Pickup bed lean…bad leaf bushing, shock?
Discussion in '1st Gen Tundras (2000-2006)' started by Jack McCarthy, May 8, 2022.
  1. Jun 20, 2022 at 7:27 AM
    #91
    Or ... you brought awareness to what otherwise would leave people scratching their damn heads, rebuilding their front suspension, etc.
  2. Jun 20, 2022 at 4:29 PM
    #92
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Which I started to do.
    Tundra2 likes this.
  3. Jun 21, 2022 at 5:30 AM
    #93
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    If anything, you brought some attention to lurking problems with 20 year old trucks.
    I didn't have time to mess with it over the last couple days, but it'll have to be addressed soon. When I jacked up the truck, it almost immediately started to re-align the cab with the bed.
    I replaced the front cab mounts when I installed the frame repair caps from Autorust.com, but didn't do the rears...
    I just have to find a rear mount now...
  4. Jun 21, 2022 at 7:14 AM
    #94
    Does Autorust not carry? Are the rear and fronts not swappable, where you can use the passenger front at the driver rear or ??
  5. Jun 21, 2022 at 10:20 AM
    #95
    N84434
    Milwaukee WI.
    2001 Limited TRD
    My apologies.. My physical steel mounts are fine, the actual rubber isolator is what failed. I bought a new isolator from a dealer in Lakeland Fla. this morning, along with the new hardware. So, once it shows up, I'll take photos and document in my main thread.
    I'm pretty sure those replacement mounts from Autorust are swappable front to back, if needed..
  6. Jun 21, 2022 at 10:25 AM
    #96
    Jack McCarthy [OP] It’s always the fuel filter
    I’ll be interested in how you plan to lift the side of the cab by at least 3 inches to get it in there and whether you have to do anything to not damage any brake lines.
  7. Jun 21, 2022 at 10:37 AM
    #97
    I think you'd be shocked at how little is holding that cab down. Most single-cab vehicles only have 4, sometimes 5 bolts holding the cab on and there's a fair amount of wiggle room, 4-6", if you pop off a couple of bolts. Access cab, maybe 6 bolts? Double I'm assuming has 7-8? @Richid had some good feedback on the last page, here.
  8. Jun 21, 2022 at 10:46 AM
    #98
    Well I am curious about how much leeway is available from the brake lines at the master cylinder to the frame rails. I don’t have ABS so no worry there.
    Also, does the front mount near the radiator hinder you from lifting the cab at all? At first glance it looks like they’re joined together (cab and engine bay).
  9. Jun 21, 2022 at 11:00 AM
    #99
    I can't say in your specific situation. But of the trucks I've had, the front clip is bolted to the cab. As long as you remove the front and rear cab mounts on one side, there's no other contact point. YMMV on a 1G Tundra, I've never had to do it before. It sounds like @Richid has though
  10. Jun 21, 2022 at 11:00 AM
    #100
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    Check out the frame repair topic and look for the instructions for frame replacement. There is a section on cab removal and what has to be done.
    Jack McCarthy[OP] likes this.
  11. Jun 21, 2022 at 11:13 AM
    #101
    Cool. I didn't even think of that. I know it's not in the FSM.
  12. Jun 21, 2022 at 2:36 PM
    #102
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Like @shifty` said, I'll be removing the bolt for the front right mount as well, which will give me plenty of wiggle room to get the mount in there. Just jack up the right side of the cab and go to town...:thumbsup: no brake lines to worry about on that side.
  13. Jul 7, 2022 at 12:47 PM
    #103
    This is more reassuring since I didn’t want to set myself on fire cutting those nuts off next to the gas tank.
    https://youtu.be/mTJUaJS5eRk
    I’m going to see what I can done this weekend.
    Bikeric likes this.
  14. Jul 7, 2022 at 1:03 PM
    #104
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Dang, that video gave me anxiety the whole time and I couldn't look away......:annoyed:
  15. Jul 7, 2022 at 2:45 PM
    #105
    NetGnome
    NetGnome New Member
    NJ
    For removal of rusted bolts and nuts without torch try a Chinese ZVS induction coils. These coils can heat without flames as long as your can reach the coil over the rusted bolt or nut. You have to bend the leads of the coil to fit the connections. Bend the leads so the coil is off to one side so it will fit over nuts easier. You can heat and cool, with ice or water or PB blaster, several times for really rusty bolts. I use a 12V car battery and a inline switch to the circuit board. I wear gloves because the circuit board will heat up. Let the circuit board cool down if it gets to hot.
    https://smile.amazon.com/DEVMO-Volt...657229614&sprefix=Zvs+induction,aps,88&sr=8-3
    HAL69000 likes this.
  16. Jul 9, 2022 at 11:32 AM
    #106
    The carnage….
    The hockey puck/polyurethane pinch weld jack pad combo…
    Looks like my bracket does fit an 02 Tundra unlike @HAL69000 ’s Tundra. So maybe no bracket modification necessary. :fingerscrossed:
    des2mtn, FirstGenVol and HAL69000 like this.
  17. Jul 9, 2022 at 11:57 AM
    #107
    HAL69000
    HAL69000 New Member
    2004 Double Cab 4WD
    Nice!
    Wow that is very interesting about the bracket. Can't even begin to wrap my head around why mine are wider.
    Thanks for the hot tip @NetGnome . For $20 I will definitely mess with one of those coils. How big a nut can you fit these over?
    FirstGenVol likes this.
  18. Jul 9, 2022 at 12:49 PM
    #108
    Gitrdun!
  19. Jul 9, 2022 at 2:34 PM
    #109
    The mangling!!!
  20. Jul 9, 2022 at 3:35 PM
    #110
    The repair…:)
    HAL69000 and des2mtn like this.
  21. Jul 9, 2022 at 3:59 PM
    #111
    Hey brother! :cheers:
  22. Jul 9, 2022 at 4:01 PM
    #112
    Don’t use this….it started smoking at 20k rpms after 10 minutes of use.
    Use a proper mangling tool!
    Along with a chisel and punch tool
    des2mtn likes this.
  23. Jul 9, 2022 at 4:02 PM
    #113
    7/10 on the mangling scale? o_O
  24. Jul 9, 2022 at 4:38 PM
    #114
    No more pickup cab lean and I can drive it without gritting my teeth going over a pothole or bump in the road. Problem solved!
    Bikeric and FirstGenVol like this.
  25. Jul 9, 2022 at 6:20 PM
    #115
    @N84434 You’re up! How is your repair coming along? I didn’t see it in your build thread but maybe I glanced over it.
  26. Jul 10, 2022 at 1:53 AM
    #116
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Oh.... This is a fascinating story so far....
    I ordered the parts through ToyotaPartsdeal.com back on June 21st. On Thursday, the 7th, I called the dealership in Lakeland Fla. and asked "Where's my stuff, eh?" I give them the order number, and I hear muffled talking, someone says "No, he's on the phone now", I'm then put on hold for a minute, the guy comes back on and says "looks like we were waiting on the bolt you ordered and it appears that it just showed up, so your order will ship out tomorrow" :rolleyes:
    So, my gut tells me the parts were in stock and they somehow missed the order, but in any case, I'll have the mount and new bolt in a few days. The truck has been sitting in my garage for the last 2 weeks just waiting for the parts to show up.
    I'll update my thread once parts are in hand.:thumbsup:
  27. Jul 10, 2022 at 9:27 AM
    #117
    NetGnome
    NetGnome New Member
    NJ
    These coils can only fit 5/8" diameter max. The bigger the nut or bolt the more power you need. So this works better on smaller nuts.
    These coils will not get nuts as hot as a torch, but are helpful when near things you don't want burnt.
  28. Jul 10, 2022 at 10:50 AM
    #118
    Rear passenger shock failing?
    Bed looks straight to the cab now, but driver side rear looks high.
  29. Jul 10, 2022 at 10:52 AM
    #119
    Yeah, those (new shocks) are still waiting an install. I forgot to bring the sawzall with me when I went to do the body mount. That’ll be another time in the next week or two.
    N84434 and shifty`[QUOTED] like this.
  30. Nov 24, 2022 at 7:05 AM
    #120
    jskeyes2
    jskeyes2 New Member
    Jeff
    Carlsbad, CA
    2005 Limited AC
    ADS Shocks 35” Yokahama M/T
    Coming into the thread late - but when you replaced your cab mounts, do you have to unbolt all of them and then jack up the cab or did you do one by one?
