Truck Is Off, But Headlights & More Stays On!
Discussion in '1st Gen Tundras (2000-2006)' started by 88GT, Feb 9, 2022.
  1. Feb 9, 2022 at 1:57 PM
    88GT
    88GT [OP] New Member
    Ray
    2002 Tundra Ltd, Extended Cab, 4.7L V8, Auto, 300k miles.
    None
    Yesterday I found out that when I shut off my 2002 Tundra (4.7L V8) Ltd, 300k miles, the headlights stayed on. Opening the hood, there was also the faint whir of something running (keep in mind the truck was turned off and the key was removed). I removed the + wire from the battery and everything stopped. I connected the battery and everything stayed off... for a while. I went inside and came back in an hour, and the headlights were back on. I now leave the battery + terminal off when I stop the truck.
    Today, I also found that the cigar lighter port was dead when the truck is running (I use it to charge my phone and run my dash cam.)
    Maybe something is wrong with the ignition switch?
    Any ideas?
  2. Feb 9, 2022 at 2:12 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I would check wires for rodent damage first, see if anything anywhere looks chewed. Check the cabin air filter, you will know if they got in there.
    1lowlife and KNABORES like this.
  3. Feb 9, 2022 at 2:16 PM
    There's no cabin air filter on a 2000-2006? :confused:
  4. Feb 9, 2022 at 9:24 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Do you have any lights on in the instrument cluster or anything like that as in warning lights? Is it anything other than the headlights and what you think you may hear running?
  5. Feb 10, 2022 at 4:41 AM
    Do you have aftermarket headlights that have fans in them?
  6. Oct 30, 2023 at 9:46 PM
    TundraWrxGuy
    TundraWrxGuy New Member
    Canada
    2006 DC Tundra LTD
    Hey! Similar problem happening with my 06 DC, Was there any solution found?
    Thanks!
  7. Oct 30, 2023 at 10:04 PM
    Mine would act up occasionally after it's been raining but then would go away long enough for me not to bother checking why.
  8. Oct 31, 2023 at 6:01 AM
    Sounds like something probably arc'ed out, OR someone has water intrustion into the fusebox, which is a really well-known issue covered in the megathread. Specifically:
    • These trucks usually don't have a ton of other electrical issues. Hidden corrosion inside the battery/alt cables happens. Sometimes, a couple thousand miles after timing belt changes, people will have startup issues because the crank position sensor wasn't properly tucked away and gets rubbed by a belt (pic). There's also a similar problem with camshaft position sensor under the cam cover, where the belt will rub through (pics). There's the rodent issues mentioned earlier. Occasionally, water leaks can send water down into the ECM behind the glovebox (pics), or into the fusebox inside the cab/dash (pics and more pics). A lot of drain/vampire issues trace back to aftermarket add-ons whether the owner knows they exist or not - alarms as mentioned earlier, brake controllers, poorly installed trailer receptacles, those are some big ones.
    But something as simple as arc'ing at the main fuse where the feed from the battery goes into the engine bay relay box could probably cause some weird issues too. If there's a relay between that engine bay fuse/relay box and the feed coming into the cab, I'd be eyeballing that also. And if you live in a rust belt state, corrosion inside harnesses is a VERY common cause of circuits staying open when you don't expect it - so identifying WHERE IN THE DAMN COUNTRY you are is pretty important.
    Wiring diagrams are linked in paragraph 4 or 5 of the megathread, help yourself.
