Blackstone ATF Report!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Oct 1, 2020.
Thread Status:
Not open for further replies.
  1. Oct 1, 2020 at 5:10 PM
    Greg Marmalard
    Greg Marmalard [OP] New Member
    2019 Tundra TRD Off Road Double Cab
    Howdy,
    Somehow the particulars of my Tundra got lost in the shuffle so I'm waiting to hear back what they think with specifics but here it is!
    Comments welcome as it's Greek to me other than they said it fine! :D
    Note I did some long heavy hot towing this summer in Tow Haul in D...
    arrampico, Black Wolf, equin and 10 others like this.
  2. Oct 1, 2020 at 5:15 PM
    Blueknights75
    Ron
    Clayton, NC
    How many miles on the transmission fluid that you had tested?
  3. Oct 1, 2020 at 5:16 PM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Thank you, that’s pretty much what I expected.
  4. Oct 1, 2020 at 5:17 PM
    Greg Marmalard
    About 18,000. A good 3000 towing a 7000lb Airstream trailer this summer. And maybe 2000 last year with a 5000lb version....Hot days, long grades...
  5. Oct 1, 2020 at 5:22 PM
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Awesome ,thank you much for doing this
  6. Oct 1, 2020 at 5:27 PM
    Vizsla
    Vizsla 2 = 2.5
    I’m shocked! LOL kidding. @Greg Marmalard if you have the ability could you please check the ATF thermal degradation number?
  7. Oct 1, 2020 at 5:27 PM
    Redcon41318
    Redcon41318 New Member
    Was it without an aftermarket cooler?
  8. Oct 1, 2020 at 5:29 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    If this is your first test then it will be your baseline. At next test interval, compare follow up test with baseline for any abnormal/significant changes of ppm mineral content in oil.
  9. Oct 1, 2020 at 5:29 PM
    Greg Marmalard
    Yes!
    This is a sample from BEFORE I installed the cooler!
    So this represents ATF with NO COOLER under harsh conditions....other than the stock heat exchanger....
    G
    Txexplorer23 and Saltyhero13 like this.
  10. Oct 1, 2020 at 5:46 PM
    Vizsla
    Vizsla 2 = 2.5
    If you have OBD Fusion, or Techstream, maybe some others you can see the value. Basically a time at temp countdown that shows proof of thermal degradation.
  11. Oct 1, 2020 at 5:47 PM
    TTund16
    TTund16 New Member
    Thanks for doing this @Greg Marmalard
    Blackstone says atf was in pretty good shape ...
    Even though there is only 18K on this ATF may be Toyota knows what they are doing since 5000 miles of the 18K was towing in "hot days, long grades".
  12. Oct 1, 2020 at 5:59 PM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    Please post this on bobistheoilguy.com
  13. Oct 1, 2020 at 6:05 PM
    timsp8
    NY
    Watching for more analysis.
  14. Oct 1, 2020 at 6:06 PM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    OP are you going to email them more info so they can update it?
  15. Oct 1, 2020 at 6:32 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Interesting Flash point 410 F.
  16. Oct 1, 2020 at 6:39 PM
    Vizsla
    Vizsla 2 = 2.5
    Flash point has nothing to do with operation in vehicle, more about storage, handling, and transportation. The temp required to give off enough gas to burn when exposed to an ignition source if left open in a room basically. It is a high value though.
    FrenchToasty and Cpl_Punishment like this.
  17. Oct 1, 2020 at 6:43 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Well that is interesting..... It came back exactly how I thought it would. Not really showing much in the analysis. From someone that has spent 15+ years in the oil and petroleum industry I figured the Toyota fluid would be just fine. Only time will tell what happens with the increased heat.....
    Flashpoint is interesting. I would be curious to see some analysis of other trans fluids as that does seem high.
    pickupjason and Cpl_Punishment like this.
  18. Oct 1, 2020 at 7:02 PM
    betotundra
    betotundra Toyota for Life
    Thank you very much for taking the time and money to test your ATF OP.
    Would've been better to post this on the original post you created a couple weeks back though.
    To me this is everything but conclusive. Did anybody really expected the ATF to be cooked after "only" 18K miles and "just" 3K of them being towing? That really would've been outrageous, not a chance this was going to be the case.
    I'm still pro ATF cooler for those who doesn't have it, and I believe that basing the decision of installing it, on these results, is a bit premature. IMHO
    Bakershack and snivilous like this.
  19. Oct 1, 2020 at 7:13 PM
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
    Blackstone Laboratories Analysis -brought to you by Toyota :D
  20. Oct 1, 2020 at 7:16 PM
    Redcon41318
    So does this mean we 19 post owners dont need a trans cooler now, wow so glad i dont need to spend $1000s.
    Black Wolf, Jtundra81 and glowblue like this.
  21. Oct 1, 2020 at 7:22 PM
    glowblue
    glowblue From time to time
    VA
  22. Oct 1, 2020 at 7:41 PM
    Jtundra81
    Joe
    Yes , based on some previous comments and opinions , not only the oil would be burnt , expectations was transmission to fall apart in 10k , well that report proved that the oil is still under good condition knowing what it went through from heavy towing by OP.
    I never reached more then 235 myself for short period on converter towing ,so I will not be worrying much knowing what OP put the truck through.
    I will be having the dealer drain and fill each 30k and call it a day
    Black Wolf and blanchard7684 like this.
  23. Oct 1, 2020 at 8:39 PM
    Vizsla
    Vizsla 2 = 2.5
    No. You need a cooler that might void your warranty, and should probably switch ATF fluid also to further the chance of voiding your warranty. Lol. :notsure:
    Txexplorer23 likes this.
  24. Oct 1, 2020 at 9:25 PM
    Blue Thunder
    Washington
    Hmm, I think I'll wait until I see the revised analysis with the Universal numbers set to the correct fluid. For engine oil, the first 4-6 elements on the list are wear metals. You want those low. The remaining elements are all the cool chemistry chit the oil manufacturer adds to enhance the base oil's properties. If the oil is still good, I'd say those numbers should be higher than the Universal numbers based on the low miles. Or at least very close to the Universal numbers.
    Correct me if I'm wrong, but those look low. Plus we don't know what the viscosity numbers should be....
  25. Oct 2, 2020 at 2:05 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Copper is a tad high compared to 'averages'. Wonder what that wore off of..... Hmmm.
  26. Oct 2, 2020 at 4:02 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    I appreciate the OP sending this in. However, I don't think this says much as there is only 18k on the oil. Does anyone really expect ATF to go bad that soon? Would be interesting to see what the oil looked like at 50K or more.
    Blueknights75 and betotundra like this.
  27. Oct 2, 2020 at 6:16 AM
    4WDWalrus
    The Silver Walrus
    I don’t buy this either with 18k miles. Try again when at couple 100k or couple millions.
    Also, need to look into the Chief engineer’s interest in Blackstone Industries as stockholder or chairman.
  28. Oct 2, 2020 at 7:15 AM
    Hartsy8
    Hartsy8 Resident Hockey Guy
    Max
    2020 MGM 1794
    Again, unbiased opinion here.. I am only following this stuff out of curiosity.. I do not tow anything yet and likely won't with any significance in the foreseeable future.
    I do find it a little funny that both trains of thought are pretty much telling themselves whatever they need to in order to confirm their initial opinion. I have no doubt in my mind that no matter what the results of this or any analysis done, no matter the conditions or dependent variables, those in the cooler camp would still be pounding the table saying evidence is inconclusive and a cooler should still be installed. On the flip side those who think the cooler is vestigial will use any positive confirmation that they are right..
    I have not the slightest clue on the mechanics of the ATF or the property of the specific being used. An unbiased view of the information presented, in the state of this ATF at the time the sample was pulled, would suggest that the cooler is not necessary.. I have no doubt that samples exist out there that would suggest the opposite. If you are looking for a truly viable answer, it will not be found in the results of a single analysis. As always, I'm sure the real answer falls somewhere in the middle. I would like to hope that the Toyota engineers put in the leg work to find that middle ground and make the call on whether the component is truly necessary. Meh :notsure::notsure:
  29. Oct 2, 2020 at 7:35 AM
    timsp8
    NY
    I have an 18 so I have the stock cooler, but if I had a 19/20 I’d be wondering why Toyota engineers thought the tundra needed a trans cooler for 12 MY (07-18), then the same trans and drivetrain suddenly didn’t need it anymore in 19. Some have speculated that they adjusted some setting inside the transmission, but there was a couple of techs in the atf cooler thread that said they found 0 evidence of any adjustments. One post said Toyota will usually issue something internally if there was a change so the techs know about it, and nothing has been said.
    SomeGuy4, drowhawk and AZBoatHauler like this.
  30. Oct 2, 2020 at 8:06 AM
    blanchard7684
    blanchard7684 New Member
    Be good to know the total acid number and total base number is over time.
    I did a long trip across the state yesterday. I noticed that at 248 converter temps there seems to be a strategy that results in very fast drop in temp down to pan temps.
    Pan temps were steady in range of 222-228.
    this was ambients of 82 to 87.
    my previous data was in 105F and high loads and I had only seen pan temps rise 8 degrees.
    looks to me like ambient temps don’t make as much of a difference as you’d think.
    and it looks like there is a lot of strategy in transmission mapping for managing temps.
    my concern over this issue is decreasing rapidly.
Thread Status:
