WTB; Crewmax OEM running boards
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by YotaFan05, Jun 9, 2021.
Thread Status:
Not open for further replies.
  1. Aug 23, 2021 at 4:38 PM
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    I just installed some invisible running boards.:)
    gkelm and Oey12 like this.
  2. Aug 23, 2021 at 5:23 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    That’s the best looking most economical running board on the market for the Tundra. However the wife and kids need something better…
  3. Aug 23, 2021 at 5:27 PM
    CorpsTundra
    CorpsTundra New Member
    Michigan
    2021 Tundra CrewMax SR5-TRD OR - Cement
    I tried to get some of these steps, but they don’t make them for a CM for some reason. I saw some identical ones on a 2021 Sequoia TRD Pro and they had TRD stamped on one end.
  4. Aug 23, 2021 at 5:44 PM
    Oey12
    Oey12 New Member
    Joey
    New York
  5. Aug 23, 2021 at 6:15 PM
    CorpsTundra
    Michigan
    Yes I seen the conflicting info looking at them before.
    Is that the same part number as the ones you have?
  6. Aug 23, 2021 at 6:21 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    No I purchased the PT767-34190.
    CorpsTundra likes this.
  7. Aug 29, 2021 at 11:19 AM
    a_double
    a_double New Member
    Does anybody know the OEM PN's to build the running boards in post 1?
  8. Aug 31, 2021 at 9:44 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    See post #18
  9. Sep 1, 2021 at 9:31 PM
    dangggggggggg
    dangggggggggg New Member
    I am new to the forum, but I am looking for a set of predator steps for crewmax! I’m located in TX!
  10. Sep 2, 2021 at 5:28 PM
    a_double
    a_double New Member
    I don't think that post fully specs the set though. Am I missing something?
  11. Sep 2, 2021 at 7:37 PM
    CorpsTundra
    Michigan
    I looked into the PT767-34160 part number to see if they will fit a CrewMax. From what I gather that is the old part number for Tundra double cab steps and is now the part number for Tacoma double cab steps.
    I believe that part number PT767-34160 is a definite no-go for CrewMax trucks. For what it’s worth, folks also said they will not fit CrewMax trucks in the Amazon questions and answers and reviews.
    I spoke to a local Toyota dealership parts person and he said that Toyota has an aluminum running board for Tundra CrewMax trucks in the pipeline, but not yet approved or something to that affect. Could be blowing smoke too, who knows?
    Oey12[QUOTED] and a_double like this.
  12. Sep 2, 2021 at 7:51 PM
    CorpsTundra
    Michigan
    Check out post# 1 of the thread linked below for the explanation and attached parts diagram photo. The diagram photo shows the flat inner piece’s part number and price. Search a Toyota dealership’s website for the flat inner piece using the part number from the diagram photo. Once you can see the diagram with all of the separate parts then you should be able to see the part numbers for each individual part as well on the same page (usually further down the page below the diagram).
    https://www.tundras.com/threads/que...g-boards-step-assist-parts.19872/#post-457612
    If you find all of the individual part numbers and confirm them be sure to post them on here.
    a_double[QUOTED] likes this.
  13. Sep 2, 2021 at 8:01 PM
    a_double
    a_double New Member
    I spoke to my local Toyota parts dept and heard something similar about that PN. Only for DC, and originally intended for the Tacoma. He did mention some new cast aluminum boards but stopped short of mentioning that style for the CM.
    I'll hold out for a little and call other dealerships to see if they have additional info.
    CorpsTundra[QUOTED] likes this.
  14. Sep 2, 2021 at 8:03 PM
    a_double
    a_double New Member
    Gotcha.
  15. Sep 3, 2021 at 4:10 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    My apologies, I guess I miss read it…
  16. Sep 3, 2021 at 4:38 AM
    CorpsTundra
    Michigan
    No big deal, I thought the same thing as you with the listings saying they were for CrewMax. Figured I should post something about it so other people know.
    Oey12[QUOTED] likes this.
  17. Sep 3, 2021 at 8:15 PM
    CorpsTundra
    Michigan
    I believe that I figured out the part numbers. Price them out if you like, but I recommend skipping it and just having a toddler kick you in the nuts instead.
    2007-2021 Tundra CrewMax KG Classic Running Boards Parts Diagram and Part Numbers:
    1R. QTY(1) Running Board, RIGHT: 51771E-0C030
    1L. QTY(1) Running Board, LEFT: 51772D-0C030
    2R. QTY(1) RB Mount Bracket, RIGHT: 51793A-0C020
    2L. QTY(1) RB Mount Bracket, LEFT: 51793B-0C020
    3R. QTY(1) RB Mount Bracket, RIGHT: 51795A-0C020
    3L. QTY(1) RB Mount Bracket, LEFT: 51796-0C020
    4R. QTY(1) RB Mount Bracket, RIGHT: 51797-0C020
    4L. QTY(1) RB Mount Bracket, LEFT: 51798-0C020
    5R. QTY(1) RB Mount Bracket, RIGHT: 51787B-0C020
    5L. QTY(1) RB Mount Bracket, LEFT: 51788B-0C020
    6R. QTY(1) Toyota RB Protector, RIGHT: 51718B-0C020
    6L. QTY(1) Toyota RB Protector, LEFT: 51719C-0C020
    7R. QTY(1) Toyota RB Spacer, RIGHT: 51723E-0C010
    7L. QTY(1) Toyota RB Spacer, LEFT: 51724-0C010
    8R. QTY(1) Toyota RB Step Pad, RIGHT: 51773B-0C030
    8L. QTY(1) Toyota RB Step Pad, LEFT: 51774A-0C030
    Hardware:
    -QTY(16) Body Bolts: 90119-A0048
    -QTY(16) Bracket Bolts: 90080-A0062
    -QTY(18) Plastic Fasteners: 90080-46303
  18. Sep 3, 2021 at 9:24 PM
    a_double
    a_double New Member
    Much appreciated sir! I was afraid of the price, after looking up 51774-0C030, that's kinda why I haven't gone to this effort.
    I got some OEM door sill protectors. Those fit my budget easily. :)
    What to do about running boards...
    This image might provide some clarity to the bracket PN question: a1_583212E.jpg
  19. Sep 3, 2021 at 10:03 PM
    #49
    CorpsTundra
    Michigan
    No problem, I’ve been looking for them myself anyway. Best I can find close-ish to me are older sets or parts from wrecked vehicles. I looked up the parts, because I figured as long as I can get the 8 brackets and both aluminum substructures intact I can always order the plastic covers and make them brand new again for way cheaper. Either way they are definitely not worth buying new.
  20. Feb 15, 2022 at 5:45 PM
    #50
    FireCpt
    FireCpt New Member
    Michael
    Vine Grove, KY
    2020 SR5 TRD
    TRD Pro grill swap. TRD Pro wheel swap. Go Rhino RB20 running boards.
    I've been thinking of swapping out these OEM running boards for something else. I'm in Ky if anyone wants to offer a swap lol.
  21. Jun 2, 2022 at 11:30 AM
    #51
    cartage1
    cartage1 New Member
    Ohio
    2023 TRD Pro
    Last post was Feb 15th, but throwing this out just in case..., have a set of Predator Steps for Crewmax for sale in the Cleveland area in case anyone is interested and can pick them up. Stay well!
Thread Status:
