ATF Burned!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Sep 20, 2020.
Thread Status:
Not open for further replies.
  1. Oct 1, 2020 at 4:16 PM
    #211
    Catmann1972
    Catmann1972 New Member
    Greg
    Rhode Island
    2020 TRD Sport
    Transmission Temperature 1 - pan
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 - Torque Converter output
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
    Saltyhero13 and Avi8or[QUOTED] like this.
  2. Oct 1, 2020 at 4:19 PM
    #212
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
  3. Oct 1, 2020 at 4:53 PM
    #213
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Might as well hop on the train.
  4. Oct 1, 2020 at 5:16 PM
    #214
    itsmerh85
    itsmerh85 New Member
    Gilbert, AZ
    2020 Black TRDPro
  5. Oct 1, 2020 at 5:18 PM
    #215
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    Posting from OPs other thread
  6. Oct 1, 2020 at 5:58 PM
    #216
    Famof5Tundy
    Famof5Tundy New Member
    2020 MGM CM Platinum
    Just getting started
    So...2 things
    1. OP was holding out and posted info on a new thread after all this traction in here????:facepalm:
    2. Looks like based on the notes, no big deal, ATF is good?
  7. Oct 1, 2020 at 6:08 PM
    #217
    glowblue
    glowblue From time to time
    VA
    Saltyhero13, Tundyfundy and 14burrito like this.
  8. Oct 1, 2020 at 9:13 PM
    #218
    Tundrafan23
    Tundrafan23 New Member
  9. Oct 2, 2020 at 12:58 AM
    #219
    Zero One Actual
    I’m just here for nine pages that prove nothing has actually happened in nine pages.
  10. Oct 2, 2020 at 2:42 AM
    #220
    GODZILLA Hail to the King, Baby.
    Wyoming
    2023 Solar Octane TRD Pro TACOMA, 2022 Honda CB500X
    Trying not to mod it
    But you're on page 8. :confused:
    Bammer, hagrid and RickC like this.
  11. Oct 2, 2020 at 4:19 AM
    #221
    Bammer
    Monroe, CT
  12. Oct 2, 2020 at 4:39 AM
    #222
    glowblue
    VA
    SomeGuy4, GODZILLA and Saltyhero13 like this.
  13. Oct 2, 2020 at 5:44 AM
    #223
    Kung
    KG, VA
    Nope, it's page 9, you must be wrong, fake news. Also,
  14. Oct 2, 2020 at 6:25 AM
    #224
    Zero One Actual
    You have all fallen for the tactic. We are that much closer to nine pages now. Muhahaha.
  15. Oct 2, 2020 at 6:30 AM
    #225
    Bammer
    Monroe, CT
    Oh the trickery ! :1up:
  16. Oct 2, 2020 at 7:39 AM
    #226
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    Anyone could advise what does the higher-than-normal number on copper mean?
    Saltyhero13 and Cpl_Punishment like this.
  17. Oct 2, 2020 at 8:36 AM
    #227
    Fearthisbeard
    Gilbert AZ
    I think someone mentioned in this thread to expect to see a higher number on the copper for the first drain, not sure why that is though.
    Saltyhero13 likes this.
  18. Oct 2, 2020 at 8:39 AM
    #228
    Bammer
    Monroe, CT
    Copper usually comes from the new cooler and will diminish over time.
    I have to look, was the sample pre or post cooler install?
  19. Oct 2, 2020 at 9:05 AM
    #229
    Cpl_Punishment
    Cpl_Punishment Young men never die.
    Rosy
    2020 MGM SR5 CM 4X4
    Thought this sample was pre-cooler so the copper must be coming from something else in the system.
    GODZILLA and AZBoatHauler like this.
  20. Oct 2, 2020 at 9:41 AM
    #230
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Sample was pre-cooler install.
    GODZILLA likes this.
  21. Oct 2, 2020 at 10:20 AM
    #231
    Txexplorer23
    Txexplorer23 New Member
    2020 Tundra Crewmax Platinum 4x4
    What’s the factory puc heat exchanger made out of?
  22. Oct 2, 2020 at 10:29 AM
    #232
    Cpl_Punishment
    Rosy
    2020 MGM SR5 CM 4X4
    I don't have a clue but I hope someone else knows.
  23. Oct 2, 2020 at 12:09 PM
    #233
    GravityGear
    Aurora, CO
    OP, now, do the same mileage and conditions and send in another sample. That will truly give you an idea of the effectiveness of the cooler. I have a feeling it will be marginal at best.
  24. Oct 3, 2020 at 5:01 AM
    #234
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    In general, the elemental analysis tells you little about the fluid and more about the condition of engine/transmission. When you see sightly elevated wear metals, especially during the first drain interval, it means NOTHING. These are wear-in metals. If coppper was 500ppm...ok there's a problem but 82 vs 68 is not really significant.
    The properties section tells you about the condition of the fluid and by all properties measured it was doing fine.
    The towing history of this transmission greatly exceeds what many will do with their Tundra and apparently the transmission and fluid are doing fine. Could it be the Toyota engineers are not incompetent, they really did look at this issue before making changes to the cooler and we all suck at armchair engineering and product development?
  25. Oct 3, 2020 at 5:34 AM
    #235
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    So how does that analysis factor in the seals, O-rings, solenoids, wiring, clutch material, adhesive, thermal expansion/contraction, etc... ???
    These are all long term potential heat related issues that will likely skate right through the warranty period fine... but still have a very high probability of causing problems in the future.
    This is a perfect example of the saying: "Ignorance is bliss". (not directed at you)
    Most people will sell or trade before its an issue and will never know or care.
    Anyone that has spent any amount of time inside a transmission (me) knows that the aux cooler is a massive benefit and running a trans at 250+ degrees is insane.
    Bammer, Dodger46, betotundra and 2 others like this.
  26. Oct 3, 2020 at 6:21 AM
    #236
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    We can guess all we want about the long-term consequences but the fact is none of us has access to any of the data they gathered during testing. What little data we do now have suggests heavy toeing is not having a detrimental effect on the transmission or the transmission fluid. Mike Swears has responded that they feel the temps seen during testing were fine - believe him or don't believe him - add a cooler or don't add a cooler based on how you use your truck - that's up to you - my only point is based on what little evidence we have available to us it seems like this is not a problem for most owners. The responses to this have ranged from failure is eminent for the majority of owners to nothing to worry about. Based on what we know as of right now I think most owners have nothing to worry about if you do light to moderate toeing occasionally.
    If I toed 5000+ pounds routinely, I might consider adding a cooler. Since I don't toe and my truck is a daily driver, I'm not worried. We are into 2021 models and there have to be a significant number of 2019s with decent mileage - I'm unaware of a significant number of failures.
    I'm just trying to add some perspective to the idea that everyone should run out and add a cooler immediately. While I do think it makes sense for some, each of us is going to have to evaluate how we use our truck and make a decision.
  27. Oct 3, 2020 at 6:56 AM
    #237
    betotundra
    betotundra Toyota for Life
    I would venture saying this IF the analysis was made at Toyota's sugested service mileage in the ownner's manual, which I read is at:
    • Replace transmission oil every 60,000 miles if towing, 90,000 miles if not (Don't quote me on this one though, I'm not sure).
    Meanwhile, because this results are on a 18K miles fluid, definitive conclusions are still up in the air, at least to me.
    GODZILLA and Cpl_Punishment like this.
  28. Oct 3, 2020 at 7:04 AM
    #238
    betotundra
    I agree with all you said, but also believe that it's too soon to see 19s failures.
    Also, as far as I know the daily driver use you give to your Tundra doesn't excempt her of ATF heating issues if a lot of stop and go traffic is involved, though they wouldn't be as prominent as in a towing rig. I might be wrong too. Cheers.
  29. Oct 3, 2020 at 7:08 AM
    #239
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I googled "toeing" and all I got was a bunch of foot pr0n.
    Bammer, Dragracer_Art, Azblue and 6 others like this.
  30. Oct 3, 2020 at 7:50 AM
    #240
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2021 Super White TRD Pro
    In progress…
    I had a girlfriend when I was a young lad that could work magic on my groin with her toes under the table sitting across from me as we ate supper with her parents.
    Alex38, Bammer, Green Thunder and 5 others like this.
Thread Status:
