Aftermarket UCAs
Discussion in 'Suspension' started by 14limited, Nov 22, 2016.
  1. Nov 22, 2016 at 5:25 PM
    14limited
    14limited [OP] Diehard Florida State fan
    Matthew
    14 limited 4wd
    3" OME magnum front bumper and steps spyder headlights MB TKO wheels
    Is that my only option to fix this angle
  2. Nov 22, 2016 at 5:35 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
  3. Nov 22, 2016 at 5:42 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Need more pics and info. Is there a jack lifting the truck?
  4. Nov 22, 2016 at 6:41 PM
    14limited
    Matthew
    14 limited 4wd
    No that's on solid ground I have a 3" OME lift
  5. Nov 22, 2016 at 8:16 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, 3" is generally considered borderline. Less and no UCA more and you gotta do UCA's. I just did my front and I did replace my UCA's. I got about 3-3.5" from the new coilovers. My front definitely doesn't have that kind of downward angle. I don't wanna tell you that you need 'em and run the risk of being wrong. Best get some more input from others that know more than I do. But, my guess is that you do need 'em. They certainly wouldn't hurt.
  6. Nov 23, 2016 at 6:10 AM
    Aurora CO
    I have the same setup. New UCA's and skids will be put on sometime before next spring. I haven't experienced any contact issues with the UCA hitting the coil with suspension fully distended when wheeling, but new SPC UCA's will get you the best alignment and more clearance. Well worth the money.
    T-Rex266 likes this.
  7. Nov 23, 2016 at 11:19 AM
    14limited
    Matthew
    14 limited 4wd
    I have no problems with UCA hitting anything just was curious about the angle
  8. Nov 23, 2016 at 11:38 AM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    After 2 1/4" we start suggesting UCA's. 3" of lift on stock upper control arms is definitely pushing that balljoint to its limits. Especially when the shock is drooping out.
    A set of uniball control arms will fix this. I personally, would never do a spindle spacer. The uniball arms are designed to allow you to get your alignment back in specs on lifted applications. Black Friday deals start in 6 hours :thumbsup:
    TheBeast and Black Wolf like this.
  9. Nov 23, 2016 at 12:07 PM
    14limited
    Matthew
    14 limited 4wd
    Yea I won't do the spindle spacer just looks ghetto IMO
    Black Wolf likes this.
  10. Nov 23, 2016 at 6:22 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I didn't even know there was such a thing as a spindle spacer. Seems like such a bad idea I'm really surprised they make 'em.
    TheBeast likes this.
