Body Mount Part #s
Discussion in '1st Gen Tundras (2000-2006)' started by _Spencer_, Jan 22, 2025.
  1. Jan 22, 2025 at 7:01 AM
    _Spencer_
    _Spencer_ [OP] New Member
    2002 Tundra AC 4x4
    Good morning all, I'm hoping someone could assist in verifying part numbers for the body mounts on my 02 Tundra Limited access cab 4x4 TRD. I've searched multiple forums with no results and cross referenced multiple parts dealers and I get conflicting results on what parts fit my truck.
    Here are the numbers I've got:
    52203-0C020 x2 (NO. 2 Middle mount)
    52217-0C070 x2 (Middle mount bolts)
    52205-0C020 x2 (NO. 3 Rear mount)
    52217-0C090 x2 (Rear mount bolts)
    94184-01001 x4 (Nuts)
    90201-10100 x4 (Washers)
    90080-11377 x8 (Smaller bolts, 2 per mount I believe?)
    I am just looking to replace these four mounts (not the front two)
    Thanks in advance!
  2. Jan 22, 2025 at 7:21 AM
    Welcome to the forum. Two super helpful threads for you:
    On that 2nd link: It'll take you 2 minutes. Read the first bullet points, ignore the rest. Once you input your VIN in the EPC site, the body mounts for your 2002 will be under "Body and interior" section, under the two links I show below. Once you click on each of those links, you should see the parts; click on the part and read the part notes to understand if it's meant for your truck. Order parts online at https://autoparts.toyota.com to ensure you get authentic (since scAmazon and fleaBay are littered with authentic looking knockoffs) and if you need a suggestion for a good dealer to order from remotely at high discount, we have suggestions.
    The main reason I'm not attempting to confirm your part numbers is because the body mounts are likely different based on your chassis code, and whether you have V6 or V8 and you were manual or auto could make a difference. You failed to include your engine in your 'One-Line Vehicle Description' inside your personal profile details. But still - it's better you learn how to fish on this one, to become self-sufficient. You'll reap the benefits in droves later.
  3. Jan 22, 2025 at 7:31 AM
    One other point of note in case it helps. I notice the EPC has something tricky/confusing in it. This is it.
    Note the big oval at the bottom. Any time you see that X with four dots, it's saying "this part had a crossover date"/"this part had a variation". You see the two smaller circles, that highlights the specific piece those designations are referring to. In this case, it only pertains to that single bottom washer, and I'm assuming there's a diameter or thickness difference, considering the rest of the parts above it are the same.
    When talking with the local parts counter person, they tell me the when you see a dash with 4 digits, the 4 digits are usually YYMM, where YY is the production year (2003) and MM is the production month. You can find your production year and month on your door sticker.
    If the parts counter guy is correct, the big circle indicates the X1 part is for all trucks using this chassis type from [start of production] thru 0310, i.e. October 2003, and the X2 part is correct for trucks from 0310, i.e. October 2003, and onward.
  4. Jan 22, 2025 at 9:53 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Jack McCarthy likes this.
  5. Jan 22, 2025 at 10:19 AM
    KNABORES likes this.
  6. Jan 22, 2025 at 10:53 AM
    NickB_01TRD
    KY
    Yup that's the one. There's so much in the mega thread sometimes I forget what we got.
  7. Jan 22, 2025 at 3:50 PM
    I looked them up myself and the dealer told me a few parts number were updated and he showed me on his system. Even with different part numbers, they looked pretty much identical to me (mount, not hardware) but I decided not to take them and got the energy suspension kit instead.
  8. Jan 23, 2025 at 1:42 PM
    _Spencer_
    2002 Tundra AC 4x4
    Thank you for the responses! That catalog is exactly what I was looking for and will definitely come in handy in the future. All the PNs checked out and I will be placing an order through Ourisman Toyota.
