Rate my timing belt
Discussion in '1st Gen Tundras (2000-2006)' started by TenderTundie, Feb 28, 2025.
  1. Apr 15, 2025 at 2:25 PM
    TenderTundie
    TenderTundie [OP] New Member
    2001 SR5 4.7L V8 4WD
    Alright people, I'm gonna get 'er done next week one way or the other!
    Clearly it's overdue anyway , and I got a little nudge today. Got a day off work to go whitewater kayaking with some buddies, and headed for the local river. About 40 miles down the freeway the temperature needle started climbing. Uh oh! Pulled off the freeway, shut off the engine, and took a look. A modest cloud of steam from under the hood, and an audible hissing sound as coolant shot out into the V of the V8. Hard to get a clear look, but it's likely the Coolant Pipe O-ring that seals the connection at the very front end of the coolant pipe (runs through the V from the back by the starter up to the front). I had actually replaced that about 6 months ago when I was dealing with the chewed knock sensor wire, because I thought I could trace a minor coolant leak to it back then. Apparently I must have nicked the O-ring when installing it, or otherwise goofed it up, because it seems to have given out today!
    Reservoir was only down about 1/4, but after cooling off I looked in the radiator and it took about 1.5 gallons of coolant. Luckily I carry plenty of coolant - maybe a little gunshy after past coolant leaks lol! Topping radiator was enough for me to limp home with totally normal temp gage, but I was losing coolant the whole way.
    Bummer to miss the river while the flows are up, but could have been worse! No tow truck is nice.
    If I am correct, replacing the coolant pipe o-ring is part of a timing belt job anyway, and included in the Aisin timing belt kit? So I made an appointment with my most trusted local shop for next week - they say all their mechanics have min 20 years experience, and they don't have any "junior mechanics" right now. They say they've done plenty of timing belts on Tundras, but didn't specify 2uz-fe or first gen tundras. They seemed confident and patient with me, so I'm leaning towards going for it with them. $1000 in labor and supplies, and they'll let me provide my own parts. I could always change my mind and do it myself, but I'm going to order the parts tonight either way.
    If I'm taking it to the shop, they'll have their own coolant, FIPG, tools, etc. ANYTHING TO ADD TO THIS SHOPPING LIST OF PARTS I'LL PROVIDE THE SHOP?
    Obviously, if I do it myself, I'll need to get some coolant and fipg. And will borrow an impact from my friend. But for tonight, I just want to get all the key parts on order in case I opt to take to the shop next week.
    Thanks in advance!
  2. Apr 15, 2025 at 5:34 PM
    TenderTundie
  3. Apr 16, 2025 at 3:25 AM
    I wouldn’t have ordered DAYCO, but …
    Aisin makes the part IIRC. You can look up the correct part using their part finder: https://aisinaftermarket.com/online
  4. Apr 16, 2025 at 3:44 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    TenderTundie[OP] likes this.
  5. Apr 16, 2025 at 7:38 AM
    TenderTundie
    DayCo not so good for the accessory belt tensioner eh? I had a feeling y'all would have suggestions on that. I did order it all last night from Rock Auto since I'm on a bit of a timeline. As best I can tell it seems AISIN makes a tensioner for the timing belt itself, but not for the accessory belt. Good resource for other parts on that link though.
    If you guys think it's worth it, I could order a Toyota OEM one today for $72 + shipping from Ourisman, then return the Dayco one to Rock Auto. Good idea?
  6. Apr 16, 2025 at 7:44 AM
    I don’t think I’ve ever replaced my accessory tensioner.
  7. Apr 16, 2025 at 8:31 AM
    TenderTundie
    Hm, interesting @KNABORES - would you recommend leaving the original?
  8. Apr 16, 2025 at 8:54 AM
    Mine continues to operate normally, as does my clutch fan and bearing. I will not be replacing them at my upcoming timing belt change. If I detect any symptoms of failure between now and then, I will plan to replace.
  9. Apr 29, 2025 at 12:58 PM
    TenderTundie
    Update: got the truck back from my (somehwat lol) trusted local shop today.
    Since the coolant pipe o-ring failed completely last week, it was a good time to do the timing belt job since replacing that o-ring is part of the job. Everything fired up just fine, and at first glance it appears they did a good job with it. Whew!
    But two questions:
    1. They filled it with a yellowish coolant. I inquired about coolant ahead of time, and they told me on the phone that I could provide coolant if I wish, but they have "Toyota coolant" they would use, so I let them do that. I've been running the Zerex Asian Coolant that's pink for a while now, but turns out the "Toyota coolant" they used is yellowish and is actually a coolant they buy in bulk from "Como Lubricants". They assured me that the yellow meets all Toyota's specs, and that I can top up with pink Zerex with no issues. YEESH. Wish I would have just provided my own pink. You guys think it's OK to top up their yellow with Zerex Pink? Maybe I need to call them up and request the spec sheet - how would you proceed?
    2. After my 30 mile test drive, coolant reservoir is down about half an inch and I smell burning coolant. Might be OK though. Possibly it is still burping air from the system which would explain the dropped level. And there was lots of coolant around in the V after my coolant pipe o-ring failed, so perhaps that is still just burning off and explains the smell. So hopefully he successfully seated the new coolant pipe o-ring and didn't put everything back together with a coolant leak somewhere...
    Temp gauge looks good. I will drive about 100 miles for work tomorrow and keep an eye on everything. I'll snap a photo of the yellow coolant and get that posted just for kicks..
  10. Apr 29, 2025 at 1:03 PM
    NEVER mix coolant colors. Don't make me pull up @Tundra2's debacle again.
    If you had pink in it before, and they added yellow, I guarantee you they didn't flush out the pink fully, probably didn't open the block drains, so you probably have 60/40 mix of pink/yellow. If it were me, I'd dump it all being sure to open both block drains, do a couple of hose-water flushes, completely emptying it, then refill with Toyota pink. What a bunch of numbnuts.
    Tlar25 and bfunke like this.
  11. Apr 29, 2025 at 1:08 PM
    TenderTundie
    Arg! That's aggravating.
    They said they performed a full coolant flush, and charged for the coolant and "coolant flush kit" whatever that means. All as part of timing belt service.
    In your opinion, is it OK to drive this week? And in your opinion, would it be a legit option to figure out exactly what they used and commit to that, seeing as how they supposedly flushed the whole system?
    I'm going to go out and get a pic of the color right now in case that's any use.
    Thank you for response as usual :)
  12. Apr 29, 2025 at 1:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Pull the debacle
  13. Apr 29, 2025 at 1:43 PM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Probably fine to drive this week, but definitely not fine to add more of what they put in. I’d only trust either the Toyota specific or the Zerex pink stuff.
  14. Apr 29, 2025 at 1:54 PM
    You're probably fine to drive for a month or two, honestly. But go back to the shop, keep your mouth shut about the color, show 'em you're low and you been smelling burnt coolant. Give them the chance to add more of whatever they put in it, at no charge. If they don't offer it, a gentle nudge of "I paid for a full coolant flush, and it doesn't appear you guys filled it up..." may suffice.
    Re-pasting from another thread:
    Like, this exact type of buildup, @Tundra2 had that crap ended up jammed in everything in his engine, like the throttle body bypass, the lines to the oil cooler, clogging everything up to the oil cooler, clogging the internals of the oil cooler, completely clogging cooling hoses, one radiator hose, another radiator hose. This was the consistency of it. His previous owner was a dumbass and didn't understand you can't mix coolants and there's no such thing as "universal" coolant.
  15. Apr 29, 2025 at 2:18 PM
    TenderTundie
    Thanks for the quick responses everyone! I will read the debacle tonight as soon as I have a second. But can anyone provide the TLDR? Does the problem lie in using Yellow Mystery Coolant? Or is the problem in the mixing of the two colors?
    I took photos, and judging by the color it seems they may have done a pretty good job getting my nice trusty Zerex Pink all flushed out and replacing it with all Yellow dog urine looking coolant.
  16. Apr 29, 2025 at 2:31 PM
    FiatRunner
    Jack
    The issue is mixing two different types of coolant.
    Unless I am mistaken, all types of antifreeze cool the same, but they have different formulations to work better with different engine materials. That’s what I’ve been told.
    I agree with you though- it does look like there isn’t any pink in that.
  17. Apr 29, 2025 at 3:05 PM
    It won't show. You could probably mix the two 50/50 and it would still look irridescent yellow.
    It's entirely possible they flushed with water in between instead of opening the block drains. The only way @TenderTundie is going to know that, and know the type of coolant the truck has in it, will be going back to the shot to ask:
    • Which coolant did you use to I know the lifespan and what to top off with, and can you top it off now because it's low after what you did?
    • "What's the flush kit on my bill, and, like, do you guys pump all the old out, then pump in the new?"
    The shop will undoubtably try to bullshit @TenderTundie on this topic. "It doesn't matter, they're all the same..." either because they don't actually know, don't understand, or don't want to take time to explain it. I'm no mechanic, but I'm a curious-as-shit person so I geek out on this kinda stuff.
    Engine blocks are made out of different stuff, some have aluminum blocks, some have steel blocks, etc. Certain additives can actually help contribute to steel breaking down, others can mix with aluminum and result in precipitate. Likewise, your radiator, which all cars have, is going to be made of different types of metals and certain coolant compositions may not be ideal.
    All coolants use different formulations, IAT, OAT, HOAT are the biggies. They all have different additives used in them, like IAT has silicates and phosphates or inorganic acids, OAT uses organic acids. HOAT is a hybrid of IAT/OAT (if I remember right). But, here's the thing: Your manufacturer is going to tell you, "hey, don't use stuff with silicates", or "don't use stuff with phosphates". There are tons of variations, I'm pretty sure you can technicaly get IAT coolants that are phosphate-free if that’s what your manufacturer prefers but … if you care what your manufacturer prefers, you’ll buy what they recommend, right? See @BubbaW's reply below for the list of ingredients Toyota wants you to avoid in your antifreeze.
    All coolants have different lifespans. The pink we use in our trucks has a 5yr lifespan (or 60k miles; 10yr/100k on first batch*). The green I'm seeing the shop used typically has a 2yr lifespan. Why is this important? Well, for one, who the fuck wants to change their coolant every 2 years? Two, who wants to use green and change their cooland 2.5x in the same timespan you'd change it once with pink? And you NEED to change it, old coolant can get caustic and do things like erode the thinner sections of head gaskets that often live between the cylinder wall and coolant ports. But beyond that .... if Toyota tells you, "Only use long-life pink in your engine", but the bottle (or your mechanic) says, "Works in all engines", who the fuck are you going to trust on this topic, the people who designed the fucking car, or the coolant company and mechanic trying to take your money?
    The different coolants are different historically because the color gave a clue on what's in them. I don't know if that fully holds true todays, but it used to be.
    Really, it's a combination of things. I say this in the megathread because it's true. There's no such thing as "universal" coolants. It's marketing bullshit. The coolant may technically be compatible with your engine, as in, it's going to cool. But it may interact poorly with the engine if using specific coolant formulations. It may interact poorly with the metal of your block, radiator, or heads. It may not cool as optimally, or it may contribute to breaking down seals faster because it contains inorganic acids vs. organic.
    tl;dr - stick with what the manufacturer tells you. For our V8, it's pink SLLC (long life coolant). And regardless which coolant you choose ALWAYS CHANGE THE COOLANT WITH A FULL FLUSH AT THE CORRECT INTERVAL LISTED ON THE BOTTLE. (This is the other reason @TenderTundie needs to know what they put in it).
    Tlar25 and TenderTundie[OP] like this.
  18. Apr 29, 2025 at 3:14 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Dude, flush that shit out. It sucks, but it's gotta be done. Period
  19. Apr 30, 2025 at 7:44 AM
    TenderTundie
    OK, this is helpful. Thanks for the script to use at the mechanic, haha! That's actually very useful. :)
    Do I want them to have flushed with water in between?
    I will call and ask these questions to see what I can learn.
  20. Apr 30, 2025 at 8:13 AM
    #50
    If you had pink before, and they changed the color, then yes, it's best practice to flush with water or drain/fill with water in between. Distilled water is preferred, but for flushes, regular hose water is fine in a pinch.
    Links pasted above to pics of what @Tundra2 found in his is a good example of what can happen when different color/type of antifreeze interact, or when you use the wrong type (precipitate for interaction with block/radiator metals can also cause jams like that, as can StopLeak products). Which one caused his case is uncertain. But it just so happens the color of stuff he dug out is roughly what I'd expect to see when pink and green collide...
    I wouldn't call them. I'd drive up to the shop. Ask, and play dumb if you like, "Hey, I notice my coolant levels are a little low after the work you did, is this normal?"
    I'm pretty sure they'll check and maybe top you off. If so, it's a good time to ask "can I take a pic of the bottle so I know what to buy at the store?"
    Could be a good time to mention, "I notice the color changed, I'm curious ... how does a flush work, like, do you guys drain the fluid out and flush it with water or what?"
    Sometimes the 1,000% best way to get answers out of people is to act like you don't know anything but you are super curious and want to learn. If you don't come off as combative or like you know a lot already, people - especially specialists - are often more willing to share. I'm telling you this after a long career of working with technology/security specialists. 9 times out of 10, people who have a specialty are excited to have opportunities to share with a newbie, as long as they're not overly busy.
  21. Apr 30, 2025 at 8:43 AM
    #51
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    If we stick with what the manufacturer suggests for our 1st Gens V8's, it varies from 00-03 Long Life(red) to 04-06 Super Long Life(pink).
    Of course, SLLC will work just fine in 00-03
    00-03....
    Coolant type:
    TOYOTA Long Life Coolant" or equivalent
    With ethylene−glycol type coolant for a
    proper corrosion protection of aluminum
    components
    Do not use alcohol type antifreeze or
    plain water alone.
    04-06....
    Coolant type:
    “Toyota Super Long Life Coolant” is
    filled in your Toyota vehicle at factory
    fill. In order to avoid technical problems,
    only use “Toyota Super Long Life Coolant”
    or similar high quality ethylene glycol
    based non−silicate, non−amine, non−
    nitrite, and non−borate coolant with
    long−life hybrid organic acid technology.
    Do not use plain water alone
    TenderTundie[OP] and shifty` like this.
  22. Apr 30, 2025 at 9:45 AM
    #52
    TenderTundie
    Thanks for this @Tundra2. Yeah, it sucks, but I guess it's not the end of the world. Just the local shop charging $300 on my Timing Belt bill in exchange for creating another headache/job for me to do... YARG!
    I guess this is one more reason for me to continue building my skills and tool collection to do absolutely everything myself and never trust a shop... That's the direction I've been heading anyway, but opted to do the shop for this complicated job, and now I regert it! lol Ever see one of those "No Regerts" tatoos? Anyway...
    Looks like I will need to read your entire Crackhead thread one day - interesting stuff! For now, I think I got the main points out of the coolant related debacle. Sounds like you bought Crackhead truck, found that coolant was coagulated and/or filled with chunks of rusty scaly stuff. Infer this was caused by mixing of orange and pink coolant, and/or sitting or making tons of short trips with neglect over year. Did all sorts of crazy shit to flush/remove and replace ruined parts. Wowsers. Missing anything?
    Here's what I take from this:
    • Sounds like I will ultimately need to flush everything and replace with Zerex Pink.
    • But, since your issue seems to have developed over a long/unknown time of sitting, hopefully it is not a huge rush? I would love to be able to drive my truck the next 2 weeks or so, then deal with the flush.
    • Folks agree that driving with the supposedly clean/flushed yellow is OK for a couple a weeks? OR does that depend on confirmation of how the mechanics "flushed" it - with water in between or not?
  23. Apr 30, 2025 at 9:57 AM
    #53
    A crackhead owned his truck prior. Nobody really knows what that crackhead actually did with it. I believe it was a farm truck prior to that. If only that truck could talk...
  24. May 1, 2025 at 3:26 PM
    #54
    TenderTundie
    Thanks for this @BubbaW! From the manual?
    I went out there today and followed @shifty` advice to play naive, and express interest in learning. Front desk guys were going to "attempt to bullshit user @TenderTundie", but then I got with a mechanic who was super helpful. He listened to all my questions, and here's what I learned:
    • A machine was used to do the flush with no water in between. The machine "gets up to temp" then it hits a button and flushes out ballpark 4 qts of my good old pink, and replaces with yellow. Mechanic said they used about 6 qts of their new yellow "universal" to hopefully get as much of the old out as possible and avoid mixing too much. He acknowledged that there is probably some degree of mixing from heater core or other nooks and crannies.
    • However, he SWEARS that it is OK to mix. This guy seemed really smart and was really listening to me, so I told him I'd read online about certain debacles related to mixing colors. He said "yes, but that's really an issue with old green coolant (IAT I think) mixing with newer technologies". He said they pay quite a bit to get a yellow universal coolant that will not cause gelling if mixed with modern coolants. Specifically said it's going to be OK if it mixes with my Toyota Zerex Pink, and that I should go ahead and use my pink for top ups. I have not done that.
    • He let me in back to look at the label, and here's what I got (below).
    What do you guys think of that Shell Multivehicle Antifreeze and Coolant? I see it meets ASTM D3306, which Zerex Asian Pink also does.
    I would value your opinions:
    Is it OK to run this coolant, possibly with some leftover Zerex Pink from the "coolant flush" for a few thousand miles without risking total disaster/debacle?
    Building from there, is it actually OK to run this coolant for a couple years, and just flush thoroughly back to pink at my next coolant change?
    Or can someone turn up a spec sheet that shows this is NOT OK for our engines and/or may be a disaster mixing with Pink? If so, it's urgent, and I will shorten up our weekend camping trip by one day in order to flush with distilled water then Zerex Pink immediately.
    From the bulk container at the shop:
    I believe I found the same product at wallyworld, and here is the front and back of the container:
  25. May 1, 2025 at 3:51 PM
    #55
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    For me personally….not labeled but A choice. I’m not being hard headed in my choices but I chose since purchase in 2019 to only use OEM until they quit making it.
  26. May 1, 2025 at 3:55 PM
    #56
    bfunke
    bfunke Tundra Curmudgeon
    Get Zerex Asian Pink
  27. May 2, 2025 at 7:52 AM
    #57
    A bit more info on the product: https://expertsincarcare.com/wp-con...ds/TDS-Shell-Multi-Vehicle-50-Pre-Diluted.pdf
    It technically [appears to me it] meets most of Toyota's requirements as posted by @BubbaW above.
    In order to avoid technical problems, only use “Toyota Super Long Life Coolant”
    or similar high quality ethylene glycol based non−silicate, non−amine, non−
    nitrite, and non−borate coolant with long−life hybrid organic acid (HOAT) technology.​
    Per the technical data sheet (TDS) I just linked, it is ...
    • Ethylene-glycol based
    • HOAT technology
    • Amine-free
    • Nitrite-free
    • Borate-free
    • NOT silicate-free (TDS for the Shell product says "low-silicate")
    IIRC - and I'm going from memory here, and my memory seems to be spottier on some things than others these days - silicates are an ultrafine abrasive and thus can cause precipitate, but are great at keeping things clean. It's not until the fluid gets old and accumulation has occured that you'll hit problems. That's not going to happen overnight. I'm not sure seals etc. will handle silicates. Not my area of expertise.
    Would I be overly worried about it, and rushing to flush my system this weekend, this month, this year?
    Probably not.
    Would I make a point of, within the next year or two, buying the correct coolant, and flushing the system to put the correct coolant in?
    Yes.
    Look, I know you have other things you need to put money into on the truck, things directly tied to safety. I'm trying to give you my honest opinion, despite my personal biases, whether I like or prefer what I'm saying. I never want to come off as a hardcore purist and we all know life is full of grey areas and "make-do", I feel like this is one of those cases.
  28. May 2, 2025 at 8:17 AM
    #58
    TenderTundie
    Thanks everyone for these responses. I'm thinking it is not an emergency, but I will ultimately replace with Zerex within the year probably sooner.
    I reviewed a bunch of other threads on here about coolant flushes, and I'm leaning towards doing this:
    1. Drain rad and block of yellow.
    2. Fill with diluted water and drive.
    3. Drain rad and block.
    4. Fill with Zerex Asian 50/50 prediluted. Maybe get 1 gal. of Zerex Asian concentrate (undiluted) and use about 1/2 of it, in order to counteract the residual diluted water and have full strength mix in the system?
    It gets to like -40 in the winter here, so it's good not to have weak antifreeze... I guess I could test it too.
    Predilute I normally use:
    Maybe 1/2 gal Concentrate since some distilled water will remain in the system after flush?:
  29. May 2, 2025 at 10:15 AM
    #59
    If you're going concentrate, a piece of advice. Yes, flush with water in between. Yes, use distilled water. On the final fill-up, pour a gallon of coolant, then pour a gallon of distilled water. Next time, half a gallon of coolant, half a gallon of distilled water. From there, it's going to be increments. I want to say the entire 2UZ engine and radiator will hold ~3.4 gallons, but don't quote me on that. I'd probably do 1 gal/1gal, then ½gal/½gal, then ¼gal/¼gal, and see where I'm at. And if you don't already have a no-spill coolant filling funnel, pick one up. Remember when draining to do the petcock on the radiator, and both block drains, just below the exhaust manifolds.
  30. May 13, 2025 at 10:29 AM
    #60
    TenderTundie
    Sounds good. I am going to take care of this along with an oil change this week.
    I got the Zerex Asian concentrate, because it's a bit cheaper, and because it seems like I will want to add a little extra concentrate after doing the repeated flush with distilled water. Like, if the system holds ~3.4 gallons (I will look up and confirm), then at the last flush I'll probably only get 2.9 gallons out, and there will be 0.5 gallons of reasonably clean distilled water left in the system.
    So it seems to me, I'd want to start by adding about 0.5 gallons of pure concentrate to balance that trapped water. Then fill up at a 50/50 ratio after that. Make sense?
    I park outside and it gets to -40 F every winter around here, so I want to make sure and have a good full strength blend in the system.
