Would a bed shell/cap/topper for an 2006 Access Cab fit a Double Cab
Discussion in '1st Gen Tundras (2000-2006)' started by tarpaw, Jun 11, 2022.
  1. Jun 11, 2022 at 7:12 AM
    tarpaw
    tarpaw [OP] New Member
    Rick
    2006 Grey Tundra SR5 V8 4X4 Double Cab
    Just found a deal on a used bed shell/cap/topper that's about 45 minutes away, in good shape, and is the same color as my 2006 Double Cab but it came off of an Access Cab. Bed length is right and to my eyeballs it looks like the rear of the Double and Access cabs have similar lines. Gonna go look at it tomorrow and hopefully pay the man, clamp it on, and drive it home, but is there a chance it's not gonna be compatible?
  2. Jun 11, 2022 at 7:17 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I believe that @FirstGenVol is running a Double Cab shell on his Access Cab, and the reverse is true for @MrDirtjumper??
  3. Jun 11, 2022 at 8:09 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I'm prettysure there is a small difference.
    Don't take my word as gospel, but I remember there is a little bit of difference where the shell meets up to the cab of the truck . . . and the length is slightly different as well, not by much, but it is different.
    Someone here a while back had posted either a AC shell on a DC truck, or vise versa.
    I remember there was like a little bit of the shell hanging over the tailgate, and also the gap between the shell/cab was slightly off.
    I think he posted a photo or 2 . . . it wasn't much, probably depends on have particular you are or aren't.
    I think left to right they are virtually identical.
    Good Luck, and keep us posted.
  4. Jun 11, 2022 at 8:17 AM
    At minimum there's a 2" difference in bed length. Double Cab has a 6'2" bed and Access/Regular Cab is 6'4" (per my recent Tonneau endeavors).
    I'd been casually hunting an Access Cab topper for a while but only thing popping up is already Double Cab. One popped up recently on CL north of ATL but the person who listed it wasn't replying to messages. Sucks to be me I guess.
    But yeah, expect the fitment won't be perfect. @FirstGenVol has is running a DC shell on his AC truck, there's a small gap for his, I believe on the side up against the back glass. He showed a picture of that really recently. It looked to be about a 1" gap to me.
  5. Jun 11, 2022 at 8:18 AM
    Bubbadog
    Bubbadog New Member
    You can make it "kinda" work.
    It will be off slightly in length and the profile of the cap will not match with the rear cab of the truck.
  6. Jun 11, 2022 at 8:28 AM
    I now see after searching, this question gets asked pretty commonly.
    Here's one of FGV's replies on it saying there's a gap that will cause leaks putting a DC shell on AC truck: https://www.tundras.com/threads/will-03-ac-cap-fit-05-dc.92097/#post-2321010
    And for Mr Dirtjumper the AC shells fit better on DC than in the reverse, but has an overhang, here's a pic:
    https://www.tundras.com/threads/are-camper-top.86396/#post-2179334
    I know for a fact FGV posted pics of his within the last 3-4 weeks. Just can't find. And here's his comment saying "DC cap on AC and you'll have leaks": https://www.tundras.com/threads/camper-shell-access-cab-vs-crew-cab.105214/#post-2706752
  7. Jun 11, 2022 at 1:30 PM
    tarpaw
    Rick
    Thanks to all for the info. Very helpful!
    What I've absorbed is that the AC bed is a tad longer than the DC so an AC topper on a DC might hang over a bit, but how much may depend on the brand of the topper. The picture on the for-sale listing says its FEDCO on its back hatch but my searches find a CT company that's now defunct.
    It's less than 45 minutes away, so I'll just drive over tomorrow and try it on for size. If I can live with the overhang, I'll probably pull the trigger and live with it since DC toppers seem to be pretty rare.
    Next question, which may be worthy of a separate thread (if so, let me know)...
    The topper has a split front window that opens a bit in the middle toward both sides, maybe 2 feet total. My truck's rear window is electric and opens all the way across and as far down as I want it to. I'll put that to use at times with long fishing rods, one being a one-piece rod about 12' in length. I'd like to be able to weather-seal around the windows to cut down the wind noise while driving and keep the rain out if I can't close both windows.
    On my old F-150, the cab and topper windows were of a similar size and nature and I found a clear plastic inflatable TrukBoot that was just the right size and worked perfectly. I am not above engineering something out of pool noodles or pipe insulation to accomplish what I need, but is there any sort of more elegant solution?
    Thanks again for all your help!
  8. Apr 11, 2023 at 5:46 PM
    thxcolm
    thxcolm New Member
    central valley, CA
    2001 Toyota Tundra SR5 V8
    I think this is a great thread to revive now that we're looking at shell camping season... and i'll piggyback a question on it.
    It's mostly about getting the perfect fitment with shells. My question is do we have to remove our bed rail frames for the perfect overhang for some camper shells? When I purchased mine, the person that I bought it from had the same AC size as mine, but the bed rails were still on his truck.
    I see some that some fit perfect at just the right angle over the bed. But like on mine it really looks like it would benefit by the rails being removed.
    Mine (the white shell)...
    Guessing that bed rails are off on these (these aren't mine the grey shell ones)...
    I was reading the other day that once the bed rail covers/liners come off you basically can't put them back on because the clips get destroyed in the process. Does anyone have a solution for either recycling/using the rails again every year, or do people just take them off and forget about them?
  9. Apr 11, 2023 at 5:55 PM
    I've found the opposite in my area. Nothing but DC caps. I almost never see AC caps, anywhere.
    I've had both rails off twice now, with no damage. I had to take them off to properly compound and polish the haze out of my paint. I actually pulled the driver side off 3 times in total. No damage. Popped right back on.
    Work slowly. Both times I removed mine, I started at the tailgate end, popping from the bed corner. If I remember, I pulled horizontally toward the tailgate while pulling up.
    Not trying to be a naysayer on both of y'all, but what you've each posted is totally the opposite of what I've personally experienced :rofl:
  10. Apr 14, 2023 at 6:35 PM
    TheLooseGoose
    TheLooseGoose Everything remain' raw
    B
    Idaho
    06 DC. shack on the back.
    Conopy from an 8ft dodge, CSF aluminum radiator, MSD blasters, Cooper S/T maxx's
    Hey you can make anything fit...
    This is for a Dodge.
  11. Apr 14, 2023 at 6:39 PM
    biebs96
    PA
    that is very clean looking without the caps installed.
  12. Apr 14, 2023 at 7:20 PM
    This might qualify as the most intriguing - or possibly most bizarre - 1st post I've ever seen. Kudos.
    FirstGenVol and FrenchToasty like this.
  13. Apr 16, 2023 at 12:56 PM
    Toiyabe
    Toiyabe New Member
    2006 DC Limited TRD Off Road
    I've got an AC shell on my DC. The rear cab profile on the AC is ever so slightly more square in the rear which means putting the AC shell on my DC leaves a slightly wider gap at the top that narrows as it comes down and doesn't quite match the line from where the bed meets the cab. This is purely aesthetic though and you really don't notice unless you're looking for it.
    There was a little gap under the rear hatch that was letting a little bit of dust in when I would be out on dusty roads but I stuck a small piece of window weather stripping you can buy at any hardware store under the bottom of the hatch and that sealed it right up.
  14. Apr 16, 2023 at 1:13 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think that shell looks great on your truck. I have a double cab shell on my access cab. Proof we can swing both ways. :anonymous:
    Toiyabe[QUOTED] likes this.
  15. Apr 17, 2023 at 6:03 AM
    Yeah, but once you see the gap or overhang, you just can't unsee it. It would really rustle my OCD jimmies.
    Jack McCarthy likes this.
  16. Apr 17, 2023 at 11:55 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm fairly OCD too but I think you're being too anal about this. It looks perfectly fine.
  17. Apr 17, 2023 at 2:50 PM
    thxcolm
    thxcolm New Member
    central valley, CA
    I guess the real question is more why did 'Yota make the DC beds ever so slightly different to the AC beds to its detriment 15-20 years later when we're still looking for precise fit shells?
    Couldn't they have just the bed sizes exactly the same it to the same length since the width was the same? What was the advantage of adding like 1-2" of length to the bed?
    #realquestions
  18. Apr 17, 2023 at 2:55 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Real question is why anyone would buy a paw cap? Absolutely useless, Buy an suv…
  19. Apr 17, 2023 at 3:02 PM
    Casper421
    In the woods
    06 DC
    Real question…what’s a paw cap?
    FrenchToasty and thxcolm like this.
  20. Apr 17, 2023 at 3:14 PM
    thxcolm
    thxcolm New Member
    central valley, CA
    Ever try going to the gravel yard with an SUV?
  21. Apr 17, 2023 at 6:31 PM
    We all know you hate caps at this point, it's almost cliche by now :rofl:
    Elevatorguy[QUOTED] likes this.
  22. Apr 18, 2023 at 1:44 AM
    Elevatorguy
    James
    You cut a hole in the top so it can be loaded like a real truck? Or pull it off for the truck to be useful again?
  23. Apr 18, 2023 at 7:03 AM
    Casper421
    In the woods
    06 DC
    Um…trailer. It can hold a lot more than your “real truck”. You’ll learn one day kid.
    alb1k and shifty` like this.
  24. Apr 18, 2023 at 9:28 AM
    Says the guy with a cab bigger than his bed. :rofl:
    :boink:
  25. Apr 18, 2023 at 9:36 AM
    Elevatorguy
    James
    :monocle:A trailer pull by a truck with a paw paw cap so you can’t load the bed? An suv could do that too… kid…
  26. Apr 18, 2023 at 9:53 AM
    Casper421
    In the woods
    06 DC
    You still haven’t given an adult explanation for what a “paw cap” is. If you don’t want to participate nicely in class, there’s the corner and a dunce cap.
  27. Apr 18, 2023 at 9:58 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I like my Paw Paw cap.
    des2mtn, shifty` and Casper421 like this.
  28. Apr 18, 2023 at 10:36 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I hope you've gotten new tires or are getting them very, very soon.
  29. Apr 23, 2023 at 6:03 PM
    Toiyabe
    Toiyabe New Member
    Yeah this picture is a few years old. I got new 35x12.5/r17 duratracs right after this was taken.
  30. Apr 26, 2023 at 11:27 AM
    Billytx
    Billytx New Member
    AnhKiet
    2016 tundra 1794
    I got 2005 double cab on my access cab but need custom abit for fit
