WTF
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nowhereman, Aug 27, 2021.
  1. Aug 27, 2021 at 6:51 PM
    Nowhereman
    Nowhereman [OP] New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Walked out to my Tundra 2021
    Been in driveway since Sunday
    Went to start it and… nothing
    Battery is dead as a doorknob
    Truck has 3000 miles on it since December
    Any thoughts
  2. Aug 27, 2021 at 6:54 PM
    2mchfun
    First thought, turn on headlight switch to confirm battery is dead.
    Hightide likes this.
  3. Aug 27, 2021 at 6:55 PM
    timsp8
    NY
    Leave something on? Don’t drive it enough to keep it charged?
  4. Aug 27, 2021 at 6:57 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Part it out.
    But seriously sounds like you need to get some smiles per gallon under your belt.
    shlunky, Darkness, YotaMan and 13 others like this.
  5. Aug 27, 2021 at 7:18 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Toyota batteries are hot piles of garbage, so I wouldn’t be surprised if you have a dead cell. Jump it tomorrow and take it to the dealership to get a new one under warranty.
  6. Aug 27, 2021 at 7:29 PM
    Jrfor0
    Jrfor0 New Member
    James
    Interior light or bed light left on?
  7. Aug 27, 2021 at 7:31 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2 ^^^^
    Saltyhero13 and Nowhereman[OP] like this.
  8. Aug 27, 2021 at 7:31 PM
    Nowhereman
    Al
    Monterey Bay area
    Headlights non functional
    2mchfun likes this.
  9. Aug 27, 2021 at 7:34 PM
    Nowhereman
    Al
    Monterey Bay area
    No I checked that
    Today it hit 95 I’m wondering if the battery is just a pos
    NewImprovedRon likes this.
  10. Aug 27, 2021 at 7:40 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Anything aftermarket. lights, remote starter?
  11. Aug 27, 2021 at 8:02 PM
    Tamutundra
    Tamutundra New Member
    Frisco Tx.
    19 super white CM TRDoffroad 4x4
    On my 08 I had about the same experience as you... I got stranded in H town and luckily for me the auto parts store came to me with a new battery... as we were pulling out the old one discovered the "J" bolt/ clamp that secures the center section across battery was extremely over tightened... after getting my 19 that was the first thing i looked at and damn if it wasn't too tight... apparently they use a pneumatic wrench thats set to an absurd torque... I would advise everyone to look at the damn battery cause if it's not cracked yet, it will be... setting up for extreme corrosion on cables/posts.
    2mchfun likes this.
  12. Aug 27, 2021 at 8:16 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    Take the battery to get tested and see if it will hold a charge, then again, new truck, under warranty, if you have a dealer close by might as well just take it to them instead.
  13. Aug 27, 2021 at 8:25 PM
    What the!?
    What the!? New Member
    2017 Pro
    Mine lasted 1 1/2 years. The OEM batteries are junk. I went to Batteries Plus and got the Northstar X2 AGM battery. It’s been 2 trouble-free years now.
    I would have taken it to the dealer and have it covered under warranty, but I didn’t want to waste my time for them take the car for a day, test the battery, order a new one, etc. only for the replacement battery to leave me stranded somewhere again later on.
    It was a 30 min trip to Batteries Plus and I was done.
  14. Aug 27, 2021 at 9:26 PM
    Nowhereman
    Al
    Monterey Bay area
    I had it jumped and it started right up. Drove for 30 min. around town and parked it.
    Pushed the start button and it started like nothing had happened.
    I have no aftermarket electronics on it but I do have the factory remote start.
    I have all the electrical testing equipment I could use at home so in the morning I'll test for voltage.
    There should be no reason for a new car battery to not last a week since last drive.
    Will keep you posted.
  15. Aug 27, 2021 at 9:45 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Only 3000 miles in 9 months means pretty low charging time, and all modern vehicles have some constant load on the battery when parked, pretty minimal, but constant. Lots of short trips too? That’s another bad one.
    A half-hour drive brought your battery’s state of charge to 25% at best, and that’s with an electron tail wind. ;)
    A slow charge (2-5A) overnight, then have the battery load tested.
    A battery maintainer or solar charger would be a great idea for a vehicle driven that infrequently.
    BravoDeltaRomeo and Geezer like this.
  16. Aug 27, 2021 at 9:52 PM
    Nowhereman
    Al
    Monterey Bay area
    Well, that's the first time in all the cars I have bought that the battery wouldn't last a week?
    There's more to it I'm thinking so I'll dig into the battery itself tomorrow.
    I'm betting I have a bad cell and the excessive heat today caused it to fail.
  17. Aug 28, 2021 at 10:47 AM
    Nowhereman
    Al
    Monterey Bay area
    OK, I multi metered the battery running and got 13.5 to 13.7 volts.
    Battery alone the best it would show is between 10.7 to 11.3.
    I'm thinking a bad cell.
    I'm calling the dealer now.
    Service guy said that with all the electronics in them now you have a constant drain with the computer being on all the time.
    They will check the electrical system for me but, he feels it needs to be driven more to support the charging requirement.
  18. Aug 28, 2021 at 11:18 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    The OEM batteries are hot garbage. I had issues with mine as well, including one embarrassing one where my battery died after watching one movie at the drive-in and I had to get jumped. I called Toyota, brought it to the dealership and it tested fine after they charged it. I held my ground that it’s unacceptable that I can’t let the truck sit for a weekend without it dying, or getting really weak. Eventually, they replaced it with one of their TrueStart batteries and an 84 month warranty.
  19. Aug 28, 2021 at 12:05 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    Once you get the battery issue resolved you may want to put a maintenance charger on the vehicle to keep the battery fresh while the vehicle sits unused. Something like a Battery Tender. I keep one on my lawn mower, tractor, and motorcycles during the winter when they are not used often.
  20. Aug 28, 2021 at 12:42 PM
    Spyker
    I’m a big fan of the CTEK tenders/chargers, they aren’t cheap, but it’ll last, they work very well, and you can buy some with neat features built into the charger (motorcycle, regular battery, reconditioning mode, AGM specific modes, etc)
    RdKing likes this.
  21. Aug 28, 2021 at 12:43 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    Okay so in a couple weeks my 2021 which I bought in early May will be parked in my driveway for 11 days without being started. Any preventive measures I should take? I will be driving it about 20 miles as the last trip before it is shut off in my driveway.
  22. Aug 28, 2021 at 12:47 PM
    Ct. Rich
    Ct. Rich New Member
    Maine
    2016 Limited TRD
    My 2016 battery was junk too. Had the dealer replace it and that one lasted about 18 months. Gave up on Toyota batteries…no more issues. Also, keep it on a tender if I know it’s going to sit a while.
  23. Aug 28, 2021 at 12:51 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    No.
    But everyone should own a good booster pack and some sore of volt meter/battery tester, just in case. So if you do come back and it's dead, you can easily boost it yourself.
    Black Wolf, Luckydog and ToyoMafia like this.
  24. Aug 28, 2021 at 1:17 PM
    2mchfun
    Anytime I ever left an auto for over a week I always disconnected one terminal. Went overseas traveling for two months once in dead of winter here, got out of airport, hooked up battery, started right up with no problems. Kinda strange to drive again after a few months of not though, especially considering the roads were iced over with freezing rain and snow.
    BravoDeltaRomeo likes this.
  25. Aug 28, 2021 at 2:06 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    My OEM battery from Dec. 2016 is complete junk. As it approaches 5 years of perfect service i want to strangle Mama Toyota. :hattip:
  26. Aug 28, 2021 at 2:46 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    My truck with the OEM battery sits for days on end and always starts. No issues, even sitting outside in the winter.
    Clemsonman14 and BravoDeltaRomeo like this.
  27. Aug 28, 2021 at 3:45 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    I just replaced my 2013 OEM battery last year, unacceptable.
    My SIL still has it in his garage as a helper battery if he needs one.
  28. Aug 28, 2021 at 5:20 PM
    Nowhereman
    Al
    Monterey Bay area
    Keeping this rig on a trickle charger is not in the cards as my parking location for the truck is about 100 feet up a slight hill adjacent to our condo.
    Driveway is small and holds the wife's Acura. The vintage 2000 Trans Am (immaculate condition) lives in the garage.
    The fact that we are talking about trickle chargers for a new car in CA. is total BS, don't you think?
    Tamutundra, Leo's first and 2mchfun like this.
  29. Aug 28, 2021 at 5:47 PM
    18" TRD Off Road Wheels
    My guess is that you have a sub par battery with some kind of defect. Dead or damaged cell. This isn't terribly uncommon with stock batteries, though many last for many years, many do not. My WRX's batter shit the bed after about a year. Replaced it and never had another problem.
    The other possible scenario would be that you are experiencing some kind of parasitic drain. This could be due to tons of things from loose connections, bad wiring, improperly installed aftermarket components, or even rodent damage.
    Tamutundra likes this.
  30. Aug 28, 2021 at 6:34 PM
    2mchfun
    If you can afford to park a fairly new Tundra most of the time, then you can afford to buy a decent battery. Just sayin' WTF!! :boink:
    Hell, buy and install a cut off too, end of problem.
    Suprafantx and GIN•OKUMA like this.
