battery size we can fit?
  4. Aug 28, 2021 at 5:13 PM
    empty_lord
    05 rollover special
    27f for sure. Maybe a 31? Honestly I’d do a 27f and a second remote mounted battery
    FrenchToasty likes this.
  5. Aug 28, 2021 at 5:21 PM
    daveeasa
    David
    Just so much extra headache going dual battery though. Maybe I’ll try a 31 and swap to the Taco if it doesn’t fit decently well.
  6. Aug 28, 2021 at 5:23 PM
    empty_lord
    05 rollover special
    That extra weight on the apron like that leads to cracks. That’s the only reason I’m hesitant
  7. Oct 24, 2021 at 12:40 PM
    shifty` Oh, I have felt Cobain's sarcoma
    Won't fit earlier model (00-02) Tundra? Or all 1st gen? This person (26239) claims to be using it, they show an '05 in their profile. "This is the part number for that GM diode. 12135037" is what they mentioned further down the thread.
  8. Oct 24, 2021 at 1:19 PM
    empty_lord
    05 rollover special
    The GM diode I had would not fit my 05. It fit my Avalon with the micro fuses. Apparently there’s a Ford part that works in the mini fuse slots
  9. Oct 24, 2021 at 1:26 PM
    daveeasa
    David
  10. Oct 24, 2021 at 2:57 PM
    Well, for $6.42 shipped from RockAuto, I'm going to test on my truck. Your truck doesn't use microfuse for the S-Alt? The part number @Thrussn listed appears mini-fuse sized.
    Receipt is below, but this is the part I bought from RockAuto (listing shown is from GM Parts Giant):
    And this is my receipt, shipping was about the same as the part, around $2.95 average.
    daveeasa likes this.
  11. Oct 24, 2021 at 3:14 PM
    And don't ask me why it's called "A/C Compressor Clutch Coil Connector" at RockAuto. Seems different sites list it as different things.
    I suspect this is probably used in more than one way in GM vehicles, generally serving as a diode.
    I'm wondering if it provides any safety features like the Australian unit, though.
  12. Oct 24, 2021 at 3:29 PM
    empty_lord
    05 rollover special
    Yea my truck is full of mini fuses not micros.
  13. Oct 24, 2021 at 3:35 PM
    Mine is mini also. I think the GM part above is mini size?
  14. Oct 24, 2021 at 3:41 PM
    empty_lord
    05 rollover special
    May be. I have a feeling there’s a few different types
  15. Oct 24, 2021 at 5:38 PM
    daveeasa
    David
    Please do let me know how it goes.
  16. Dec 26, 2021 at 7:44 PM
    daveeasa
    David
    Given the alternator swap, should we also upgrade our alternator fuse to 150 amp?
    Tundra2 likes this.
  17. Aug 21, 2022 at 6:18 PM
    Mercticated
    Mercticated New Member
    Jody
    2000 Toyota Tundra 4.7 V8
    Thank you very much for this detailed write-up! saved my bacon today. I was in need of an alternator and went to pick n pull to grab one off 03' Sequoia and didn't realize it was different till I saw the square plug So since I already had it off I googled it at the scrap yard and found your post! Woohoooooo! Took the thing home for $30....de-pinned my connector and did the swap and now I'm all set! Thanks again. My 00' Tundra is alive and well again lol
    Jack87, N84434, des2mtn and 4 others like this.
  18. Aug 21, 2022 at 6:33 PM
    Cool! Now stick around and hang out. Not only is there good info, there's also some good folks hanging around.
    Jack87 likes this.
  19. Aug 21, 2022 at 6:59 PM
    #49
    empty_lord
    05 rollover special
    so technically no.. the fuse in the fuse block is to protect the bus bar in said block. if you do a big 3 and run straight to the battery a larger than 150 amp fuse would be ideal for the one to said battery
    shifty` likes this.
  20. Aug 21, 2022 at 7:22 PM
    #50
    daveeasa
    David
    I did 140 recently. Haven't finished the big 3, Jason should hopefully have the cables somewhere, it's been a loooooooong time.
  21. Aug 21, 2022 at 7:24 PM
    #51
    empty_lord
    05 rollover special
    i still havent had time to run my big wires. hell im just now getting to the horns. shortened the harness you made today. still need to do the trigger wire though. soon.
  22. Aug 21, 2022 at 7:32 PM
    #52
    daveeasa
    David
    What I wouldn't give to be sonic, man. That guy can get s done in no time at all.
  23. Oct 24, 2022 at 5:59 PM
    #53
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I know that PHM is no longer with us... or is he? :tinfoilhat:
    Anyways, @shifty` @empty_lord and @daveeasa helped me look for these part numbers to add the "third stud" to the 2000-2002 engine block for the third ear on the 150 amp alternator. Meaning this becomes more of a bolt on upgrade eliminating the need to cut the third ear off. Posts begin here, with pictures I stole from youboob here, and continue on to my order post.
    As of THIS post, the part numbers below are unconfirmed, but I'll update once the nut, and the bolt get here.
    Toyota part numbers below.
    Nut Flange: 90178-A0089
    Bolt: 90068-04019
    This is a link to the square connector that you'll need to re-pin from your old oval plug. Link courtesy of @daveeasa which he supplied on my crackhead thread, here.
  24. Nov 19, 2022 at 5:29 PM
    #54
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    So, the parts came in. The nut was correct, but the stud was wrong. I have no idea what this is for, but here's my "unwrapping" post showing each part. @des2mtn thinks that the stud is for a Sienna.
    Thanks to @assassin10000... we now have the correct part number for that stud. Here's his post where the below image came.
    So the Part numbers you'll need for the stud are 90109-08298, and the nut is 90178-A0089.
    I was able to lop the third ear off, and install my 100 amp newer alternator anyways today. Here's my post about it. Again, huge thanks to @shifty` for gifting me his cracked alternator for crackie!. Merry Christmas to y'all! :santa2:
    I'm glad to be rid of the flickering interior lights!
    robabeatle and shifty` like this.
  25. Feb 5, 2023 at 5:55 AM
    #55
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Stock connection in my 2002 AC from the battery to the frame is right next to the battery. Any reason to choose another spot. Also, best ground spot on engine?
  26. May 24, 2023 at 4:04 PM
    #56
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Noah, if those parts were correct, why did you end up cutting the ear off? I'm in the same boat as you with my 02 and @daveeasa is encouraging me to upgrade to the big boy 150A.
    bmf4069 and daveeasa like this.
  27. May 24, 2023 at 5:26 PM
    #57
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The parts that I ordered initially were incorrect. I installed only using the two mounting points
  28. May 24, 2023 at 7:17 PM
    #58
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So if I order the correct parts I can avoid having the cut off the 3rd ear?
  29. May 24, 2023 at 8:19 PM
    #59
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yes.
  30. May 24, 2023 at 8:20 PM
    #60
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @FirstGenVol these are correct. I thought in the earlier quote from you that you quoted my first, initial post.
    Caught myself skimming. Shiiiet
    FirstGenVol likes this.
