392k, haven't replaced the timing belt or water pump yet
Discussion in '1st Gen Tundras (2000-2006)' started by BYRON R, Dec 25, 2022.
  1. Dec 25, 2022 at 3:40 PM
    BYRON R
    BYRON R [OP] New Member
    BYRON R
    2000 XCAB TUNDRA
    I have 392,000 miles on my 2000 4.7 motor never replacing the timing belt or water pump. Never had any problems at all, the block has never even been cracked. Just been reading about interference engines, am I in trouble?
    Advise encouraged
    Byron R
  2. Dec 25, 2022 at 3:46 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    You're past due. Get it done.
  3. Dec 25, 2022 at 3:48 PM
    Welcome.
    Yes, you're living on borrowed time, borrowed time that's been loaned and re-loaned several layers deep. I wouldn't even drive it to the store to buy parts. If a shop is doing it, I wouldn't drive it to the shop for replacement, I'd tow. You've definitely gotten your money's worth out of the engine, but it's not even at half-life.
    10mm to loosen a timing cover and inspect the belt doesn't take much effort. If you see cracks throughout the belt, stop driving on it. Crack can become a rip in no time. This is one of the worst ones I've seen, and at only 140k miles: https://www.tundras.com/threads/clicking-noise-from-engine-or-belts.102057/#post-2619704
    Lots of questions and answers about these trucks over here.
    FirstGenVol, Bob, bmf4069 and 2 others like this.
  4. Dec 25, 2022 at 3:50 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Yea, open the timing cover and show us what it looks like. 400k is pretty impressive for a rubber belt. My buells drive belt broke at 30k and didnt have any visible cracks.
    FirstGenVol, IsaiahCanada and shifty` like this.
  5. Dec 25, 2022 at 3:50 PM
    Ooh, here's another good one at about 160k miles (270,000km): https://www.tundras.com/threads/head-gasket-failure-or-loose-bolt.64132/#post-1674035
    There was one other guy on here who swore he had like 260k on his original belt, and it looked better than the two I just linked. I was skeptical, but ...
  6. Dec 25, 2022 at 3:53 PM
    Tundra2 likes this.
  7. Dec 25, 2022 at 3:59 PM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Welcome from the Rust belt. First thing i would do is take her in and get the TB and WP changed pronto. Like they said above you're living on borrowed time.
  8. Dec 25, 2022 at 4:05 PM
    And to that point, here's the Toyota/Aisin kit you'll want to order: https://www.rockauto.com/en/moreinfo.php?pk=3290529
    Don't buy on scAmazon, fleaBay, WallyMart, you're liable to get counterfeits. RockAuto is a great source. Summit Racing also.
    FrenchToasty and Mr.bee like this.
  9. Dec 25, 2022 at 4:09 PM
    Welcome from NY.
    Change that belt ASAP.
  10. Dec 25, 2022 at 4:59 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Ditto!
  11. Dec 25, 2022 at 5:17 PM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
    The replacement belt will not last as long as the original belt.
  12. Dec 25, 2022 at 8:13 PM
    French Avocado
    Utah / Wyo
    Welcome. Are you the original owner? A lot of miles. What is the driving environment?
  13. Dec 26, 2022 at 10:11 AM
    BYRON R
    BYRON R
    2000 XCAB TUNDRA
    Yes the original owner, southern California.
    georgiey22 and French Avocado like this.
  14. Dec 26, 2022 at 10:20 AM
    Could be the reason why the belt has lasted so long, mild climate.
    But we've seen other California members with as few as 180k-200k miles snap the original belt. @thefish712 is one of them, over here, @ 218k miles on his belt: https://www.tundras.com/threads/potentially-snapped-timing-belt.90981/
    Engine was a boat anchor afterward.
  15. Dec 26, 2022 at 12:46 PM
    French Avocado
    Utah / Wyo
    Perhaps not experiencing the extremes has saved you. Get it done quickly before you regret it.
    Tundra2 likes this.
  16. Dec 26, 2022 at 12:58 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    @BYRON R we all want to see pictures of that belt!
    txagg and FirstGenVol like this.
  17. Dec 26, 2022 at 1:16 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I always wonder how important the time interval is as compared to the mileage in the real world. I replaced the belt and all the related components, along with the water pump at about 72K miles, but now at 100K miles, it's now been 8 years and coming up on the time limit interval. It sure seems overkill to do another belt with so little miles on it. The original looked great BTW, I could hardly tell it from new.
    txagg likes this.
  18. Dec 26, 2022 at 2:57 PM
  19. Dec 26, 2022 at 5:19 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Meh..... it's lasted this long, probably will never fail... :thumbsup:
    PomDad and Mr.bee like this.
  20. Dec 26, 2022 at 6:11 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Yea… I’d replace that.. soon. The Kit is cheap from Aisin. I’m More impressed the water pump isn’t leaking like a waterfall.. the pumps rarely last as long as the belt without leaking
    But yes interference. Belt snaps? That trucks going to need an engine.
    French Avocado likes this.
  21. Dec 26, 2022 at 8:48 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I was told when I bought mine at 207k it was changed recently. I’m pretty sure it was original when I did mine at 275k.
    FirstGenVol, shifty` and Elevatorguy like this.
  22. Dec 27, 2022 at 4:58 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    That's exactly how mine looked when I replaced it. The truck had 175K on it and the previous owner told me he had it replaced around 130K....:pray: The water pump had a date stamp from 2000, so I'm pretty sure he was fibbin...
  23. Dec 27, 2022 at 7:27 AM
    I dunno, the sheen on that rubber suggests it's not horribly old. Maybe they just used a crappy quality belt, and did the belt only? A lot of people have that "if it ain't broke, don't fix it" mentality, won't do the water pump, tensioners. This one linked earlier was at 160k original miles, OEM belt.
    N84434[QUOTED] likes this.
  24. Dec 27, 2022 at 7:43 AM
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    Wow, 392000 on original belt. Probably you have highest mileage on original timing ever. If I have 392000 miles on original belt , I will drive until it breaks to see how long and how many miles will it last. You already had all of your money back at this mileage. Your belt maybe already hold the world record. Cheer!
  25. Dec 27, 2022 at 8:10 PM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    This is out of curiosity and for science: what does the rest of your maintenance schedule look like? Based on your TB/WP schedule the truck seems to be on a reactive maintenance v. a preventive maintenance schedule. Not that one is right and the other is wrong, there are plenty of arguments that say that cost and down time of preventive maintenance is not worth the benefit. So, did you change the oil every 5K miles. Just add oil if it was low?
    You have science to contribute to the collective First Gen knowledge base.
    shifty` and KNABORES like this.
  26. Dec 28, 2022 at 12:39 AM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    I mean it’s not just a rubber belt, it’s got all sorts for nylony Kevlar looking stuff in it. Mine was cracked to $hit at 270k, but it still looked strong.
    It’s a massive belt as well. No idea why they would fail at anything less than 200k.
    shifty` likes this.
  27. Dec 28, 2022 at 11:13 AM
    BYRON R
    BYRON R
    2000 XCAB TUNDRA
    jimf909, From day one ran Castrol synthetic oil every 5,000 to 6,000 miles, installed K&N cold air intake system about 50,000 miles. Replaced plugs every 50,000 miles. Replace the radiator at 320,000 miles, replace the serpentine belt at 360,000 miles (it broke) tranny and rear end fluid 1 time. 340,000.
    georgiey22 and jimf909 like this.
  28. Dec 28, 2022 at 12:09 PM
    You are the epitome of "don't fix it if it ain't broke". Truly amazing honestly.
    Have you ever touched the other fluids? Transmission, Transfer case(if 4x4), power steering?
    Elevatorguy and shifty` like this.
  29. Dec 29, 2022 at 8:30 AM
    jimf909
    Washington or Idaho
    Cool. Your truck has served you extremely well and your cost-per-mile is probably about as low as possible for a full-size pickup.
    The radiator replacement may be a great example of reactive maintenance v. preventive maintenance. You don't mention coolant flushes so maybe you're running oem coolant. Would flushing the coolant every two years have extended the life of the radiator? Probably if it was replaced due to becoming clogged. Would the cost of 11 coolant flushes be more than the rad replacement? I'm guessing yes. So, just run the oem coolant until the rad fails may be reasonable.
    Although, as mentioned, it's surprising the water pump hasn't failed. Even more so if the coolant was flushed regularly.
    txagg likes this.
  30. Dec 29, 2022 at 8:36 AM
    I think the serpentine belt snapping is an ominous sign. Heed its warning. Toyotas are tough. As evidenced by yours, but they are not invincible. Ask whistlindiesel.
    jimf909 and txagg like this.
