Will 295/70R18 tires really fit (and what does fit mean?)
Discussion in '2.5 Gen Tundras (2014-2021)' started by CP17Tundra, Oct 29, 2019.
  1. Jan 25, 2020 at 4:35 PM
    #121
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    What's the wheel offset?
  2. Jan 25, 2020 at 4:52 PM
    #122
    RustyShackelford
    RustyShackelford New Member
    2020 TRD Sport 4x4
    18mm offset
    SprinterAE86[QUOTED] likes this.
  3. Feb 5, 2020 at 6:05 PM
    #123
    ostm282
    ostm282 New Member
    Stock 2018 Tundra Limited Silver
    2" leveling kit installed up front
    With the 3" lift up front, are you still running stock upper control arms? If you're running aftermarket uppers, what brand did you go with? How did your alignment turn out if you're still using stock uppers? Thanks and nice truck
  4. Feb 5, 2020 at 7:07 PM
    #124
    RustyShackelford
    2020 TRD Sport 4x4
    Running the stock UCAs with no alignment issues at all everything came in within spec and it runs straight and smooth.
  5. Apr 29, 2020 at 6:26 PM
    #125
    How do you like the AAL? I'm getting ready to remove the Readylift 3/2 spacer kit. I'm replacing it with the Toytec Alumas and Boss rears with resis. Right now I'm dealing with confusion on the rear end. I'm being advised to go with the AAL and Toytec shackles and ditch the rear block.
  6. Oct 10, 2020 at 8:58 PM
    #126
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    When did BFG finally get it together and release KO2s in 295/70R18?!
    TheBeast likes this.
  7. Oct 11, 2020 at 5:09 AM
    #127
    tundra121
    tundra121 New Member
    A year ago I was told that in the spring of 2019 they would have the 295’s but still no stock in Canada till mid next year.
    Had no choice but choose something else which so far like better than the other size ko2’s I have had.
  8. Oct 11, 2020 at 5:22 AM
    #128
    ohreary
    ohreary Party!
    2020 Platinum
    Planning on running the same setup, 3/1.5 lift and 0 offset wheels. If I run 295/70/18 do you think I would still need to do the BMC?
  9. Sep 12, 2022 at 6:32 PM
    #129
    Geodude82
    Geodude82 New Member
    Did you say you were running a 2/1 leveling kit without rubbing?
  10. Sep 14, 2022 at 2:26 PM
    #130
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    My tundra is black. But I do like that color of blue. :thumbsup:
