WTF
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nowhereman, Aug 27, 2021.
  1. Aug 30, 2021 at 7:33 AM
    #61
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    There should be NO NEED for a trickle charger unless your truck is sitting for months. That is the point here...either the battery has an issue or something else has an issue. If these trucks needed a trickle charger there would be threads all over the place and group buys for either battery shut-off switches or trickle chargers.
    A trickle charge will, yes, help the OP out (if he has access to a plug) in this situation. BUT, that will only treat the symptom, not the root cause.
  2. Aug 30, 2021 at 9:25 AM
    #62
    oh_really
    oh_really New Member
    NoVa
    2019 Tundra CrewMax Limited Cement
    I'll see myself out. But I'll be back with an update when it dies.
  3. Aug 30, 2021 at 11:10 AM
    #63
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  4. Aug 30, 2021 at 12:53 PM
    #64
    Nowhereman
    Nowhereman [OP] New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    I drove it around town last night for an hour. This morning I washed the beast then threw a battery charger on it.
    It read a pull of 7 to 8 amps, which is a lot.
    I'm leaving the charger on it all day. That should top it off for tomorrow's trek to LA.
    If it dies again, I get to exercise my new SA 9mm....
  5. Aug 30, 2021 at 12:57 PM
    #65
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Battery issues aside, I hope your wife’s operation is successful and she makes a 100% recovery.
  6. Aug 30, 2021 at 1:32 PM
    #66
    AZBoatHauler
    So.Arizona
    If I’m following this correctly - you drove the truck for 30 minutes after jumping it (when this problem first manifested) and then threw a meter on and the battery was right around 11 volts… no way in hell I’d be taking that battery on a road trip. I agree, it sounds like you have a bad cell.
    As people have told you - if you don’t value your time or effort, warranty the battery with the dealer and get another crappy one at no cost. If you do value your time and effort, buy a quality replacement and forget about it for the next 5 years.
    Tamutundra and 2mchfun like this.
