Would FFV prevent you from purchasing?
Discussion in 'General Tundra Discussion' started by gdog_Tundra, Dec 28, 2018.
  1. Dec 28, 2018 at 5:34 PM
    Yep!! Cool!! Way cool...
    NewImprovedRon likes this.
  2. Dec 28, 2018 at 7:13 PM
    Donkeypunch
    Donkeypunch New Member
    When I go SC and Full tuning is available, I would be wishing even more mine is FFV to have the lines and Teflon coated, anodized fittings, etc.
    mundra likes this.
  3. Dec 28, 2018 at 7:48 PM
    Donkeypunch
    Nice! The problem now is that the blend is not consistent now. I can vary from E85 to E70 depending on the season and gas station. My older AEM doesn’t support a flex fuel sensor so I used to have to measure the E content at the pump, whip out the laptop and adjust the timing accordingly. The GM flex fuel sensor is the standard to use with tuners today.
    Because of this, I just bought E90 by the barrel to be consistent. Still way cheaper than race fuel. On VP C16 i made 1115rwhp pushing the injectors past 90% duty cycle.
    Back to the point, I would think Toyota’s game on Flex Fuel would be on par with GM.
    Luckydog and Black Wolf like this.
  4. Dec 28, 2018 at 7:50 PM
    Blueknights75
    Ron
    Clayton, NC
    I specifically wanted a non FFV Tundra when I purchased.
    ATHiker likes this.
  5. Dec 28, 2018 at 7:53 PM
    flying dave
    flying dave New Member
    NC
    As nice as I possibly can....
    What are the specs on the double breasted long legger????:bowdown::bowdown:
  6. Dec 28, 2018 at 7:58 PM
    Donkeypunch
    It’s all in the Turbo. All 80mm of it. LOL. 54psi. The rest is standard, ported head, cams, Intake, massive intercooler, etc.
  7. Dec 28, 2018 at 8:14 PM
    Donkeypunch
  8. Dec 28, 2018 at 8:38 PM
    flying dave
    NC
    Nice but I was talking about the other thing in your avatar....:cool:
  9. Dec 28, 2018 at 8:50 PM
    Donkeypunch
    LOL
  10. Dec 11, 2019 at 7:50 AM
    Target612
    Target612 New Member
    I have a 2016 FFV 5.7L V8 4x4 crewmax. I feel the need to notify the public that my car was having really really bad rough starts in the morning - didn’t matter if weather was cold or warm - first start of the day always sounded like the engine was choking. I googled online and found this site and many other message boards about the Alcohol Density Calculation problems and the need to “reflash” the ECM (see Toyota Service Bulletin T-SB-0058-13).
    I took the truck in to the dealer yesterday, they did a cold start this morning after it sat in the lot overnight, and concluded it had this problem that is specific to FFV Tundra engines.
    The service advisor said that Toyota just came out with a new TSB a few days ago updating the old TSB so that it now covers the fuel pump and the “reflashing” of the ECM, it now also covers all FFV Tundras from 2009 - 2019. The new TSB is T-SB-0166-19.
    So I hope this info helps, hit up your dealer if you are having enginestart-up problems with your FFVengine Tundras, and pass the word around!
    If I had known about these engine issues, I would have NEVER bought a FFV engine!!!
    This TSB engine fix is only good if you’re under 96 months or 80,000 miles!!!
    AZBoatHauler likes this.
  11. Dec 11, 2019 at 9:20 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Would not steer away from a FFV. Only differences are the ECU has a tune to deal with E85 when the gas tank sensor senses it in the tank. There is a larger 2 speed fuel pump in the tank to deal with the additional fuel delivery requirements of E85 roughly 25 to 30% more fuel needed. The injectors are larger to deal with the additional fuel requirements of E85.
    Alcohol density reading with the tundra is more of the issue. Toyota has a problem with it. I have had to have mine reset several times at the dealer.
    Luckydog likes this.
  12. Dec 11, 2019 at 1:59 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I have a 13 crewmax SR5 TRD with 85,000 miles and haven't had any issues.I like the fact that it has the larger injectors and that the entire fuel system is coated to prevent rusting because of the E85 fuel.
    Luckydog and NewImprovedRon like this.
  13. Dec 11, 2019 at 3:30 PM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  14. Dec 11, 2019 at 5:32 PM
    Luckydog
    Luckydog New Member
    Dominic
    2015 DC TRD Offroad.
    Ranch Hand Summit front and rear bumpers. Diamondback SE tonneau cover. Rigid DOT fogs. LED headlight/fog replacement bulbs. Matt Gecko hood, and bed LED's. Foot well led's, and interior LED buld replacement. (warm) Broke the front shock of the 3" spacer lift, so replaced with 6112/5160 and 1' block rear. KO 2's. Speaker replacement, added amp and (2) 10's under seat. Weathertech floor mats. Salex organizers. Ziebart undercoating. RCI front, transmission/diff, and gas tank skids received, waiting for spring install. Compustar remote starter. front/rear dash cam.
    The fix works regardless of mileage, you just might have to pay a little bit out of pocket. I dealt with this issue last week. The dealership reflashed the computer, and pressure tested the fuel pump. The dealer only charged me the diagnostic fee of $145. I would not hesitate to buy a Ffv. The FFV issue is a minor inconvenience at best.
  15. Dec 11, 2019 at 5:56 PM
    CLowery
    CLowery New Member
    Bates City, MO
    2018 Cement Tundra TRD
    None (yet)
    I didn't realize that the Tundra had the non- FFV option when I bought mine. All the trucks at the dealership I purchased from were all FFV. Had I known, I would have gone with a NON-FFV. I haven't had any issues but I also will not run E-85 in my vehicle.
    Strangely enough, I run 100% Methanol in my racecar.FB_IMG_1494134674482.jpg
  16. Dec 11, 2019 at 8:02 PM
    ZPMAN
    Minnesota
    If I had a do over I would avoid it like the plague.
    GODZILLA likes this.
  17. Dec 12, 2019 at 3:34 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
  18. Dec 13, 2019 at 7:21 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    The same issue here. I have stations here that sell no alcohol gas. I would use it for my boat when it is stored for the winter. But my choices are wither aviation fuel (I think that was like $7/gal) or very high octane gas, which again was darn expensive and not needed by the outboard.
  19. Dec 13, 2019 at 8:04 AM
    #49
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I wouldn’t have known about the potential issues of the FFV when I was shopping. So I probably would have bought one if everything else was right like it was when I bought my Tundra (right time/ right place/ right price, literally just strolled in to a dealership on a whim and left with a truck). But after hanging around here and seeing the alcohol density issues I would make sure to stay away from those now. Hell, I have enough issues with alcohol. I don’t need my truck to have one, too. :rofl:
    ZPMAN and Luckydog like this.
  20. Dec 13, 2019 at 8:11 AM
    #50
    Rubberdown
    You’re saying all of these changes were implemented on the tundra? I don’t believe this is correct information.
  21. Dec 13, 2019 at 8:54 AM
    #51
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
