Wrong battery??Help a novice please!
Discussion in '1st Gen Tundras (2000-2006)' started by Tawondra05, Feb 4, 2022.
  1. Feb 6, 2022 at 11:58 AM
    #61
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    For what it is worth I think you are doing a great job..
    I hope you get it fixed soon..
    tvpierce and Aerindel like this.
  2. Feb 6, 2022 at 12:00 PM
    #62
    Tawondra05
    Tawondra05 [OP] New Member
    Thank you. Yes. I checked out that video when i was trying to get the buggers out....Unfortunately, the 2 part shops that are opened today both told me i had to bring them in to see if they had replacements. Makes me laugh.
    Aerindel likes this.
  3. Feb 6, 2022 at 12:01 PM
    #63
    Tawondra05
    Thank you! 8)....I wish I would of stayed in auto mechanics in high school.
  4. Feb 6, 2022 at 12:02 PM
    #64
    Tawondra05
  5. Feb 6, 2022 at 12:45 PM
    #65
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Since checking for continuity plays a big part in many checks we make on our Tundras(and many other products also), we can work on giving you that fuzzy feeling if you wish. For starters, mind showing with a pic the meter you're working with and a couple more pics of the green fuse link. I looked in my 2004 hoping to see a duplicate of what you have in order to help show how to check green one but no luck, totally different.
    bmf4069 likes this.
  6. Feb 6, 2022 at 12:56 PM
    #66
    Tawondra05
  7. Feb 6, 2022 at 1:05 PM
    #67
    ezdog
    ezdog New Member
    Gateway To The West
    So turn the knob to the 2000k setting
    Now touch the leads together and meter reading should go to 0 ish which means continuous a connection between the leads.
    If so then the meter is working
    Now touch one lead to the big ground tab and then the other lead to each other contact one at a time
    The good ones will read exactly like the leads touching each other did but the bad or open or blown ones will not change at all
    does this make sense to you?
  8. Feb 6, 2022 at 1:19 PM
    #68
    Tawondra05
    I believe so. This follows the same advice i read on line but when i test the black( which is visually fried )as a control of sorts, it does the same....so i am doing something wrong. Thank you so much for your help. I'm gonna get my neighbor to test it tonight. Can't get to a parts store today anyway.. Thanx again.
  9. Feb 6, 2022 at 1:31 PM
    #69
    ezdog
    ezdog New Member
    Gateway To The West
    I guess it depends on what you mean exactly?
    The only thing that matters is whether the meter displays 0 or OL when testing between 2 points.
    so when touching the leads together does it display 0 or not?
    If yes then the meter works and you have seen it read a good circuit of just the leads touching
    So now touch black to the big tab of black fuses and red to each other contact point and the meter will tell you the same thing hopefully
    I understand waiting though too and knowing for sure from a parts place just make sure to take the parts with you too!
  10. Feb 11, 2022 at 12:53 AM
    #70
    Aerindel
    Aerindel New Member
    Montana
    Any updates to this story??
  11. Feb 15, 2022 at 1:35 PM
    #71
    Tawondra05
    Thank you ezdog for those instructions. I ended up taking them in to be tested. Finally, got back to working on it. Replaced the main black fuse. Still no luck...( same as before replacing the fuse) engine sounds like it's trying to turn over but it does not start. I'm gonna go through the thread here and do more research but I'm thinking my next course of action to to address the small box of fuses under the main fuse box. Thank all!
  12. Feb 15, 2022 at 1:46 PM
    #72
    Tawondra05
  13. Feb 20, 2022 at 3:34 PM
    #73
    Tawondra05
    Hello all. Thank you so much for all your advice, support and assistance. My wonderful Tawundra ( my truck) is up and running...It seems the ever elusive Alt fuse I was looking for was part of one of the big main fuses (the black one) that I ordered and then replaced. I just needed to go back and make sure everything that I had done was snug. Tightened up all the cables ect. 8) Thanx again.
    dbittle, w666, des2mtn and 3 others like this.
