New to me 2001 4x4 5spd V6
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, May 16, 2023.
  1. Jun 20, 2023 at 2:30 PM
    #271
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Did I get the wrong compressor or am I expected to swap the top part over?
    Also what is this little doohickey and where does it go?
  2. Jun 20, 2023 at 2:34 PM
    #272
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    If there arent hose ports, i guess you'd have to swap it over. Maybe the gasket is under the plate?
    more pics of the doohickey.
  3. Jun 20, 2023 at 4:38 PM
    #273
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    My brother said the doohickey is an expansion valve.
    I just don't recognize seeing it anywhere
  4. Jun 20, 2023 at 5:20 PM
    #274
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    I sold the 17" 4runner wheels today and so tonight I splurged new parts for Tuntra
    16"x8" 0-offset
    265/75/r16
    110 to 106 hub centric rims
    Window doodads
    Silet, DJenerated and bmf4069 like this.
  5. Jun 20, 2023 at 5:24 PM
    #275
    That’s just a shipping cap to keep it clean, you’ll have to swap over your top piece, and usually they get shipped dry, so you’ll have to look up oil specs and amounts to add before you finish swapping top plates. That chingaso is probably the filter drier if I had to make a couch guess.
  6. Jun 20, 2023 at 5:56 PM
    #276
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    My brother said the chinsago is an expansion valve
  7. Jun 20, 2023 at 6:01 PM
    #277
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Bmktw2[OP] likes this.
  8. Jun 20, 2023 at 6:11 PM
    #278
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Cool! Thankyou for helping me finding the expansion valve. Luckily I don't have a center console and I have the lines already disconnected so the job shouldn't be too bad
  9. Jun 21, 2023 at 2:31 AM
    #279
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    If I had to go to that much trouble I might replace the core while I was at it...
  10. Jun 21, 2023 at 4:53 AM
    #280
    Yeah, about those ... if they ain't broke, don't fix. Learn from my experience - and I was being careful. https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1612#post-3182827
    Since the aftermarket ones are the not fixing anything, they're just replacements, it's not worth swapping if not broken. If you must do this process, pop off the door panel, remove the latch fully, and do the work on a bench.
  11. Jun 21, 2023 at 6:39 AM
    #281
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Shifty, thanks for the input. Both sides are broken on my truck so I need to replace them.
  12. Jun 21, 2023 at 6:46 AM
    #282
    I think it was @Jack McCarthy who mentioned the ideal way, probably in reply to the post I linked.
    Pop off the door card back there. There are two screws holding the latch onto the door frame, pop them off. There's one screw holding it to the glass, pop it off.
    Once off, transfer to a bench. Tap out the tension pins. Don't try to re-use the tension pins; Use the round pins that came with your kit - mine had none of those, and the force required to install the OEM tension pins without a proper tool is ... I believe ... what caused my unfortunate result.
  13. Jun 21, 2023 at 6:47 AM
    #283
    PS - while you're in there, you could upgrade your rear speakers with some solid 3-ohm JBL Club midbass co/tri-axial speakers too :D
    bmf4069 and Bmktw2[OP] like this.
  14. Jun 21, 2023 at 7:34 AM
    #284
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1037#post-2346263
    I used a punch with a ball-peen hammer to get them out, supporting the backside with a block of wood to localize the force to mostly just the pin itself.
    Bmktw2[QUOTED][OP] likes this.
  15. Jun 21, 2023 at 8:46 AM
    #285
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Good thinking!
    I just ordered it
    w666[QUOTED] likes this.
  16. Jun 21, 2023 at 8:48 AM
    #286
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Oh lord Shifty don't make me spend more money!
    Thanks
    bmf4069 likes this.
  17. Jun 21, 2023 at 9:16 AM
    #287
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Dare I ask how much have you spent on the truck already?
    Don't get me wrong, I think this is such a unicorn and would be awesome to keep/mess around with, but man, 10 pages and @shifty` is egging you on for more upgrades.... :D:D
    bmf4069 and Bmktw2[QUOTED][OP] like this.
  18. Jun 21, 2023 at 9:35 AM
    #288
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Latch removed:
    Aluminum Doo-dad installed and latch replaced:
    Feels good. Window opens and closes nice.
    bmf4069 and Jack McCarthy like this.
  19. Jun 21, 2023 at 9:40 AM
    #289
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Hahaha yeah I love Shifty he knows how to fix these tuntras up nice.
    So I spent $2500 on the truck and I think another $5,000 in parts lol I had to sell my old daily driver and all my savings to pay for all the parts. I'm riding bicycle right now until the truck gets going. Ive been fortunate in finding odd and end jobs like doing yard work, mechanic, pest control and working with my brother at a brewery unloading kegs.
    One thing I can say is Ive done all the labor myself so that has saved a lot of money
    I'm putting a ton of trust in this rusty truck so I've named it the Tuntrustra.
  20. Jun 21, 2023 at 9:42 AM
    #290
    Ghost Rider
    Ian
    Cypress, Texas
    Tuntrustra.... that rolls off the tongue like that....
    But yea, at under $10K some might see it as not worth it, but I think this is a keeper just because it is MANUAL!!!
    Gah..... I can't find my manual Forester my kids been getting on my nerves about.....
  21. Jun 21, 2023 at 9:47 AM
    #291
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    "Some". Yes, some might see it as not worth it.
    But I do, and I am happy with it. The experience of restoring the truck to this extent gives me a warm fuzzy feeling inside with a peace of mind in case something does go wrong later down the road that I'll know how to tackle it.
    If this truck didn't have the V6, manual transmission, and transfercase, I would not have taken this project on or even purchased the truck. But because it had everything I wanted including the brand new chassis and clean interior it became my love affair.
    Once it's all complete, I would bet most on the 1st gen forum wouldnt mind having this truck.
    Silet and Ghost Rider[QUOTED] like this.
  22. Jun 21, 2023 at 10:29 AM
    #292
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    I reused the pins on my AC rear window latches. Had to tap the holes a little larger with a drill bit (RIP, drill bit) and they still didn't quite fit, so I squeezed the pins inside of some pliers and pounded the pliers with a hammer to "close" the weird serrated jaws-thingies on those pins all the way, then they fit just fine.
  23. Jun 21, 2023 at 10:38 AM
    #293
    Do it.
  24. Jun 21, 2023 at 10:39 AM
    #294
    Well, at least you’ll know enough on how to change out the clutch when the time comes. My brother gave up on his T-100 after spending over $1k every time that needed to be done. That and the rusted out frame, brake and fuel lines underneath made sense to just get rid of it.
  25. Jun 21, 2023 at 12:01 PM
    #295
    That’s with labor.
  26. Jun 21, 2023 at 8:31 PM
    #296
    Ghost Rider
    Ian
    Cypress, Texas
    Yea, I wouldn't mind buying it be honest. But being able to wrench it is good, especially you know what happened and how you can make it right.
    I just wish I had just as much time/effort to it....
    But good for you working on it and sharing it, it was a blast to read/watch
  27. Jun 21, 2023 at 11:27 PM
    #297
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    What specs are those and how much do they cost?
  28. Jun 21, 2023 at 11:35 PM
    #298
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Buddy showed up today with his '02 access cab to see the progress on my '01. My truck was manufactured in 01/01 and his was 10/01
    bmf4069 likes this.
  29. Jun 22, 2023 at 4:05 AM
    #299
    artsr2002 and Bmktw2[QUOTED][OP] like this.
  30. Jun 22, 2023 at 10:25 AM
    #300
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Getting to the evaporator and expansion valve
    Now I'm stuck until I can get the line disconnect tool.....
    artsr2002, Winning8 and bmf4069 like this.
