Wind noise concern
Discussion in '3rd Gen Tundras (2022+)' started by Hogujak, Nov 26, 2021.
  1. Jan 19, 2023 at 7:59 AM
    #241
    ArticTundra
    ArticTundra New Member
    Cold
    Has anyone experimented with air VG’s/diffusers/disrupters on the mirror to see if that helped reduce the noise coming from the mirror?
  2. Jan 19, 2023 at 9:27 AM
    #242
    Kap1
    Kap1 New Member
    San Francisco, CA
    So, originally I thought my noise is because of the mirror, but I'm not so sure anymore.
    When mirror is closed, the noise quiets down, but maybe it's because the closed mirror helps to route wind around the window seals...
    So maybe it's the window seals after all that's making the noise and not necessarily the mirror itself. I tried to tape up the mirror and it only helped a little bit
    Henry1jg likes this.
  3. Jan 19, 2023 at 10:13 AM
    #243
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    I've been thinking the same thing. Most of the noise (after putting 4,500 miles on my truck) seems to be due to the window seals or the weather stripping not allowing the door to close properly.
  4. Jan 19, 2023 at 11:15 AM
    #244
    ArticTundra
    Cold
    With that, has anyone taped up the door all the way around from the outside then went for a drive? I guess you could even tape up portions to see where the problem is coming from.
    One step further for those in cold weather: If you have access to a thermal camera (my wife got me a little one for christmas that plugs into my phone) you can go for a drive and look for leaks....
    Just some ideas.
    Kap1 likes this.
  5. Jan 20, 2023 at 12:22 AM
    #245
    Kap1
    Kap1 New Member
    San Francisco, CA
    I want to diagnose more, but my daily commute to work is only about 30 min through the city, so don't hear this whistling often. And I didn't had a chance to diagnose more..
  6. Jan 21, 2023 at 5:55 AM
    #246
    dekeman
    dekeman New Member
    Derek
    Ottawa, ON, CANADA
    2022 Tundra Limted TRD
    Dealership was able to replicate my noise, hence the replacement. It's definitely coming from the rubber seal that the window slides into, as though it's not quite thick enough to form a good seat around the glass perimeter. I am going to pull the seal and attach some kind of tape to the frame, then reinstall the seal to see if that helps.
    RickyBobbysTundra likes this.
  7. Jan 21, 2023 at 8:44 AM
    #247
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    I get whistling after rain but goes away after everything is dry.
    Honestly I’m completely disappointed at Toyota.
  8. Jan 25, 2023 at 6:31 PM
    #248
    Troyboy84
    Troyboy84 New Member
    BC Canada
    2022 SR5 TRD Offroad
    Just got my truck back after they replaced the drivers side window seal, zero improvement. I’ll be back at the dealership tomorrow. That and there is moisture under the drivers floor mat and Toyota corporate says it’s a faulty design in the mat, I call total BS. Everyone should be checking under their mat after driving on wet roads.
    Kap1 likes this.
  9. Jan 25, 2023 at 6:38 PM
    #249
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Have you checked the drivers side a pillar and oh shit handle?
    heard a few folks had water intrusion through top of windshield . Could be coming all the way down to the carpet
  10. Jan 25, 2023 at 6:46 PM
    #250
    Troyboy84
    BC Canada
    I mentioned that to the dealership and they said it wasn’t from that. I pulled the cover off the grab handle while I washed it and didn’t see and water coming in. I’ll be doing more investigation tomorrow, thank you for the input though, I want to get to the bottom of this.
  11. Jan 27, 2023 at 2:27 PM
    #251
    OCzipPAC
    OCzipPAC New Member
    I was thinking of installing wind deflectors on the side windows, from Weather Tech. Do you think this will help eliminate the noise? Does anyone already have this on their truck?
  12. Jan 27, 2023 at 10:46 PM
    #252
    Fxclm5
    Fxclm5 New Member
    search for this, there are a few threads, but basically one of the foams that seals a seam is not properly done, and water will travel up if your driving in the rain. IMO toyota should find the vins that are effected and do a recall, the foam is just a 2ndary protection of a welded seam that has failed and allowing water to come into the cabin.
    The thread has pics and few other ppl who have same issues.
  13. Jan 27, 2023 at 11:19 PM
    #253
    Troyboy84
    BC Canada
    I showed my dealership that whole thread, they agreed with me but Toyota corporate told them no, it was coming from the floor mat. My dealership is trying to push the issue and has told me to keep monitoring it and let them know when it’s wet again.
  14. Jan 28, 2023 at 11:42 AM
    #254
    Fxclm5
    Fxclm5 New Member
    pretty sure ppl replicated the issue in the thread
    Dry it off in front of them, ask them to spray water from underneath at that seam, check for moisture is what I would ask them to do - in front of you. (I was a previous mercedes auto tech) - this would most likely not be done in the actual service bay but outside where they do detail/carwashes
  15. Jan 28, 2023 at 12:07 PM
    #255
    Breathing Borla
    Northern Illinois
    I sure hope I dont wind up with this kinda sloppy ass build quality bullshit, ugh
    Im about a month out for a build date
    it does seem like they have really been cleaning up the builds recently and issuing TSBs,ect, so it seems like its finally turning around
  16. Jan 28, 2023 at 12:21 PM
    #256
    Troyboy84
    BC Canada
    thats the plan, a friend of mine has the same issue so we’re both hounding them to do better.
  17. Jan 28, 2023 at 1:47 PM
    #257
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    back out… had I known these issues were a thing I would have never purchased this truck.
    I love the truck but these little annoying issues are not acceptable
  18. Jan 28, 2023 at 6:37 PM
    #258
    Breathing Borla
    Northern Illinois
    when was your build date?
  19. Jan 31, 2023 at 6:40 AM
    #259
    ruff
    ruff New Member
    I have a 2022 1794 and also have a clicking noise from the driver side windows with the wind or bumps, wind noise in the top left corner, and had a very annoying whistling noise.
    Dealer put felt on the window gasket inside the truck which helped with the clicking but made the wind noise worse, they just replaced the entire seal yesterday and the noise seems to be better but the clicking is still there especially when I go over bumps, it's like the window / door seal is sliding around against each other over bumps. I'm going to try some lubricant on the seal to see if that stops it, the new one is much tighter. They also said they are going to replace the rear window seals which are terrible and don't click in like they should.
    For the whistling noise I tried tape and folding the mirrors in. What I discovered was that the black vinyl wrap at the top of the windshield was peeled up slightly(1/8th of an inch at the most) and that was causing the whistling on both sides. I pushed that back down underneath the black piece and the whistling has completely stopped for months now.
  20. Jan 31, 2023 at 8:04 AM
    #260
    Breathing Borla
    Northern Illinois
    whats you build date?
  21. Jan 31, 2023 at 4:53 PM
    #261
    ruff
    ruff New Member
    The build date is 2/2022.
  22. Feb 4, 2023 at 7:48 PM
    #262
    Kap1
    Kap1 New Member
    San Francisco, CA
    Cholland5583 likes this.
  23. Feb 5, 2023 at 1:47 PM
    #263
    Cholland5583
    Cholland5583 New Member
    Yep that’s what my dealership told me. My issue is when I hit about 70 mph my window will rattle. I thought it was the mirror but I can put my arm up against the window and apply pressure and it goes away. Don’t have all the wind noise that everyone else mentions. Also first issue I’ve had with 22k miles. (Knock on wood)
    Kap1[QUOTED] likes this.
  24. Feb 17, 2023 at 9:26 PM
    #264
    Tundra23owner
    Tundra23owner New Member
    I just picked up a 2023 tundra 1794 with 3 miles on it and it has whistling/ wind noise from driver side… if I knew I wouldn’t have bought it. Spent close to 70k to get a truck that makes wind noise lol. Anything from Toyota on this yet? I don’t want to go there and for them to turn me away.
  25. Feb 18, 2023 at 1:01 AM
    #265
    Kap1
    Kap1 New Member
    San Francisco, CA
    There's no solution yet. I'm in same situation as you're. And many more..
    You can wait, or start taping up seams between the window and door frame, and door frame and truck body to figure out exactly where this noise is coming from, and maybe you'll be able to help dealership come up with a solution
    Tundra23owner[QUOTED] likes this.
  26. Feb 18, 2023 at 2:18 AM
    #266
    fastarget
    fastarget New Member
    2023 Max Platinum
    Picked up 2023 platinum last night, wife and kid in the truck for a test drive, 75mph on the highway, it was quiet, they thought it is the least noisy cab they had been iin. Hope it stays that way. Sorry for the people having issues.
    Kap1 and Tundra23owner like this.
  27. Feb 18, 2023 at 7:01 PM
    #267
    Tundra23owner
    you’d think they would fix this problem, now I know why the guy that ordered it didn’t take delivery. This thing makes noise at any mph. :/ I guess I’ll wait.. I’ll do some tinkering tomorrow and see if I can figure it out before Toyota does.
    Kap1 likes this.
  28. Feb 18, 2023 at 9:25 PM
    #268
    Kap1
    Kap1 New Member
    San Francisco, CA
    Basically you have to use masking painters tape, tape up every seam, drive, see if noise stopped, if it stopped, open up some portion of the seam, drive more, repeat until you figure out what's causing the noise...
    This will be helpfully to hopefully finding some sort of solution, or pointing dealer the right way. They'll be doing diagnostics same way as you but probably less patient. Let us know please
  29. Feb 20, 2023 at 1:18 PM
    #269
    hassaan.shezad
    hassaan.shezad New Member
    I also have the wind noise issue in my 2022 SR Tundra, but only on my driver side window while going 40+ mph.
    I told my dealer about this, and they test drove it. They didn’t hear the noise originally but when I sat and test drove with them, I was able to point the noise out. At first, we thought this noise was from the weather trim on the window. They took the truck, gave us a loaner car, and ordered the new part which was “RUN, FR DOOR GLAS FP NUMBER 68151-0C050.”
    Apparently the part they changed arrived damaged during shipment, but they still installed it either way, the noise still remained. The exact notes they left were:
    CUSTOMER STATES HEARING WIND NOISE FROM DRIVER SIDE DOOR. PLEASE CHECK AND ADVISE. PART WAS DISPATCHED WAS DEFECTIVE. TOP CORNER OF WINDOW RUN (CORNER NUMBER 3) DOES NOT SIT FLUSH ON THE WINDOW. NEW WINDOW RUN IS DEFORMED DUE TO PACKAGING. THE WINDOW RUN IS FOLDED 3 TIMES AND PLACED INTO A SMALL BAG AS ITS PACKAGE, CAUSING IT TO LOSE SHAPE… REPLACED DRIVER FRONT WINDOW RUN
    Anyways, that dealer is a headache. So, I took it to another one today and the technician said that the noise isn’t from the window weather seal and that it’s from the left front outer side mirror. They taped it up and took for a test drive, they did not hear any noise and even while I was driving it back today, I did not hear any noise while going 50+ mph.
    WhatsApp Image 2023-02-20 at 1.30.37 PM.jpg WhatsApp Image 2023-02-20 at 1.30.38 PM.jpg
    So as of right now, they apparently do not have a solution? The technician said that a customer also had a similar issue last Saturday (3 days ago) but there was no solution till then and that he will call the engineers at Toyota for the next step. This is quite disturbing to hear since this thread alone has been complaining about this issue since November, 2021. Here are the exact notes they left:
    TECH FOUND WIND NOISE/WHISTLE FROM LEFT FRONT OUTTER MIRROR- TECH TAPED OFF SEAMS ON OUTER MIRROR AND NOISE WAS NO LONGER PRE5ENT- TECH OPENED TAS CASE #- TECH WAS INFORMED NO COUNTER MEASURE PART HAS AVAILABLE AT THIS TIME AND NOISE WAS CONSIDERED CONSISTANT WITH LIKE MODEL TUNDRAS AND BASE NON TURNSIGNAL MIRROR- NO REPAIR PERFORMED AT THIS TIME.
    I am not exactly sure what “non turn signal mirrors” are, but looks like the issue is only with those types of mirrors. As of right now, they have rescheduled me for Monday (7 days from now) and they plan to give an update/ solution on this issue.
    I am not entirely sure if these are two different wind issues, the one I faced with my side mirrors vs. the weather trim possible issue, considering that some people in this forum replaced/taped their weather trim which made the issue go away. I also asked the technician if it was possible to replace the entire side mirror but he said the issue would still remain.
    I will keep updating here based on updates/Monday appointment. In the meantime, if anyone else here is also still having this issue, I highly suggest you to tape the side mirrors the same way they taped mine, and see if the issue still remains, hopefully this clears the story up a little bit.
    Breathing Borla likes this.
  30. Feb 20, 2023 at 1:29 PM
    #270
    Tundra23owner
    thats fucking insane.. the whole mirror is bad. im going to tape mine up like this and see if it resolves the issue
