Found my 1st Gen!
Discussion in '1st Gen Tundras (2000-2006)' started by B_Pilgrim, Aug 27, 2025 at 9:43 AM.
  1. Aug 30, 2025 at 9:19 AM
    #91
    B_Pilgrim
    B_Pilgrim [OP] New Member
    Aaron
    I kinda feel like it's going to get worse from here and not better. As more and more people realize how poorly made new vehicles are, and perhaps more importantly, as more and more people realize they really can't afford new vehicles, it's going to put more pressure on the used market.
    I could be wrong of course but everyday I see new stories about catastrophic failures in new vehicles under 30,000 miles. Yesterday saw where a 2025 4Runner had to have a new transmission after only 1,500 miles!
    That and the fact that rates for delinquency on car payments have surpassed what we saw during the 2008/09 crash. I love how that used to be referred to as the Great Financial Crisis and between Covid and what we're looking at over these next years, it doesn't seem so great anymore. Kinda like how it WWI used to be The Great War or The War To End All Wars and now it's just the first in a non-stop string of conflict over the past century. Yay for progress!
    G_unit3000 likes this.
  2. Aug 30, 2025 at 5:05 PM
    #92
    Trueno
    Trueno New Member
    Will
    2006 Sr5 Dbl Cab
    more pressure on the used market means more demand which means less inventory which means higher prices….back to CovID.
  3. Aug 30, 2025 at 7:40 PM
    #93
    B_Pilgrim
    Aaron
    @shifty`
    My truck comes with the base stereo. Are there additional speaker locations on the jbl trucks or is it just extra tweeters in same locations?
    If I want to get maximum benefit out of a head unit and speaker replacement, do I need parts from a truck sold with JBL? Door cards, speaker grills, speaker brackets?
  4. Aug 30, 2025 at 10:42 PM
    #94
    ps8820
    ps8820 New Member
    joe
    06 SR5 AC 2WD V8 CaptainsSeats
    Freshly Killed Piezo Buzzr!, Re-paint 04-2025
  5. Aug 31, 2025 at 5:13 AM
    #95
    I cannot answer your questions easily, not enough info. Are we talking about DC trucks or RC trucks or AC trucks? It makes a huuuge difference here.
    if you don’t have JBL, then you’ll have different wiring than the JBL system. You won’t just be plugging OEM JBL stuff in, and it will work on a truck that didn’t come with JBL.
  6. Aug 31, 2025 at 6:04 AM
    #96
    B_Pilgrim
    Aaron
    05 DC
  7. Aug 31, 2025 at 6:19 AM
    #97
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    If you plan on hanging out here for a while I would recommend putting this information in your profile bruh. Makes life just a bit easier for everyone :rolleyes:
    The Black Mamba likes this.
  8. Aug 31, 2025 at 6:21 AM
    #98
    B_Pilgrim
    Aaron
    For sure, will do. I'm just going to buy truck today
  9. Aug 31, 2025 at 6:25 AM
    #99
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    OH, that's right, you haven't tagged it and bagged it yet!
    Good luck, safe travels :thumbsup:
  10. Aug 31, 2025 at 8:42 AM
    #100
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    Honestly in my opinion, a NON JBL truck is easier to do a stereo in. Less hassle, less work, less money.
    Buy a head unit, buy the standard Toyota wiring harness, and replace door speakers and voila'
    The JBL equipped trucks are a lot more money, or time, depending on which way you go. Deleting the factory amp, or using a massive harness to keep it, both take more time and money. Also the JBL amps start clipping when you push them hard and get static in them when you get them hot after driving them hard. If you want a good sounding stereo the base model stuff without JBL is the easiest place to start and the least amount of work. The aftermarket radios of these days put out more power than the 20+ year old JBL stuff anyway.
    Chris948 and G_unit3000 like this.
  11. Aug 31, 2025 at 8:58 AM
    #101
    ChattanoogaPhil
    ChattanoogaPhil New Member
    2000 4.7 AC SR5 4wd
    The factory unit sounds fine to me for a truck radio. Preferable to the head-thumping vehicle-shaking noise that sometimes pulls up next to me at a traffic light.
  12. Aug 31, 2025 at 9:45 AM
    #102
    Long story short, bullets for brevity on the DC trucks:
    • You need to know if you have JBL or non-JBL ..... JBL trucks always have 8-speaker, non-JBL are (almost always?) 6-speaker
    • If non-JBL, you need to know if you have an amp or not, it would be behind the back seat panel (driver side back wall)
    • For all non-JBL DC, you have two front door speakers wired off the same channel (parallel), one tweeter in the sail panel (the rear view mirror triangle panel on inside) and one woofer in the lower door all wired to the same front channel, there's also one speaker in the rear door on its own front channel (2 channels total, per side)
    • For all JBL DC, there's 8 speakers, 6 in the front door (the woofer is 2ohm and on its own channel, while the tweeter and 2" speaker are 4ohm but wired in parallel to create a 2ohm load on its own front channel), and the rear door speaker is 2ohm on its own channel (3 channels total, per side)
    • The sail panel tweeter setup is the same for all DC, aftermarket tweeter mounting option example here, note that the pushpin that locks the panel in place likes to get stupid, either the receiver is shit, or the post on the sail panel is shit
    • For the lower-front-door speaker location, you can technically bolt the 2-speaker housing from the JBL system into non-JBL trucks if you *really* wanted to add another 2" spealer into the mix, but you'd need to adapt the wiring
    • The actual woofer speaker opening in the lower door and the rear is more suited to a 6¾-7" driver, while Crutchfield will likely tell you it's a 6½", you can go larger than that, up to 7"
    • Ideal situation, whether you're JBL or non-JBL (IMHO) is to bypass the OEM amp fully. But note, OEM JBL owners, your speakers are 2ohm and need to be updated if you use the Metra amp bypass harness, to avoid overloading your head unit
    Speaker upgrade-wise:
    • Note my last bullet in the section above regarding speakers on the JBL systems
    • I'll always recommend going aftermarket on your speakers, regardless which system you have
    • For ease of install and quality of sound, on the front doors, I'll always recommend buying a matched component system, i.e. a woofer/tweeter pair that uses a crossover, and I prefer JBL for this purpose, then install coaxial or triaxial speaker in the rear door. I recommend this because it's easier to adapt the front doors to use only one channel (two wires, one +/- pair, which will be used to feed the crossover on each door)
      • For non-JBL/6spk: You'll grab the pair to feed your crossover via the purple/pink wires on driver side using a Metra speaker adapter, and blue/green on the right using a Metra speaker adapter (I believe it'll be Metra 72-8104). I think the rear doors use Metra 72-9301.
      • For JBL/8spk: I think the rear doors use Metra 72-9301. For the front, ideally you want to delete the woofer out of the mix, and intercept your two crossover feed wires one of two ways:
        • More-invasive: You'll grab the pair to feed your crossover by cutting the purple/pink wires on driver side (purple is negative), and blue/green on the passenger side (blue is negative). LIKE THIS EXAMPLE FOR PASSENGER SIDE (colors will change on driver side!). See THIS REPLY for more details.
        • Less-invasive: Go up to the tweeter, and trace its green/black wires down to the white/beige connector; unravel the tape lump above the connector to reveal a green/black loopback wires (6 total wires, going into 4 holes) You'll cut the green/black wires at the tweeter terminals, then cut the loop wires at the white/beige connector, re-tape the cut wires near the connector, and use the green wires to feed your crossover. See THIS REPLY for more details. I prefer the "MORE INVASIVE" method
        • From there, you'll use the four respective wires coming off your crossover, and route those to your tweeter and woofer (disconnect any existing speaker wires on the back of the woofer/tweeter and tuck away)
    • If using the Metra amp bypass harness, if using the methods I just provided above above, you'll be wiring the bypass harness to your radio using the following setup, matching the purple/white/grey/green pairs to the radio, and ignoring the other 8 wires
    • DO NOT USE THE FOLLOWING DIAGRAM FOR ANY OTHER INSTALL PURPOSE, BECAUSE THE WOOFERS WON'T GET SOUND UNLESS YOU USE THE WIRING INSTRUCTIONS ABOVE!!
  13. Sep 1, 2025 at 1:00 PM
    #103
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    So...
    EyeSpyA1stGenTundra and BroHon like this.
  14. Sep 1, 2025 at 2:39 PM
    #104
    ps8820
    ps8820 New Member
    joe
    yeah,...suspense getting to me.
    Gotta think yes, since once acquisition is complete, he's likely cruising it around on tour...I would be!
  15. Sep 2, 2025 at 5:21 AM
    #105
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    Deadbeats.
    Our latest model vehicle is a very nice garage kept a 2010 Lexus RX350 with 100k miles that the wife recently purchased from a friend for $9k cash. $900/mo car payments for seven years won't help us sleep better at night.
    BroHon likes this.
  16. Sep 2, 2025 at 5:31 AM
    #106
    Well shit, I was hoping to find a correlation here, but no dice.
    BroHon likes this.
  17. Sep 2, 2025 at 5:36 AM
    #107
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    OldGuy03 and shifty`[QUOTED] like this.
  18. Sep 2, 2025 at 7:22 AM
    #108
    EyeSpyA1stGenTundra
    EyeSpyA1stGenTundra New Member
    Eric
    Looking for my future 1st Gen Tundra
    Insert Nic Cage .gif Con Air getting off plane wind in his hair smiling smelling the fresh air
  19. Sep 2, 2025 at 7:25 AM
    #109
  20. Sep 2, 2025 at 7:26 AM
    #110
    Try searching for “poorest” or “most socioeconomically disadvantaged” states. It’ll probably be those ones in the first graph.
    OldGuy03 likes this.
  21. Sep 2, 2025 at 7:30 AM
    #111
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    The data in that study is not surprising at all. The youth of Gen Z and their desire to just have Insta-income, instead of a steady job, isn't panning out so well for the bulk of the generation.
    BroHon and The Black Mamba like this.
  22. Sep 2, 2025 at 7:43 AM
    #112
    Nearly as close, but not quite a match. Interestingly, although not surprising, 9 of the top 10 most-disadvantaged areas are in Mississippi (MP) and South Dakota (SA). The one outlier in the top 10 is in Lousiana (LS).
  23. Sep 2, 2025 at 7:49 AM
    #113
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    I agree. There's a ton of reasons but the overriding IMO is living above a person's means or otherwise on the edge paycheck to paycheck where nothing unexpected can occur with health, job or whatever, else face economic catastrophe within a few weeks.
    That said, the automobile landscape has changed quite a bit. It used to be that a young guy could buy a clunker for under a $1,000 and it was simple enough to work on in the driveway when required. Not so much today.
    In any event, if a person borrows money they should pay it back on time as agreed to.
    BroHon and OldGuy03[QUOTED] like this.
  24. Sep 2, 2025 at 7:54 AM
    #114
    You can still buy serviceable clunkers and fix them yourself. But no one will. They can’t be caught dead not in the latest and greatest.
    BroHon likes this.
  25. Sep 2, 2025 at 8:27 AM
    #115
    This is only true in an environment where predatory lending isn't rampant. Reference 2007-2008 recession in case the memory is fuzzy, how quickly predatory lending can pour gasoline on fires and destroy everything.
    The reality is, those loans to buy the latest-and-greatest shouldn't be available to these kids. There's a sizeable argument to be made about whether or not their mentality of "They wouldn't give it to me if I wasn't qualified" is valid, but the reality is, we're humans, temptation will win the majority of the time if you open the door.
    I was fortunate to have poor parents who were skilled [as a result of poverty], who then handed down/taught those skills to me, so I could then share with my kids. Sadly, all it takes is one generation failing to hand down those skills, it reverberates through subsequent generations. That skills divide, that failure to teach, happened somewhere between the Boomer generation and GenX. In GenX's defense, we were taught by our Boomer parents that going to college is the only way to succeed in life, it was the biggest importance, prioritize it above everything. That was a failed teaching from the Boomer generation that, I believe, ultimately led us to where we are today, on all accounts. It's what many of my older GenX peers taught their kids who are in their 30s at this point, college is the only way. That's when predatory lending entered the chat, capitalizing on people desperate to heed their teaching and use higher education to get ahead. Enter the student loan crisis.
    The whole situation is pretty bleak, frankly. We had a major parenting screw-up in the 70s/80s that's led to the course we're presently on. Note it's not happening to a remotely similar degree in, for example, Europe.
  26. Sep 2, 2025 at 8:29 AM
    #116
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    I don't subscribe to the notion that it's someone else's fault. Personal responsibility has worked well for me.
    BroHon, bfunke and KNABORES like this.
  27. Sep 2, 2025 at 8:34 AM
    #117
    You're a fortunate dude to have the ability to control yourself. It's a rare trait, and always has been, it's not something that's been taught for decades now, and even if it had been, the internet/influencer culture would've un-taught it.
    When you don't suffer from certain afflictions or shortcomings that enable or fortify that control, it's really easy to paint everyone around you as a loser, an ingrate, a burden, a failure. And doing exactly that is what's wrong with the world today. When you accept the system is perfect for everyone as if everyone is just like you, we're all destined to fail. Strength doesn't need to be personal/individual. We're all in this shit together, like it or not. There's nothing wrong with helping your fellow man, or at least trying to understand their plight/burden, and realize very few people are the same as you, have the same discipline as you, etc. If you cast people out, write them off so easily, from where are they supposed to learn better?
    Again, this is another major cancer prevalent today.
  28. Sep 2, 2025 at 9:16 AM
    #118
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  29. Sep 2, 2025 at 9:17 AM
    #119
    badass03taco
    Dont look at me just delivering data
  30. Sep 2, 2025 at 9:19 AM
    #120
    ChattanoogaPhil
    2000 4.7 AC SR5 4wd
    Accepting responsibility for the choices one makes isn't a special gift, it's a choice.
    I agree that there's nothing wrong with helping others. What's wrong is making excuses and blame-shifting on behalf of others, suggesting that the poor choices they make are the fault of others. Victimhood mentality is the cancer. Personal responsibility is the cure.
