Best Gen-ECGS bushing tool
Discussion in '1st Gen Tundras (2000-2006)' started by FrenchToasty, Jan 4, 2020.
  1. Jan 4, 2020 at 10:58 AM
    FrenchToasty
    FrenchToasty [OP] The Desert rat, SSEM #5/25, 6 lug enthusiast
    Mo
    The SoAz….. big surprise
    Bone stock
    BBC332FE-F2D8-49CA-9A7F-E0F7B822DE34.jpg If you plan on doing the East Coast bushing upgrade; I’m will to send my removal/installation tool out to you to use.
    All I ask is that it is taken care of and used the way it was designed to be used. It has been modified slightly, to easily slip past the needle bearing for removal. When you return the tool, you must include something local to you; a cool sticker, beer, or beer(unless your from Milwaukee, I don’t want any milky beast!) or anything you feel like sharing.
    Only request the tool when your actually going to use it, not for an upcoming project in the months to come(incase someone else needs it sooner)
    PM me with your address and contact info. Happy clamming!
    snoope, Kimosabe, Hutcheson and 27 others like this.
  2. Jan 4, 2020 at 11:19 AM
    Professional Hand Model
    Hand Protectors
    Nice offer! And if you break it, then you buy 2 new ones. One for you and another for everyone else to use. Gotta add a little incentive to not abuse tool.
  3. Jan 4, 2020 at 11:25 AM
    FrenchToasty
    Mo
    Bone stock
    A public shaming would be in order as well
  4. Jan 4, 2020 at 12:25 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  5. Jan 4, 2020 at 12:53 PM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
  6. Jan 4, 2020 at 2:24 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You should have pursued an art career.
  7. Jan 4, 2020 at 2:31 PM
    Hand Protectors
    Yeah. His talents are wasting in the wire/fire and smoke industry.
    Tundra2 and bmf4069 like this.
  8. Jan 4, 2020 at 2:42 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I figured I could show my appreciation with a picture when the like button isn't enough.
    Mater, Sunnier and FrenchToasty[OP] like this.
  9. Jan 4, 2020 at 5:53 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Sorry about having to ummm.... Adjust your tool. I still feel bad about that. Thanks again for helping me out though!
  10. Jan 4, 2020 at 6:00 PM
    FrenchToasty
    Mo
    Bone stock
    The next guy can curse you!
    I’m guessing what you did, will help the next chap down the road, I’m not worried about it:)
  11. Jan 4, 2020 at 6:04 PM
    Aerindel
    Aerindel New Member
    Montana
    Anyone want to do a quick description of why you want an ECGS bushing and or how you know if you need one?
    Acatlin96 and wandering_boy like this.
  12. Jan 4, 2020 at 6:09 PM
    speedtre
    speedtre New Member
    Inland Northwest
    The needle bearing on the driver's side half shaft prematurely wears out on lifted trucks. If you feel a vibration that goes away when in 4wd, it needs replacing with this bushing that will not prematurely wear out.
  13. Jan 4, 2020 at 7:49 PM
    KarmaKannon
    Utah
    Some junk
    I honestly don't see how it could do anything but help. I just didn't like having to modify your tool. The side with the removed material really is too far by design. I guess they figure the end user can grind it if they need to.
    As the post above says and... I guess this is common if you lift even though my CV angles are pretty close to stock and mine went out. I suppose the fact that my suspension droops out to just before cv bind doesn't help.
    The why is also emphasized by this...
  14. Jan 4, 2020 at 8:02 PM
    Aerindel
    Aerindel New Member
    Montana
    Thanks. I recently had a bad drivers side front diff leak. When I replaced the seal I de-leveled the truck, and replaced the CV since I had a new laying around anyway and I was trying to solve a vibration issue in 4hi.(turned out if was a rear U joint) I noticed that bearing and was wondering if it was hard etc to replace if it needed it.
    KarmaKannon likes this.
  15. Jan 9, 2020 at 3:57 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Sounds great! will contact ya soon for the 'rental' :D
  16. Jan 10, 2020 at 9:29 AM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
    Hey French Toasty! I have recently discovered a leaking front axle seal, and I'm planning on doing the ECGS bushing while I have everything opened up. Is the tool still available?
    Clark
  17. Jan 10, 2020 at 10:46 AM
    FrenchToasty
    Mo
    Bone stock
    It’s out right now, but get all your research and parts together and it should be back by then
  18. Jan 10, 2020 at 11:26 AM
    Whothefat
    Clark
    Las Vegas
    Awesome thank you. I just ordered the bushing and seal from ECGS.
  19. Jan 22, 2020 at 5:28 PM
    Whothefat
    Clark
    Las Vegas
    @FrenchToasty
    Got my ECGS bushing installed today along with the new axle seal. I bought a piece of pvc to pound in the axle seal, I’ll send that along in case the next guy is doing the seal as well.
    thanks again!
    Mater, SUBSEVEN, Sunnier and 5 others like this.
  20. Jan 22, 2020 at 5:31 PM
    Whothefat
    Clark
    Las Vegas
    Here’s the bolt they welded onto my front diff drain plug. Worked like a champ
  21. Jan 23, 2020 at 11:24 AM
    Whothefat
    Clark
    Las Vegas
    Well shit, drove the truck today and noticed it’s leaking from in between the CV axle and the diff. Any ideas? Did I not pound the new seal in far enough?
  22. Jan 24, 2020 at 11:09 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Somebody help @Whothefat! Unless you figured it out. Then all is well.
    Whothefat likes this.
  23. Jan 24, 2020 at 11:17 AM
    Whothefat
    Clark
    Las Vegas
    I ordered another axle seal and I’m going to install when it arrives. Going to knock out the left wheel bearing when it’s apart again.
    when you guys installed the ECGS bushing did you pound it in until it’s flush with the lip of the diff? Mine was sticking out maybe 1/8 inch and it felt pretty seated in there.
  24. Jan 24, 2020 at 11:20 AM
    FrenchToasty
    Mo
    Bone stock
    Yeah mine was sitting out maybe 1/16-1/8 of an inch
  25. Jan 24, 2020 at 11:21 AM
    Whothefat
    Clark
    Las Vegas
    I must have screwed up the seal somehow. Now I’m debating if I should replace the CV axles or at least reboot while I have it apart too...
  26. Jan 24, 2020 at 12:29 PM
    Hand Protectors
    Is there a special service tool for this seal installation?
    I know there is one for the wheel bearing seals. Keeps the tool flush all over the entirety of the seal for better pounding.
  27. Jan 24, 2020 at 12:32 PM
    Whothefat
    Clark
    Las Vegas
    I used a 2 inch pvc cap that fit the outer ring of the seal pretty nicely. I’m just not sure if I pressed it in too far, not far enough or not perfectly straight.
  28. Jan 24, 2020 at 12:37 PM
    Hand Protectors
    We need some better instruction on this entire job process. Seems like a high fail rate type job.
    Tundra2 and two2cal like this.
  29. Jan 24, 2020 at 12:43 PM
    Whothefat
    Clark
    Las Vegas
    Timmy the toolman has a video for a third gen 4Runner that’s pretty good, but that’s the only guidance out there that I know of
  30. Jan 24, 2020 at 12:46 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    We have a million DIY guys here but none want to do write ups. Not sure why. I can't believe my simple PCV post has 10,000 views... That alone shows that the interest is out there.
    w666, Sunnier, wandering_boy and 2 others like this.
