Thoughts on spindle spacers???
Discussion in 'Suspension' started by csuviper, Nov 25, 2015.
  1. Nov 25, 2015 at 10:58 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    "This is what our spindle spacer does! takes away all of the stress a levling kit puts on your ball joints without having to buy the expensive uni-ball upper control arms! They are much easier to install too!"
    Black Wolf likes this.
  2. Nov 26, 2015 at 12:52 PM
    Not sure..havent heard of this, but I would go with I know what can work..
  3. Nov 26, 2015 at 1:22 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    My friend worked for East Coast Off-Road, and he told me the spindle lift was the best way to lift a 2wd. Somewhat expensive, around $700 just up front. Was looking at going that way, but like the ultimate lift from Toytec.
  4. Nov 26, 2015 at 4:22 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Yeah I'm going to pass. Additional leverage that was never intended to be on the spindle, and further it will totally screw off the suspension geometry likely leading to camber/caster issues as the suspension moves through it's travel range
    JH5370, Sefferston and TruckLife900 like this.
  5. Nov 26, 2015 at 4:24 PM
    Relentless
    Eric
    The early IFS torsion bar pickups used to have leveling kits that were similar to this since the upper control arm on those trucks held all the load and therefore putting a spacer in there would directly achieve lift.
    On the newer trucks like ours with coilovers I'd stay away from something like these, like you said, stick to what works
    T-Rex266[QUOTED] likes this.
  6. Nov 26, 2015 at 4:26 PM
    Relentless
    Eric
    Spindle lift on a 2wd is great, but achieved entirely different than this item
    DVYota, 15whtrd, 14burrito and 2 others like this.
  7. Nov 26, 2015 at 7:55 PM
    csuviper
    Broomfield, CO
    Yea this was my initial thoughts as well.
    Relentless[QUOTED] likes this.
  8. Dec 2, 2015 at 6:09 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Longer moment arm, added force... lead to failures :boom:
    Thinking you may stress the ball joint mounting points on the UCA and that metal could fatigue and eventually crack under heavy use.
  9. Dec 2, 2015 at 10:20 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Bwahahahaha. Can we say bump steer?
    Fabricated extended spindles physically move the outer tie rod location. Bump steer is calculated as follows:
    If you change C without changing D.....you're introducing bump steer. Stupidest fucking thing ever.
    It's completely negligible. The moment arm along the LCA and UCA (pivoting on the frame) takes the load (along with the coilover that's basically trying to break the LCA in half).
  10. Dec 4, 2015 at 8:30 AM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    That's the easiest way I've seen bump steer explained. Thanks for the information.
  11. Dec 4, 2015 at 7:04 PM
    Maintaining parallelism between all associated parts is always a good thing.
    Relentless likes this.
  12. Dec 5, 2015 at 8:46 AM
    jberry813
    Lake Tahoe
    Some serious black magic voodoo shit huh?
    There are some other factors that can contribute to bump steer, but predominately the process above will get you 90% there, especially when dealing with OE mounting locations.
    Sefferston[QUOTED] likes this.
  13. Jul 26, 2017 at 7:38 AM
    Phillipk98
    Phillipk98 05 sequoia
    2005 sr5 sequoia
    Okay so that makes sense. No dropping the LCA down and using extended spindle, say like in a drop bracket lift would this cause bump steer as well?
  14. Jul 26, 2017 at 9:16 AM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Depends on where the steering link mounts to on the spindle. If you drop your LCA and extend out your spindle, the steering link has to move.
  15. Jul 26, 2017 at 10:53 AM
    Phillipk98
    2005 sr5 sequoia
  16. Jul 26, 2017 at 12:47 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Great explanation!
  17. Jul 26, 2017 at 2:40 PM
    jberry813
    Lake Tahoe
    Drop brackets lower the LCA mount points to maintain the ratio of the longer spindles.
  18. Jul 26, 2017 at 3:51 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Holy shit. You do live.
    jberry813 likes this.
  19. Jul 26, 2017 at 7:03 PM
    Phillipk98
    2005 sr5 sequoia
    Awesome!!!:thumbsup:
  20. Jul 28, 2017 at 3:06 PM
    jberry813
    Lake Tahoe
    Quit my old job and started a new one. Been all over the country in the last 2 months.
    Sefferston[QUOTED] and T-Rex266 like this.
  21. Jul 28, 2017 at 3:58 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Murica.
  22. Oct 1, 2017 at 8:54 PM
    csuviper
    Broomfield, CO
    @nate i do not have the spindle spacers nor do I reccomend them.
  23. May 8, 2018 at 1:19 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Can someone point me to some UCAs for a 2000 yrs tundra 4wd that I'm going to lift 3 inches in the front?
  24. May 9, 2018 at 9:57 AM
    jberry813
    Lake Tahoe
  25. May 9, 2018 at 10:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    T-Rex266 likes this.
