Still learning
Discussion in 'Performance and Tuning' started by Quicksand2020, May 10, 2020.
  1. May 10, 2020 at 8:57 PM
    Quicksand2020
    Quicksand2020 [OP] New Member
    Chuck
    Quicksand 2020 tundra limited crewmax
    Floor mats bed liner bed cover step bars black badges rain guards
    What is the best air intake system or is it all personal preference without breaking the bank. But also if your changing the intake of air do you have to compensate that with a hotter spark ?
  2. May 11, 2020 at 1:08 AM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Welcome brother general consensus keep what you got spend the extra couple of hundys on guns/ammo/beer/bbq
    cuz well Murica
  3. May 11, 2020 at 2:44 AM
    linwozzle
    linwozzle New Member
    Linden
    2014 SW Tundra Platinum 4x4 CM
    Mostly for sound. I have Volant, but TRD and S&B seem the most popular
  4. May 11, 2020 at 3:01 AM
    rodl12
    rodl12 New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    With all my research and reviews I read I went with S&B. IMHO performance and economy is a definite improvement over the stock and even the TRD CAI.
  5. May 11, 2020 at 4:26 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Dont forget the hookers.
    Trooper2 likes this.
  6. May 11, 2020 at 8:15 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Stock is already a cold air intake.
    back in the day a vehicles ecu was dumb and slow. Intake manufacturers capitalized on this fact by changing the way the air goes thru the mass air meter. The ecu would make adjustments based on a false lower load value which would make power.
    our ecu is fast and smart. And adaptive, it learns. When it sees these ‘false values’ it realizes they’re false by cross referencing other sensors. Sometimes it runs worse as a result. Most don’t. But some do.
    you’re better off doing
    stock air box mod
    Throttle body coolant bypass mod
    Catback exhaust
    Gearing
    Tuner
    call for details. 760-877-4234
    Trooper2, snivilous and Rex Kramer like this.
  7. May 11, 2020 at 8:59 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    What is the air box mod?
    What is the benefit of the throttle body coolant bypass mod?
    I already have an excellent BAMuffler catback exhaust, 4:30 gear, dry AFE filter and a tune.
    prevent and Rely01 like this.
  8. May 11, 2020 at 10:03 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    and blow...
  9. Nov 28, 2020 at 8:42 PM
    sharkmango
    sharkmango New Member
    2014 Tundra TRD 4x4 White
    Inquiring minds would like to know...
  10. Nov 28, 2020 at 8:57 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
  11. Nov 28, 2020 at 8:59 PM
    sharkmango
  12. Nov 28, 2020 at 9:02 PM
    Trooper2
    JR
