Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. May 24, 2022 at 8:39 AM
    #1861
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Not sure on the class of hitch, but it does have one. Definitely has trans cooler. Pretty sure the crackhead before me removed the wiring harness AFTER the connector for the trailer harness.
    Love your information!!!
    BubbaW[QUOTED] likes this.
  2. May 24, 2022 at 1:02 PM
    #1862
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I agree with this and then I'd tow with it and see if you need anything else.
  3. May 27, 2022 at 7:28 AM
    #1863
    Tundra2
    Noah
    Western Kentucky
    There has been some discussion elsewhere on the forum about general springs. On the fence with them or Alcan again like I used for the V6.
    Anyone got any real world reviews? Did a quick searchie, but couldn't find what I was hunting.
  4. May 27, 2022 at 10:10 AM
    #1864
    Mine work great. I went with new shackles as well. They're a tad stiff, but that could be the toytecs overdamping them.
    Tundra2[QUOTED][OP] likes this.
  5. May 27, 2022 at 1:47 PM
    #1865
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Cant get in at ts?
    ‘06 ac has slightly longer, slightly thinner leafs, than ‘02 leafs.
    When designing made-to-order springs i’d be apt to exaggerate the overall capacity i’m looking for by 1000 lbs, so when it shows up weak, its perfect.
    Tundra2[OP] likes this.
  6. May 28, 2022 at 6:51 AM
    #1866
    Tundra2
    Noah
    Western Kentucky
    Slowly starting to build a parts list for crackie. Pictures are links to the listing on RockAuto. Looking at brakes right now. Open to any, and all suggestions/advice! Also, for peace of mind... I'll go ahead, and do the Brake booster, and Master cylinder. Special thanks to @Thrussn for this! T100 brake booster upgrade!
    Not against any suggestions of anything else from anywhere else. Memorial day coming up, I'd like to jump on any discounts I can snap up...
    Thanks in advance!
  7. May 28, 2022 at 6:59 AM
    #1867
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You'll save yourself some cash if you go with these two.
    https://www.rockauto.com/en/moreinfo.php?pk=4752030&a=PowerStopPK
    https://www.rockauto.com/en/moreinfo.php?pk=8845304&a=PowerStopPK
  8. May 29, 2022 at 5:27 AM
    #1868
    Tundra2
    Noah
    Western Kentucky
    Festerw[QUOTED] likes this.
  9. May 29, 2022 at 5:38 AM
    #1869
    Tundra2
    Noah
    Western Kentucky
    Browsing for everything right now. Just rubber neckin'. I don't know how long the CV axle boots on crackie have been ripped open, but all four were torn when I got him. Would you 4WD dudes reboot an "unknown" CV axle like that? Both appear to be OEM best I can remember. Also, planning to keep the same ride height roughly. I think it's sitting about two inches over stock. Need them fancy boots?? The high angle fuckers?
    The Junkyard I go to has a few Sequoias. A CV axle there is about $25... Could reboot a set from there if I can find any...
  10. May 29, 2022 at 5:48 AM
    #1870
    Tundra2
    Noah
    Western Kentucky
    Found'em! Thanks to @DarkMint and his thread, and to @abcinv for posting a link! Now, the question is... do I need'em?
  11. May 31, 2022 at 3:38 PM
    #1871
    rock climber
    If you're rebooting anyway, I would.
  12. Jun 1, 2022 at 11:55 AM
    #1872
    RustyMcTee
    RustyMcTee New Member
    New England
    '03 SR5 4x4 AC V6 - new frame in '22!
    I also need to completely redo my vacuum lines. They're all hard as a rock and cracked. Small evap leak code just came on too.
    Did you find a kit or just got some stock hosing and cut everything to size. My mechanic said that he wasn't sure how to do the vacuum lines because they were specially bent.
    New to vac lines... I don't know heck about the evap system so any insight would be appreciated
    NUDRAT likes this.
  13. Jun 1, 2022 at 1:16 PM
    #1873
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    When I did mine, I chose to go OEM. Hard part was most toyota online sites weren't that accurate with their part presentation for vacuum lines. I chose to use the below site and all worked out well. If you choose to go OEM, you could at least use the site to look part #'s up.
    At that link, choose your basic model/frame code, at next page select whole model code, next page select Engine, fuel system...., next page over to right select Vacuum piping.
    Parts catalog for Toyota Tundra (epc-data.com)
    the below is my layout for model code UCK41L-PRSLKA....
  14. Jun 1, 2022 at 7:48 PM
    #1874
    Not sure the real world review on Powerstop rear drums, but most aftermarket give vibrations that are unresolvable. OEM seem to be the #1 choice for drums. Mixed reviews on powerstop fronts. OEM rotors with EBC green stuff pads seem to be the best reviewed for fronts.
    NUDRAT likes this.
  15. Jun 1, 2022 at 9:14 PM
    #1875
    RustyMcTee
    New England
    Thanks bubba this will get me started. How much did the hosing run ya, do you remember?
    Might be kind of a peaceful job... Just matching up hosing and replacing
  16. Jun 2, 2022 at 4:40 AM
    #1876
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Approx $100 but it was only the 2 going to the air control valve on PS motor and also the one on driver side going to the throttle body. Those 3 had enough drastic 90's, I chose to use OEM. Your 03 will be different from my 04 in many ways and suggest you look at @Tundra2 post below and perhaps he'll recall what size tubing he bought.
  17. Jun 3, 2022 at 10:37 AM
    #1877
    RustyMcTee
    New England
    Yeah @Tundra2 I'm curious about your experience sourcing all the vac hosing.
  18. Jun 3, 2022 at 11:19 AM
    #1878
    Tundra2
    Noah
    Western Kentucky
    shifty`, NUDRAT and bmf4069 like this.
  19. Jun 3, 2022 at 11:21 AM
    #1879
    Man, I was just looking for where I bought that to link it! One size doesn't have quiet enough if doing all the hoses. The 2nd biggest I believe.
  20. Jun 4, 2022 at 9:50 AM
    #1880
    RustyMcTee
    New England
    8mm then? This is great guys, thank you.
  21. Jul 19, 2022 at 4:50 PM
    #1881
    Tundra2
    Noah
    Western Kentucky
    Started working on the front end of crackie today with my Girlfriend Tabitha. We were talking, and working most of the day so I didn't get many pictures... Here's where we're at so far...
    This is driver's side only...
    • Drivers side was completely stripped except for the lower control arm because it was replaced by Toyota when they did the frame recall.
    • Old no-name lower ball joint replaced with OEM.
    • ECGS bushing, and new oil seal installed. Yuuge shoutout to @FrenchToasty!!! Yuuge!
    • New to me Junkyard CV axle installed without rebooting. (Later date.)
    • Old upper ball joint pressed out of the knuckle, and new SPC adapter pressed in.
    • Knuckle reinstalled. LBJ nut torqued to 103 ft.lbs. All four LBJ bolts torqued to 59 ft.lbs.
    • OEM upper control arm removed, and replaced with SPC UCA.
    • Wheeler's off road stainless steel brake line installed on frame side hard line.
    The plan for tomorrow??? Rip apart the passengers side, and take my shocks to a shop in town to have the tophats, and the coils replaced while trying to make headway on the driver's side brakes, and continue on the passengers side.
    More to come, pics included... ;)
    Daily first gen link
    bmf4069, des2mtn, w666 and 3 others like this.
  22. Jul 19, 2022 at 4:59 PM
    #1882
    Tundra2
    Noah
    Western Kentucky
    Oh, forgot to mention... most likely will be buying a slide in camper of some sort soon. Hence why I'm planning on stealing the silver trucks leaf springs to help beef up crackie a smidgen without breaking my bank right now...
    So the cap is for sale along with the clamps that go to it. Make offer.
    FrenchToasty and RainMan_PNW like this.
  23. Jul 19, 2022 at 7:18 PM
    #1883
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Good luck with that passenger side seal if that's something you're going to knock out. Measure how deep the old one is with something and try to get similar. I had to do mine twice since it wouldn't seal right.
  24. Jul 19, 2022 at 7:31 PM
    #1884
    Tundra2
    Noah
    Western Kentucky
    Naw, I ain't fucking with it if I don't have to. This is a bare bones, down and dirty, revamp to get the fuck out of dodge.
    I'm not doing the steering rack even though I have it. I'm not doing the wheel bearings even though they need it. I'm not doing a lot of things that I want to do because I'm feeling the fire. I know this truck will get me and mine where we wanna go when I'm done with it, and then I'll do all the other things that it really needs.
    I'm mainly using what I already have to fix it up gooder-enuff for now....
    bmf4069, shifty` and FrenchToasty like this.
  25. Jul 19, 2022 at 7:36 PM
    #1885
    des2mtn, RainMan_PNW and Tundra2[OP] like this.
  26. Jul 19, 2022 at 8:08 PM
    #1886
    Tundra2
    Noah
    Western Kentucky
    Yup! Can that bend be bent back out?
    The drivers side was rusted to the wheel hub, and I broke it taking it off...
  27. Jul 19, 2022 at 8:11 PM
    #1887
    I’m sure it can be bent back, I didn’t bend it, but have had no issues with them staying on. Pretty sure the new ones I had to hammer on will look the same after the 1st removal
    des2mtn and Tundra2[QUOTED][OP] like this.
  28. Jul 19, 2022 at 8:22 PM
    #1888
    Tundra2
    Noah
    Western Kentucky
    That sounds great!!!
    Well send them bitches my way because they are far better than mine!!!!
  29. Jul 19, 2022 at 8:36 PM
    #1889
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    :wave:
    Good to see ol crackie still going
  30. Jul 19, 2022 at 8:42 PM
    #1890
    Tundra2
    Noah
    Western Kentucky
    I ain't forgot about him. I just ain't had time.
