Clunk and shudder when braking in rear ‘04
Discussion in '1st Gen Tundras (2000-2006)' started by Don’t do it alone, Jul 9, 2023.
  1. Jul 9, 2023 at 4:17 PM
    Don’t do it alone
    Don’t do it alone [OP] New Member
    Tom
    2004 Tundra SR5 4WD Access Cab
    None
    I have an issue that began as intermittent but not constant. When braking at slow speed, the rear axle shudders and makes a thumping noise. At first, I thought it was in the front. I replaced the CV axle, stabilizer links, brake rotors, calipers and pads. I took the drums off the rear and it’s not the brakes (maybe ABS OR GEARS). I don’t (but will) want to replace and see if that works. Anyone experience this ?
  2. Jul 9, 2023 at 4:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Grease your driveshaft
    Aerindel likes this.
  3. Jul 9, 2023 at 4:23 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  4. Jul 9, 2023 at 4:30 PM
    Don’t do it alone
    Tom
    None
    Nope. It isn’t the driveshaft needing grease. I did a complete service and I personally greased every fitting on the truck. I used a full tube of grease on the 3 vehicles I maintain for My Family.
    this link you supplied
    is for acceleration problems. Mine is a deceleration/braking issue. Completely the opposite of the issue.
  5. Jul 9, 2023 at 4:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. Jul 9, 2023 at 5:15 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Brake problem
    Casper421 likes this.
  7. Jul 9, 2023 at 5:18 PM
    alb1k
    Left Coast
    It's good
    Oh and to help isolate all but the drive shaft, throw it in neutral when you begin braking in a safe area.
    Jack McCarthy likes this.
  8. Jul 9, 2023 at 5:53 PM
    Give us some specs on your truck's suspension, whether you have aftermarket lift, any armor or skidplates. Anything non-stock or replaced suspension-wise, basically.
    And are you 1,000% positive your rear drums are properly adjusted, and your e-brake system is completely functional and intact? And the slip yoke specifically isn't lubed like the other zerks, you're sure you did that correctly, i.e. pump, distribute, pump, distribute, then loosen the zerk? (Clunk at stop/accel is a classic symptom, vibration not so much, it speaks to other driveline items or rear brakes)
    Have you checked the u-joints and confirmed the carrier bearing has no clear issues, and your driveshaft is clocked correctly? Has the driveshaft or carrier been out recently for any reason?
    What has been done for the rear brakes, were drums replaced?
  9. Jul 10, 2023 at 2:23 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I had this problem when I first got my truck. I replaced the brakes and rear shocks (in addition to the shudder the back would "hop" when braking)...problem solved.
  10. Jul 12, 2023 at 7:53 PM
    Don’t do it alone
    Tom
    None
    Hi w666. I do need to replace the shocks and I’ll try that along with the brakes. What I’ll also need to replace are the backing plates also. It seems like the cheapest I can find are very expensive.
  11. Jul 12, 2023 at 7:57 PM
    Don’t do it alone
    Tom
    None
    Hi Shifty. I’ve driven the truck for 6 years without replacing anything. The issue just started as I was returning from an errand. It’s all pure stock. I’ve kept up with the maintenance and that included greasing every fitting. I’ll do the brakes and shocks. I plan on driving this for another 200k miles.
  12. Jul 13, 2023 at 2:11 AM
    w666
    Maryland
    The rear shocks I used from Rock Auto cost $12 each! Now that I've decide to keep the truck (~ 3 years later) I've just replaced them with Bilstein 4600. The backing plate is another matter...the axle has to come out and the bearing et al is pressed off. Most of us have rust around the outer edge of the backing plate while the center (the important part) is good. Post up some pictures
  13. Jul 13, 2023 at 8:07 AM
    I'm hearing "My truck is a rusty bucket" vibes here. Any pics?
  14. Jul 17, 2023 at 4:07 PM
    Hartwell
    Hartwell New Member
    2004 Double Cab 4x4 SR5
    Similar issue in mine. Going to grease the driveshaft tomorrow. Hopefully that does it.
    Do you notice it happens more often in reverse? Almost like ABS is engaging? Mine had rear brakes done at Toyota dealership in last 10,000 miles by previous owner. Wonder if they weren't ajsuted properly?
  15. Jul 17, 2023 at 4:11 PM
    If you notice a clunk when shifting back and forth between R and F, that's more often a bad U-joint. Welcome to the forum. This thread may be helpful.
    You on the lake, or is the nickname symbolic of something else? Not prying, no answer required, I just happen to fish up that way a couple times a year.
  16. Jul 17, 2023 at 4:56 PM
    Hartwell
    Hartwell New Member
    Thanks, shifty! No, west coast. It's a family name though, and some from the Carolinas.
    What you mentioned happens too, but I'm more specifically talking about when I'm already in reverse and moving.
    shifty`[QUOTED] likes this.
  17. Jul 17, 2023 at 5:42 PM
    I'm not saying it is the U-joints, and I'd expect clunk both ways, but I guess I'd still be checking the U-joints while greasing the driveline. Especially if not greased in the last 5k-10k miles as expected (I do mine every oil change).
    But yeah, grease the whole driveline. While you're under there, may as well give the U-joints a good jerk and tweak.
  18. Jul 17, 2023 at 5:46 PM
    Hartwell
    Hartwell New Member
    Thanks again. Not very mechanically apt, but learning quickly with the Tundra. Is there a way to jerk/tweak while they are still attached? Should I put the truck in Neutral? What should I be looking for to determine if they are OK or need to be replaced?
    Also, is there a good way to grease the center support bearing? What kind of grease to use if so?
  19. Jul 17, 2023 at 6:06 PM
    Unless you're seeing zerks on the carrier, it's not greasable. I don't think I've seen one for our trucks that is.
    On U-joints. Someone posted this earlier, and as much as I don't like the guy, it's actually pretty solid, skip to 4m48s:
  20. Jul 17, 2023 at 6:26 PM
    Hartwell
    Hartwell New Member
    Have a 4x4 and there are zerks? This is very helpful, thank you!
  21. Jul 17, 2023 at 6:34 PM
    Hartwell
    Hartwell New Member
  22. Jul 18, 2023 at 6:22 AM
    Damn, make sure you clean those zerks before you pump :D
  23. Jul 18, 2023 at 6:30 AM
    No, I mean for the carrier bearing. You asked about the carrier/center support bearing and if it had zerks or was greasable. It's a mixed bag on most vehicles I've owned, you either need to use a needle tip to punch through the boot and lube, unless it's using a sealed bearing and can't be.
    For details on lubing from the FSM: https://www.tundras.com/threads/jolt-when-stopping-at-a-light.60699/#post-1590863
    For specific info on the slip yoke's zerk which uses a bit of a different process from other's, read FGV's words in italic here (you can skip his link): https://www.tundras.com/threads/what-would-you-say-if-i-told-you.71827/#post-1848468
    My prefered NLGI 2 grease, but use what you like as long as it's NLGI 2: https://www.tundras.com/threads/jolt-when-stopping-at-a-light.60699/page-2#post-1861809
  24. Jul 18, 2023 at 8:20 AM
    Hartwell
    Hartwell New Member
    Ahh yeah. Thank you. NLGI 2 ordered and ready to go.
  25. Jul 18, 2023 at 7:35 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
  26. Jul 19, 2023 at 5:50 AM
    You're right. Grease I referenced is moly-fortified, but I'll be honest: I just poked around and I'm having trouble finding a quality NLGI 2 grease that isn't moly-fortified.
