Your thoughts on 10,000 mile oil changes.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rider0120, Jul 30, 2018.
  1. Aug 23, 2018 at 10:05 AM
    #91
    Capt J-Rod
    Capt J-Rod New Member
    Ohio
    2018 Cement TRD Off Road Crew Max SR5 Tundra
    Husky Floor Mats, Diamond back lid, Coverking seat covers, More gas.
    I guess I didn't specify, but I just wanted the oil out of there in the first few miles. It looked fine and the filter was clean too. I just have these nightmares of metal shavings dancing around in there.
    Chu likes this.
  2. Aug 23, 2018 at 10:07 AM
    #92
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Look at the above sample result from Blackstone Labs, the numbers don't lie.
  3. Aug 23, 2018 at 11:24 AM
    #93
    Chu
    Chu New Member
    2014 Crewmax
    Amsoil.
  4. Aug 23, 2018 at 11:27 AM
    #94
    Chu
    Chu New Member
    2014 Crewmax
    You're not going to have shavings like a bad bearing, lol. But def a good move because a new motor will have material as you break it in. That's why many manufacturers still have the 1k mile service.
  5. Aug 24, 2018 at 4:49 PM
    #95
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    Oil is cheap, engines are expensive...
    Capt J-Rod likes this.
  6. Aug 24, 2018 at 5:19 PM
    #96
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    I drained the oil at 1200 miles and filled it with fresh. I did not replace the filter, easy pezy. When I took it in at 6months, they refused to change the oil even tho I said I was towing and driving down some dirt roads. I only had 4500 miles, so told them to do the 10 K oil change.
    I have rebuilt engines in the past, I wanted to get all the startup lubercants out. I’d rather spend an extra $30-35 on oil for peace of mind. I recycle my oil anyways.
    My Tundra runs fine!
