Will 295/70R18 tires really fit (and what does fit mean?)
Discussion in '2.5 Gen Tundras (2014-2021)' started by CP17Tundra, Oct 29, 2019.
  1. Oct 29, 2019 at 10:56 PM
    CP17Tundra
    CP17Tundra [OP] New Member
    Clay
    Seattle
    Silver 2017 Tundra Limited
    3” lift, SCS Ray 10 wheels, Nitto Ridge Grapplers, bumper shims, interior LEDs, Baja Squadron fog lights, SPC UCAs, Bushwacker flares
    New member - first post. I have used search and found lots of info, much conflicting info. I have (just bought) a 2017 Tundra Crew Max. I have a 3” Toytec Boss lift - front and rear shocks, new SPC UCAs, rear add a leaf springs & shackles, diff drop kit sitting in the shop.
    Have already removed mud flaps when I installed flares. I was thinking 295/70/18 Nitto Ridge Grapplers on XD impact 18x9 + 18mm offset wheels.
    Toytec says this combo will fit fine - no rubbing after some minor trimming.
    I see a range of comments in posts - bolted up and no rubbing, some rubbing, some cutting required, some used spacers....
    Anyone have experience / insight on similar combo - particularly wheel offset and rubbing? Any and all info appreciated.
    Thanks much in advance,
    CP
    zcarpenter92 likes this.
  2. Oct 30, 2019 at 4:11 AM
    XPTUNDRA
    XPTUNDRA New Member
    North MS
    2016 Tundra Limited
    4" Pro Comp Lift 35x12.50x20 Toyo RT's 20x9 +20 Fuel Mavericks Rough Country soft tri-fold bed cover LED headlight and Fogs with LEDs throughout the cab as well
    Not sure about the fit with your wheels but with factory 18's no rub except full lock on skid plate which i trimmed and all is perfect. Running 295/70/18's on factory 18's with 2" RC leveling spacers
  3. Oct 30, 2019 at 4:23 AM
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    I'm running 295/70/18s on Vision Nemesis 18x9 +18mm. I'm on a 3/1 spacer lift with Freedom off road UCAs and only had to trim the plastic at the front of the wheel wells for clearance at full lock.
    CP17Tundra[OP] likes this.
  4. Oct 30, 2019 at 7:24 AM
    CP17Tundra
    Clay
    Seattle
    Thanks for the info and replies. Much appreciated.
    XPTUNDRA likes this.
  5. Oct 30, 2019 at 7:27 AM
    CP17Tundra
    Clay
    Seattle
    As you can see, looks a little weak with the stock tires.
    PeakIT likes this.
  6. Oct 30, 2019 at 7:42 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    I have the Toytec Boss kit, SPC UCA’s and Method NV 18x9 +25 offset with 295/70/18 Toyo AT2 extremes. I had to remove the front mud flap and have very slight rubbing on the front fender liner at full lock.
  7. Oct 30, 2019 at 7:45 AM
    TwistedTad
    Tad
    Canyon Lake, CA
  8. Oct 30, 2019 at 7:49 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    18x9 Warlords with 295/70/18 Open Country AT2
    removed the mudflaps and trimmed the front splash guards
  9. Oct 30, 2019 at 8:27 PM
    CP17Tundra
    Clay
    Seattle
    The boys at the tire shop said I could get away with 295’s on 18x9 wheels with +25mm of offset and expect minor trimming of skid plate and flaps. Already removed flaps. I’m ok with trimming the skid plate so am gonna give it a go.
    will be a couple of weeks as I have a hunt in Montana coming up and don’t want to deal with the change right before trip. Will post pics. Thanks for the help and advice...
    CP
  10. Oct 30, 2019 at 8:29 PM
    Tundrajoe
    Tundrajoe New Member
    Joe
    2014 crewmax super white
    Bilstein 5100s cooper at3 xlts, tint, full custom exhaust, methods
    I have +18 offset, stock uppers and bilstein 5100s, no rub all I had to do was space front bumper, coach builder makes shims for this
  11. Oct 30, 2019 at 8:52 PM
    rznhales
    rznhales New Member
    Randy
    Southern Utah
    2014 Tundra Crewmax Limited TRD
    Bilstein 5100's
    Just had 297/70’s installed yesterday. 3/1 level kit with factory UCA. Pulled front mudflaps and have slight rub on skid plate at full turn but had it with 286/70’s as well.
  12. Oct 30, 2019 at 10:16 PM
    CP17Tundra
    Clay
    Seattle
    Thanks for the info.
  13. Oct 30, 2019 at 10:51 PM
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    I had Toytec BOSS 3/1.5 with Method +0 Grid 35x12.50x18 body mount chop...no rubbing!
  14. Oct 30, 2019 at 11:15 PM
    zeusb1
    zeusb1 New Member
    Nel
    Duvall, WA
    2017 Tundra TRD PRO Cement
    Cooper AT3 XLT 295/70/18 Interior/Exterior LED swap Black Lugs Nfab Rails K&N Intake Pedal Commander Full Tint Lamin X fogs Retrax XR Tonneau cover Yakima Outpost HD with rails Yakima Lo Carbonite Box Yakima Slim Shady awning
    295/70/18 No rubbing with front flap removed
    misfit, gjbsupCM, georgiey22 and 2 others like this.
  15. Oct 31, 2019 at 12:40 AM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    I only have minor minor rubbing at full lock, but some small trimming would easily fix the issue
  16. Oct 31, 2019 at 12:57 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    How’d the 295s effect your fuel mileage and speedo?
  17. Oct 31, 2019 at 5:57 AM
    Tundrajoe
    Joe
    1 mpg and 3mph
  18. Oct 31, 2019 at 1:23 PM
    CP17Tundra
    Clay
    Seattle
    Ordered today....
  19. Oct 31, 2019 at 1:58 PM
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    Did you do spacers or just the oem wheels?
  20. Oct 31, 2019 at 3:01 PM
    Mgmtundra
    Mgmtundra MGM Crew
    I’m on a similar lift, mine is OME I got SCS SR8, everything fits nicely. Running Cooper ST Maxx in 295s.
  21. Oct 31, 2019 at 3:14 PM
    CP17Tundra
    Clay
    Seattle
    Thanks much. I backed out of the XD Impacts and ordered SCS Ray 10s. Encouraged that your set up is very similar to mine and the 295s work.
  22. Oct 31, 2019 at 3:21 PM
    Wildtrout
    Wildtrout New Member
    Seattle
    2018 Tundra Crew Max
    OME BP51 Front and Rear, Complete de badge, ARE Z Series camper shell, Decked system, TRD CAI, painted hood bulge and grill surround, WeatherTech mats
    I've been running 295/70/18s for a year. OME BP51s all around with Dakar heavy leafs with Coachbuilder +2 shackles. About 2.75-3" all around. RCI skidplate up front eleiminates any turn in rub. Also running an Expedition One front bumper which clears larger tires easily. Moving to 37s soon.
  23. Oct 31, 2019 at 3:26 PM
    Mgmtundra
    Mgmtundra MGM Crew
    Oh yeah don’t look at the dirty seven thread, you will forever second guess the 295s
    Willy224 and Wildtrout like this.
  24. Oct 31, 2019 at 3:27 PM
    Wildtrout
    Seattle
    Ha! Made my decision before I found that thread...but I agree it’s awful in a good way.
    Willy224 and jewsNbrews like this.
  25. Oct 31, 2019 at 3:31 PM
    CP17Tundra
    Clay
    Seattle
    Ok, I’ll bite. What’s the Dirty 7 thread?
  26. Oct 31, 2019 at 3:38 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    jewsNbrews likes this.
  27. Oct 31, 2019 at 3:39 PM
    smy
    smy New Member
    Willy224 likes this.
  28. Nov 2, 2019 at 12:57 PM
    CP17Tundra
    Clay
    Seattle
    A bit of love arrived from Toytec today.....
    badmotofing3r, DiegoC, Rica25 and 6 others like this.
  29. Nov 2, 2019 at 1:52 PM
    traveller09
    traveller09 New Member
    David
    Seattle Area
    2005 G500 & 1995 911. Looking to buy 1/2 ton truck mostly for overlanding and daily driver.
    Love the snorkel/cold air intake. I haven’t seen many pics with them installed on a Tundra. Can you share a few pictures?
    Rica25 likes this.
  30. Nov 2, 2019 at 3:39 PM
    Wildtrout
    Seattle
    Hey-Start a conversation with me and I’ll be happy to provide. Let’s keep this thread on the tire size questions...
