Winjet tail lights didn't fit. Wiring harness didn't match!
Discussion in 'Lighting' started by ADaniel210, Mar 11, 2017.
  1. Mar 11, 2017 at 4:50 AM
    ADaniel210
    ADaniel210 [OP] New Member
    Adrian
    San Antonio, TX
    2015 White Tundra TRD
    I bought these winjet tail lights and the wiring harness didn't connect. Do I need to do any modifications or just somehow they sent the wrong ones? Order label says there correct. I'm unsure.
  2. Mar 11, 2017 at 5:25 AM
    Kizmatti
    Kizmatti New Member
    I sent mine back after being on my truck for 2 days. Called their support # and they sent me a fedex ship label thru my email. I purchased from protuninglab not Amazon.
    Fitment was aweful. 1/4 inch gap on top and nearly rubbing the paint on the bottom. My left side had condensation/water in it after 2 days on the truck. I didn't seal these myself before installing, nor will I. They advertise these as "presicion fit & waterproof" right on the webpage you order off.
    Was also concerned they just aren't bright enough for people from behind to see the brake and turn signals on a sunny day. Mine were the clear glossy black. Maybe the smoked or red tinted lenses were better. I sure hope so.
    As far as hooking them up goes, they are plug & play. The 3rd connection needs to reuse your backup bulb from your stocker taillights or you buy led bulb from them. The other 2 leads should plug straight in from your stock tails.
    They do look cool. But I found form, fit, and function flat out unacceptable. I'm happy with my stocker tails.
  3. Mar 11, 2017 at 5:34 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Good to know.
  4. Mar 11, 2017 at 5:37 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    I've had mine on for over a year with no issues they function and fit just fine.
    Backslider likes this.
  5. Mar 11, 2017 at 6:01 AM
    Kizmatti
    Kizmatti New Member
    I'm glad for you. You got a decent set and I'm sure quality control is all over the board on these.
    Mine even had flashing around the edges that wasn't trimmed properly, nor was the "gate" trimmed flush on the front lens cover, when it came out of the mold at the press.
    Also noticed the 2 alignment pins that help center the light on the truck on the winjet lights are tapped and screwed in by hand after the part is molded. If these aren't centered and put in at the proper angle fitment will be, and on mine was compromised.
    The 2 alignment pins on the stocker lenses are molded into the back taillight housings at the press.
    These are $200 made in china taillights. You might get a good pair with 0 issue. But at that price quality control on these is slim to nonexistent. They can't scrap out much and still make money.
  6. Mar 11, 2017 at 11:21 AM
    ADaniel210
    Adrian
    San Antonio, TX
    Thanks for the response. These tail lights don't connect period to any of my wires.. any other recommendations? I'm looking at the recon tail lights.
  7. Mar 11, 2017 at 3:45 PM
    Kizmatti
    Kizmatti New Member
    Are you taking the harness off with each of the bulbs on your Tundra? Or just pulling the bulbs out?
    The turn signal / brake light connection has to have the harness pulled off with the bulb. There is a clip on the side you need to push and it will release. This then plugs into the winjet taillight. You can't cross the leads because 1 is much bigger than the other.
    Running light bulb same thing. Pull harness off with the bulb left in it.
    Once you have the harness off these 2 leads that is what plugs into the winjet.
    The third lead, which is the backup bulb is the only 1 you leave the bulb in because there aren't any backup led lights in the winjet taillight. You either use your existing bulb, or buy an led to plug into it.
  8. Apr 5, 2017 at 5:32 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I had no issues with mine I purchased them 2+ years ago.
  9. Apr 5, 2017 at 6:43 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I've had mine nearly a year. Zero problems and I love the way they look. They fit perfectly and were plug and play.
    I'm sorry you guys aren't having the same experience.
  10. Aug 12, 2017 at 5:42 PM
    Briantran88
    Briantran88 New Member
    Small led on the side fell off after a day installed and run
  11. Aug 12, 2017 at 5:49 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've had 'em for more than a year with no issues. I'm glad there weren't reviews like this to read before I purchased, I'd never have gotten 'em. As it is, I'm quite happy with 'em. I'm sorry they didn't work out for you guys.
  12. Aug 12, 2017 at 5:51 PM
    Backslider
    Tooele, UT
    That sucks.. I guess the silver lining is that if they were only installed for a day you should be able to get a refund or replacement pretty easily.
    Mine are still working 100% after over a year of owning them. Sucks that their QC appears to be kind of spotty.
  13. Sep 22, 2017 at 7:10 AM
    War Machine
    War Machine SSEM # 5 3MW
    1505524143011.jpg Mine left a small gap around them. Looking at it, the side prongs are longer than the ones on the stock, which seems to be the problem. That said, they look awesome. I like the look of them better than I do the Anzos or Recons, and they are half the price. The styling in these are very sharp. I'm going to try and trim the prongs down a little and see if that helps. I was hoping to just swap the prongs out from the stock lights, but they oem ones aren't removable.
    I saw where another guy just removed the prongs and mounted them that way. He said they fit perfectly after that, but I'm not sure it's a good idea to not have anything at all holding them in on the sides.
    I agree that you shouldn't have to modify them at all, but since I actually like these better than the better brands, I'll try to make them work. If not, I'll wait a while and get a more quality brand.
    4x4_Angel and SouthBoundSteve like this.
  14. Sep 23, 2017 at 8:21 AM
    warlord192
    warlord192 Get off my lawn !!
    New Orleans
    2014 Silver Sky metallic Tundra Double Cab
    I have the Recon's and have no problems.
  15. Sep 24, 2017 at 5:29 PM
    War Machine
    Thank you sir. They are very sharp looking lights.
    SouthBoundSteve likes this.
  16. Oct 4, 2017 at 11:38 AM
    NROD
    NROD New Member
    2017 TOYOTA TUNDRA 4X4
    Mine fit great...having other issues. The tail lights don't light up. The brake, the backup and the turn signal all work fine just no lights. Any solutions?
  17. Oct 4, 2017 at 11:52 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
  18. Oct 4, 2017 at 12:57 PM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Sorry that you are having problems with them. These are the ones that I have been looking at to get. I think that I may still get them and hope for the best.
  19. Feb 28, 2018 at 11:30 AM
    Kripple
    Kripple New Member
    David
    2017 black tundra trd
    Anyone have issue on the side of the led not lighting up or know how to fix the issue
