Jolt when stopping at a light
Discussion in '1st Gen Tundras (2000-2006)' started by 06TUNDO, Jan 21, 2020.
  1. Aug 11, 2020 at 10:12 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    Salsa Red 2007 Tundra DC @91k.
    7" BDS Coilover Suspension Lift/BDS UCAs/XB LED Headlights/Nitto trail Grappler tires on Black Rhyno Armory wheels
    I expect this is the same thing happening in my 07. Can I assume the solution is the same also?
  2. Aug 11, 2020 at 10:18 AM
    I've been using 1 grease for all the zerks. I'm sure it would be better if I followed the manual but I also doubt I'll hurt anything. I'm not even sure what grease I bought but I know it was compatible.
    shifty`[QUOTED] likes this.
  3. Aug 11, 2020 at 10:51 AM
    I've traditionally keep one full-size gun loaded with marine non-syn, one full-size loaded with VV985 synthetic and squirt accordingly. I was happy to find the VV985 is acceptable, NLGI 2, GC-LB, it's pretty flexible. Just got worried when I saw the sheet saying Moly additive was preferred for just that one joint but not on the others.
    IIRC, the only purpose of the moly additive is to treat parts with a slippery finish that hangs around after the grease is flushed out.
  4. Aug 11, 2020 at 11:06 AM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    I did not have issue of rpm rev with my 2006 dc 4.7, just the thud when stopping. The thud went away after differential service.. replaced gear oil with 75w140
    e3phung likes this.
  5. Aug 11, 2020 at 1:59 PM
    Professional Hand Model
    Fred
    Hand Protectors
    No reason. I bypassed this when doing research. The Moly overides both. Both can use Moly. No need for two separate guns and greases. Good check up on that, though.
  6. Aug 11, 2020 at 2:27 PM
    TTund16
    TTund16 New Member
    Good to know. I have it on my list of things to do or check.
  7. Aug 11, 2020 at 2:29 PM
    I honestly don't even know where I'd source NLGI 2 w/o moly. The stuff I'm using is the only I've ever used the last decade.
  8. Aug 12, 2020 at 3:45 AM
    TTund16
    TTund16 New Member
  9. Aug 12, 2020 at 4:53 AM
    Fred
    Hand Protectors
    TTund16[QUOTED] likes this.
  10. Aug 12, 2020 at 7:34 AM
    For my grease gun, where synthetic is required (<$12), this is also compatible with SPC balljoints @ 3% moly:
    https://www.amazon.com/dp/B0735RLMCC/
    For driveline stuff out of the gun, pre-lift, before I had to keep up with SPC balljoints, I was previously using using this Valvoline 985 which is a few bucks less, with 2.5% moly:
    https://www.amazon.com/dp/B000CQ4DK0
    Where non-full-synthetic / non-moly is required and for loose-bearing applications, I use the following in tube or tub, both are NLGI 2 (<$5):
    https://www.amazon.com/dp/B000CQ4DIM OR https://www.amazon.com/dp/B000CQ264A/
    The tub is what I use to repack wheels, hubs, cranks, and similar bearing-ball applications where manual repacking is required. If you're into vintage bikes, the Valvoline red looks identical to what Campagnolo sold at high-dollar BITD, but performs better IMO.
  11. Feb 9, 2023 at 8:26 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Flash forward two years in the hopes you see this reply. I am planning on greasing up the areas on my truck that well... need greasin. Was curious if you just used the Moly grease on all the applications as opposed to using non-moly, as that is the only grease I have at the moment? Thanks.
  12. Feb 10, 2023 at 5:17 AM
    I wouldn't use the non-moly, myself. As you'll see in reply # 7, Toyota calls for moly w/the double-cardan joint in the FSM, so I just use moly fortified on everything. All it's doing is adding a non-slip coating.
    evanhmn[QUOTED] likes this.
  13. Aug 29, 2023 at 11:50 PM
    boogy
    boogy New Member
    2003 Tundra AC 4x4
  14. Aug 30, 2023 at 6:17 AM
    I personally would feel confident using that grease, for three reasons. On the label, it clearly states it's NLGI 2, and it also indicates it's moly-fortified. At Amazon's site, it clearly states it's Lithium based. Those are the three requirements inside the image you quoted, which was taken from Toyota's FSM (field service manual).
  15. Aug 30, 2023 at 6:28 AM
    And @boogy your question led me on a damn goose chase to see what the moly concentration was in the grease I typically use, the VV-985 linked above. I'm hoping to get my SPC uppers in this weekend and will need to grease.
    SPC wants 3-5% Moly concentration in greases. Dunno why Valvoline makes you dig so hard, had to unearth the product SDS to learn the 985 is only 2.5% Moly, so it's just shy of SPC's metric. I'll still use it b/c I'm not tossing half a tube of grease out because it's 0.5% shy on Moly. But looks like I need to switch greases next go-round eh.
    bmf4069 and FirstGenVol like this.
  16. Aug 30, 2023 at 2:06 PM
    boogy
    boogy New Member
    2003 Tundra AC 4x4
    @shifty` Thank You kindly for your reply! I was leading towards using it because as I said I already have some on hand but I feel better about it with your affirmation. And I hear you about tossing half a tube of grease, that aint happening here either lol.
  17. Aug 30, 2023 at 2:46 PM
    I went down a similar rabbit hole when I did my SPC uppers in 2019. I remember I had trouble finding something that met specs for both SPC and our U-joints. I need to open my grease gun and see what I've been using. I thought it was Valvoline but my Amazon history shows I bought Mobile 1 also.
  18. Mar 11, 2024 at 8:09 AM
    Altitude
    Altitude OpsCkBad
    Charleston, SC
    Black 06 4.7 DC 4WD Limited 267k
    Lifted (Exact height unknown. I didn't install) 32" ATs
    Hopefully someone sees this. My yoke is missing the cap to retain the grease (in pic. Obviously not our yoke but just so you know what im refering to). Can't find any part numbers for it. If I need to replace the yoke it's self then so be it. It's been commented on before but I haven't found a solution. Need to stop the thunk but can't get grease in there.
  19. Mar 11, 2024 at 9:37 AM
    Altitude
    Altitude OpsCkBad
    Charleston, SC
    I found this PN for the yoke searching by my vin 37302-20040. It doesn't say if it fits for not. Anyone know the correct PN? But all in all, if there is a way to find the cap that goes in the end, that'll be a perfect fix.
  20. Mar 11, 2024 at 3:40 PM
    #50
    IIRC, was it @FiatRunner who had that cap missing with his Dorman replacement? Or wait, actually I think it was @Bmktw2 who had that happen actually. And he had to tack-weld a new cap on.
    FiatRunner and Altitude like this.
  21. Mar 11, 2024 at 3:41 PM
    #51
    Altitude
    Altitude OpsCkBad
    Charleston, SC
  22. Mar 11, 2024 at 4:28 PM
    #52
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    shifty`[QUOTED] and Altitude like this.
  23. Mar 11, 2024 at 5:03 PM
    #53
    Altitude
    Altitude OpsCkBad
    Charleston, SC
    @shifty` @w666 thanks for the quick reply on the old thread. I'll continue the search for the cap. If no luck I'll just order a new yoke.
  24. Mar 12, 2024 at 6:10 AM
    #54
    bfunke
    bfunke Tundra Curmudgeon
    I think he called and they offered to send a new one.
  25. Mar 12, 2024 at 2:50 PM
    #55
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    So I had a weird issue like this the first time I greased my driveline. There was a weird nondescript hole where the zerk should have been. I ended up buying some zerks and tapping a hole and installing my own. Seemed a little scary when I did it but it worked for me. No clunks anymore! Pic 1 is from before it tapped it and installed the zerk. Pic 2 is after. That metal is pretty soft so if you decide to tap it be aware of that.IMG_0947.jpg
    Tlar25 likes this.
  26. Mar 14, 2024 at 2:34 PM
    #56
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Sorry I just realized you probably have a different problem than I did. Ignore my post above....
  27. Mar 28, 2024 at 10:42 AM
    #57
    Squeakyduck4
    Squeakyduck4 New Member
    Santa Barbara
    06 DC 4x4 V8 TRD
    So is the "slip yoke" all of those fittings that need 30-40 pumps or is it just one of those?
    Edit I see the grease fitting on the sleeve yoke. Is that the particular fitting that needs 30+ pumps or do all of them need that much?
  28. Mar 28, 2024 at 10:57 AM
    #58
    It's (B) in the diagram. "Sliding" == "Slip"
  29. Mar 28, 2024 at 11:01 AM
    #59
    Squeakyduck4
    Santa Barbara
    06 DC 4x4 V8 TRD
    I see. And is this fitting where we pump 30-40 times and jump up and down on the bumper? What about the other 7? thanks
  30. Mar 28, 2024 at 11:02 AM
    #60
    It is. But I'd say 10-20, then jump up and down. Watch the yoke as you pump. Then repeat, then pop out the zerk to let off pressure. From that point, make a point of 5-8 pumps at every oil change.
    On the other 7, do as you would with any other U-joint. Pump until clean grease comes out, then wipe up.
