Wind noise concern
Discussion in '3rd Gen Tundras (2022+)' started by Hogujak, Nov 26, 2021.
  1. Mar 14, 2022 at 2:29 PM
    #91
    Breathing Borla
    AZ
    the ones that Ive seen that went in just got the same shitty seals put back in. I havent seen a real fix yet.
    keep us posted, major concern of mine before I pull the trigger on a purchase
    Russ_S and Rwaters like this.
  2. Mar 17, 2022 at 9:37 AM
    #92
    articdesert
    articdesert Will work for truck parts
    23 1794 MGM
    I just got my truck back from the techs. They said Toyota knows of the issue and that I’m in the system to fix the issue when Toyota come out with one.
    but they basically said they’ve localized the spot. At the driver side door where I took the picture. Around the 90 degree angle. She said she isn’t sure if it’s gonna be just the seal or what but when Toyota decides they’ll fix it
    Dmon187 likes this.
  3. Mar 17, 2022 at 10:05 AM
    #93
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    I noticed all my doors look like this, I can only hear it from the driver side door though. Honestly it looks like poor fitting or something. I’m going to mention it but as long as they know and are working on a fix I’m good.
  4. Mar 17, 2022 at 10:55 AM
    #94
    21CGtundra
    21CGtundra New Member
    Robbie
    SLC, UT
    2022 Midnight Black Tundra SR5
    2" front level, 1" Cornfed rear spacer, Rally Armor flaps, Method Con-6 wheels, 285/75 Duratrac
    It seems like the seal shape isn't designed to fit tight enough to the glass. Like the seals on the truck are meant for a thicker piece of glass or something. I have the noise on my driver's side. Been meaning to try and slide some thin foam behind the seal to help it fit tighter to the glass but haven't had a chance yet.
  5. Mar 18, 2022 at 7:20 PM
    #95
    EvilSteve
    EvilSteve New Member
    2022 Lunar Rock Tundra Limited
    I took my 22 LTD in to the dealer today, they’re replacing the seal/gasket around the sunroof. I showed them the awkward gaps around the rear windows as well but they didn’t think there was an updated part for that yet so no guarantee that it’d be better until Toyota updates those. Parts are coming in next week.
  6. Mar 19, 2022 at 12:07 PM
    #96
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Take it to the car wash, turn up the fan and watch the bubbles...
  7. Mar 19, 2022 at 2:43 PM
    #97
    ThePolak
    ThePolak 2022 Platinum hunt/tow/haul/family ride on order!
    The Land of the Cobra Chicken
    Oh man, that's not good.
  8. Mar 19, 2022 at 7:11 PM
    #98
    EvilSteve
    I like bubbles, they’re fun. :D
  9. Apr 17, 2022 at 1:19 PM
    #99
    2bak
    2bak Thanks
    M
    Bellingham WA
    2018 CM
    Anyone have a solution yet?
  10. Apr 17, 2022 at 9:58 PM
    #100
    BREAKAW
    BREAKAW New Member
    2022 SR5 Crewmax TRD Off road
    I've tried putting tape on all the areas suggested and I still haven't nailed it down yet. Mine has similar symptoms of a whistle that starts around 40 mph. Seems to come more from the forward area of the driver side door or mirror. It makes the whistle noise if the window is up or down so I don't think its a window seal but I'm totally lost this point.
  11. Apr 18, 2022 at 6:20 AM
    #101
    gregor12
    gregor12 New Member
    PHIL
    2022 Tundra Limited
    Lol this is pretty clever. i would imagine since you're pulling air from outside and blowing it into the cabin, the air will have to escape from somewhere... ive seen where cars and SUVs have relief flaps in the rear quarter panels or bumper area but im not sure if the trucks have them in between the bed or something. curious if you turn on the recirc if it will still blow bubbles.
    anyways, i can hear a tiny tiny whistle in my 2022 tundra limited around 80 MPH if i really listen for it and turn the music down. However, this truck is 50 times better than my 2020 tundra when it comes to wind noise and feel. i could feel the air resonating through the floor pan in my old one lol
    as much as some people hate them, the low profile rain guards would probably stop the noise...
  12. Apr 18, 2022 at 6:26 AM
    #102
    gregor12
    gregor12 New Member
    PHIL
    2022 Tundra Limited
    my old tundra had noise that came from the mirror seams.... you could try taping around the mirror where the mirror pivots or around the seems where the caps meet. also if there are bolt/screw holes on the under side of the mirror, those could also a howling or wind noise.
  13. Apr 19, 2022 at 5:15 AM
    #103
    Ryan P
    Ryan P New Member
    Ryan
    2022 Tundra Platinum
    So I think I'm experiencing the same thing as you, which might be different than what some others are hearing. It seems there are two camps, one that hears hissing, like actual wind noise that gets worse with speed, and others like myself which are hearing a faint but consistent whistle at certain speeds. I only experience the noise from around 35-50 mph. At highway speeds it's dead silent. If I'm going 40mph, I hear what sounds almost like a low pitched teapot. The tone doesn't chance with speed, just the intensity. What is extra strange is this recently started in the last few days. I haven't started to diagnose it yet, but quick things I tried were lowering the windows, removing my tonneau cover (which I recently installed), and popping in neutral while coasting, none of which made a change.
    golfersa likes this.
  14. Apr 20, 2022 at 10:38 PM
    #104
    Tundra.Lui
    Tundra.Lui New Member
    2022 Army Green Tundra 1794
    I will complete my one month ownership in a week and I never noticed the wind noise till last week when I was with my parents I turned down the music and heard it so I have been paying attention and about 65mph is when I begin to hear it and I hear it as if its coming from the back. I have an appointment tomorrow at 12:15pm tomorrow for them to check it out but it doesn't really bug me I mostly hear my music, the engine and wind from outside if the currents are strong
  15. Apr 21, 2022 at 3:05 PM
    #105
    newdles
    newdles New Member
    brandon
    Red 2022 tundra
    Only commenting here to add to the list of people with a drastic noise issue. Mines bad enough that the radio must be turned up quite high to overpower the noise at 60+. Have an appointment next Monday morning due to having the lane centering warning come up saying visit dealer. Since that has happened 3-4 times now decided was time to get an appointment.
    While there, they’re going to check the seals and noise, the warning light for land assist/departure, check the very excessive rattling of the right front door panel. Very noticeable and very easy to pinpoint it. Have a passenger in the front seat with their knee slightly applying pressure no rattle.
    Also have a very very unusual sound coming from the engine that doesn’t hardly ever happen. Here is link to video (don’t mind the bugs everywhere, just got back from 2900 mile trip and it’s clean now).
    https://youtube.com/shorts/T6v60D_DXLU?feature=share
    Troyboy84 likes this.
  16. Apr 21, 2022 at 4:32 PM
    #106
    Tundra.Lui
    UPDATE. So I just got back from the dealership I was told by my service rep that Toyota wants ALL Tundra issues to be contacted about right away, him and the tec did various areas taped and drove on the freeway and got all area's affected (my truck is both rear windows and I don't know what level at toyota they spoke to but pretty much they said either give me my truck tomorrow or they will be sending out a top engineer from the texas plant and are going to use my truck as a Guinea pig. I'm kinda like wtf but they did say that if any issues or damages occur after the new tests after the engineer they will remove the truck off my hands without a fight i don't know if it's the dealer or actually toyota that will all be recorded and talked about tomorrow when toyota contacts the dealer tomorrow but for the inconvenience of this they will wash my truck fill it up and a accessory of $200 or less
    Hadelson likes this.
  17. Apr 22, 2022 at 6:23 AM
    #107
    Breathing Borla
    AZ
    those are killer long sentences, wow.
    keep us updated if there is actually a new fix are just putting in new same parts
    EvilSteve likes this.
  18. Apr 22, 2022 at 7:49 AM
    #108
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    My take, Coming from a 17 TRD Pro 4 Runner daily driver to the 22 Tundra.
    The only abnormal wind noise is when Mother Nature working her magic and we have high winds. That said, all cars experience some increase level of wind noise when this happens. Also, my other ride has Long Tube headers into full Borla AE Cat-back. So in comparison, what noise with the Tundra.
    I have looked closely at all the window seals and aligned they look like crap. It will be noted with Toyota when I bring in for the 5K check
    22PlatWCP likes this.
  19. Apr 22, 2022 at 9:00 AM
    #109
    newdles
    newdles New Member
    brandon
    Red 2022 tundra
    Here’s a quick video clip of the sound in the cab at 60.
    https://youtube.com/shorts/wS1FcAm1qRo?feature=share
  20. Apr 24, 2022 at 1:56 AM
    #110
    AMSOFLO
    AMSOFLO New Member
    ANGEL
    2022 TUNDRA
    I hear wind noise inside driver side. I tried to locate by moving my hand along the door gasket inside the truck and I feel the door flexing as I'm driving, crazy. Door gasket front pillar by handle all along I could feel the flex.
  21. Apr 25, 2022 at 5:33 PM
    #111
    BREAKAW
    BREAKAW New Member
    I've narrowed down where the whistling on mine was coming from. I taped up several seams under the mirror and plugged two holes that look like the are for draining and its gone away. Im going to remove the tape one by one to see when it comes back and ill post an update. I'm just so reluctant to remove it right now because I'm enjoying the silence.
    Breathing Borla and reese3303 like this.
  22. Apr 27, 2022 at 10:34 AM
    #112
    reese3303
    reese3303 New Member
    SC Louisiana
    2015 Tundra 4x4
    Here's a few pictures of the seals on my truck, build date of 4/7/22.
    Haven't brought it to the dealership yet because they have no idea about anything on these trucks yet.
    Its painful to even ask them a question
    [​IMG] [​IMG] [​IMG] [​IMG]
  23. Apr 27, 2022 at 10:36 AM
    #113
    Breathing Borla
    AZ
    wow thats really sloppy.
    it looks like the arm rest on your door is all deformed or it that just the angle.
    I just got a call from a dealer here that has several tundras and Im not real sure I want to jump in yet, QC still seems questionable at best.
  24. Apr 27, 2022 at 10:38 AM
    #114
    reese3303
    SC Louisiana
    2015 Tundra 4x4
    The armrest has a slight hump in middle on driver and passenger doors. Had from day one.
  25. Apr 27, 2022 at 11:37 AM
    #115
    Breathing Borla
    AZ
    ya it doesnt look right, I would have them fix that with all the other stuff as well, looks like the door panel is coming off too right in that spot. Too much of your hard earned money to have sloppy work like that.
    just my .02 though
  26. Apr 27, 2022 at 1:04 PM
    #116
    MJPlat
    MJPlat New Member
    The front interior panels of mine look the same as yours. Exterior seals are a little bit better fitting tho. Are you having wind noise issues? Mine is fine.
  27. Apr 27, 2022 at 1:38 PM
    #117
    reese3303
    SC Louisiana
    2015 Tundra 4x4
    I am on drivers side
  28. Apr 27, 2022 at 1:39 PM
    #118
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    Are you guys suggesting it shouldn't sound like my passenger side window is cracked open anytime I drive on the highway? LOL. First thing the wife noticed when we left the lot. Hoping to get this resolved at the first service but I'm not holding my breath after watching this thread for a bit. It looks like it could get much worse if they mess with it.
  29. Apr 27, 2022 at 1:53 PM
    #119
    newdles
    newdles New Member
    brandon
    Red 2022 tundra
    I’m at 6500+ miles after 3 weeks of ownership and the wind noise is horrid. 45+ is where it really shines. Took into dealer and they ordered new seals so hopefully when replaced it’ll be better but definitely sounds like the window is cracked just a little while driving. Downside is the new seals won’t be at the dealer for about a month they said.
    Also, on Friday I’m having some audio work done and sound deadening installed in the entire cab except the head liner. That’ll help the little road noise but won’t do anything for the wind noise unfortunately.
  30. Apr 27, 2022 at 2:08 PM
    #120
    Breathing Borla
    AZ
    I wonder if these "new seals" are just the same shit that doesnt fit now , but re-isntalled or if toyota actually has a new design out that fixes it
    please update if you guys can, this is a major one for me holding back my purchase, I really cant take noises , rattles, etc, drives me nuts.
    thats part of why I buy tundras, you usually dont have rattles, etc at all with them
