Will 295/70R18 tires really fit (and what does fit mean?)
Discussion in '2.5 Gen Tundras (2014-2021)' started by CP17Tundra, Oct 29, 2019.
  1. Dec 4, 2019 at 2:17 PM
    #91
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Yeah. I cant speak on the 4.7 or 5.7, but that 3.7L minivan engine sucked major balls out of gear. It was a no brainer option for me.
  2. Dec 4, 2019 at 3:13 PM
    #92
    BrennanHuff
    BrennanHuff New Member
    Toyotas
    My 4.7 is useable, but its also noticeable. My 100 is weighed down with armor, but still. The 4.88's will liven it back up a lot.
  3. Dec 5, 2019 at 6:02 AM
    #93
    mundra
    mundra New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    315/70/17 grapplers with no run yet... just installed them last night with rock warrior wheels. Removed the muds flaps though.
    S. Equoia, yoshi82 and focal like this.
  4. Dec 5, 2019 at 7:24 PM
    #94
    taco supreme
    taco supreme New Member
    16 white CM 1794
    You running on stock suspension?
  5. Dec 6, 2019 at 2:16 AM
    #95
    mundra
    mundra New Member
    2019 platinum 4x4
    Yes, I’m all stock. Last night I had a very little rub on skid plate. So I took a pair of channel locks and bent the rear corner of each side about 1/2” and now it clears plenty of tire area. Here’s a better pic in the daylight. I did remove the mud flaps in the front tire area
    S. Equoia, drobb, Willy224 and 3 others like this.
  6. Dec 10, 2019 at 9:00 AM
    #96
    Blak80k
    Blak80k New Member
    Dave
    Stock (for now)
    I'm assuming you're running the stock suspension. Have the same truck and want new shoes!
  7. Dec 10, 2019 at 9:43 AM
    #97
    mundra
    mundra New Member
    2019 platinum 4x4
    I’m running stock suspension
    Blak80k likes this.
  8. Dec 12, 2019 at 1:32 PM
    #98
    CP17Tundra
    CP17Tundra [OP] New Member
    Clay
    Seattle
    Silver 2017 Tundra Limited
    3” lift, SCS Ray 10 wheels, Nitto Ridge Grapplers, bumper shims, interior LEDs, Baja Squadron fog lights, SPC UCAs, Bushwacker flares
    Guess I should post a final (for now) pic.
    295-70r18 Ridge Grapplers ( wish I would have bought 35’s)
    Toytec 3/1.5 kit with rear AAL
    SPC adjustable UCAs
    Coachbuilder bumper shims
    SCS Ray-10 w/+25 offset
    Had to adjust the skid plate after lift
    I had removed flaps when I installed flares
    Everything else cleared
    yoshi82, Mgmtundra and zia_tundra575 like this.
  9. Dec 12, 2019 at 2:07 PM
    #99
    mundra
    mundra New Member
    2019 platinum 4x4
    Looks great! That’s why I went to the 315/70/17 close to 35’s. I had the 295 mounted and changed my mind.
    CP17Tundra[OP] likes this.
  10. Dec 19, 2019 at 3:45 PM
    #100
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Mine W/ 295’s.
    Wildtrout and Iowa12tundra like this.
  11. Dec 20, 2019 at 5:51 AM
    #101
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    Looking good!
    sea_weathered[QUOTED] likes this.
  12. Dec 20, 2019 at 6:02 AM
    #102
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    @Porkchop Express clean ass wheels!!!
    Hey I Have the same ones also, what are using to clean your rims with? Been careful not to stain the rims is my main concern
  13. Dec 20, 2019 at 6:15 AM
    #103
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Thanks. I use Macguires wash wax soap and a soft scrub brush if its not too muddy.
    yoshi82[QUOTED] likes this.
  14. Dec 20, 2019 at 6:48 AM
    #104
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    @Weavin Pro
    Can we see more of your truck? Trying to decide if I want to go 295 with just a level or not, and your truck is a good model!
  15. Dec 20, 2019 at 12:02 PM
    #105
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    I am more than happy to throw some pics up...just let me know what you want to see...this first pic is just with the 295s and stock PRO suspension...second pic is with Coachbuilder lift.
  16. Dec 24, 2019 at 12:49 PM
    #106
    Blak80k
    Blak80k New Member
    Dave
    Stock (for now)
    Any rub on the front end at full lock?
  17. Dec 24, 2019 at 1:51 PM
    #107
    Weavin Pro
    After removing the little front mud flap, and using the Coachbuilder bumper shims, I have zero rubbing in front.
    Before the lift...I had no rubbing in front or back. Just a very close fit to the upper A arm...but no issues.
    Blak80k likes this.
  18. Dec 30, 2019 at 8:05 PM
    #108
    Noodleboy
    Noodleboy New Member
    HP
    SGV
    2015 tundra double cab
    Are you running spacers?
  19. Dec 31, 2019 at 5:09 AM
    #109
    sea_weathered
    Pacific Ocean
    Yeah, 1.25” spacers from wheeladaptersusa.com . I’m happy enough with them. Seems like just the right amount of “stick out”. When the $$ lines up, I will be ditching the stock wheels and spacers for +25 SCS Ray10’s though.
    Seeing as this thread was originally about 295’s fitting properly, I should add my experience. They fit just fine. 3/1” leveling kit from frontrangeoffroad.com
    Added wheel spacers as noted above, only had 1/4” clearance to the UCA’s, removed all mud flaps, meh, pushed the front bumper inner liner forward about 3/4” and re-drilled a hole in the plastic to hold it in place. All very easy work to do in my driveway.
    Truck drives like a dream! Average fuel economy over the last 5k/mi. is 13.9mpg according to my hand calculations on the Fuelly app.
    SprinterAE86 likes this.
  20. Dec 31, 2019 at 6:17 AM
    #110
    vhstejskal
    vhstejskal New Member
    Vic
    2010 Silver SR5 Crewmax
    Here are my results with the 295/70/18 (35 mm offset wheels) size tires. I only have a leveling kit (2 inches front) without the mudflat removal. No rubbing in any forward or reverse at full lock. Interesting the diameter difference from my 33s how much better the ride feels.
    Berdine likes this.
  21. Jan 21, 2020 at 9:54 PM
    #111
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    Did you have to BMC, massage the liners or 1/2” lift up front? If something were to happen to my Quicksand this would definitely be my 2nd choice if I wanted a replacement ready to go minus the 295’s.
  22. Jan 22, 2020 at 3:21 AM
    #112
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    295.70.18 18x9 +12. Fits, but had to shim bumper, remove front flaps, remove mud guard, pry plastic behind bumper and drill new hole. I'm shopping for new wheels again.
  23. Jan 22, 2020 at 3:28 AM
    #113
    SprinterAE86
    Ian
    Before I destroy my mudguards, will the SC10 +25 with 295.70.18 clear?
  24. Jan 24, 2020 at 2:15 PM
    #114
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    24 limited hybrid offroad
    So absolutely no rubbing on the body mount?
    YotaNate likes this.
  25. Jan 24, 2020 at 5:38 PM
    #115
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    No, nothing on the body mount. With this offset and wheel size I haven't read of anyone needing a BMC. There was some rubbing on the front plastic, there's a few different ways to tackle that
  26. Jan 24, 2020 at 6:15 PM
    #116
    TundraLaw
    Northern Nevada
    Awesome thanks.
    what offset are your SCS’s?
  27. Jan 24, 2020 at 9:00 PM
    #117
    JimboSlice413
    Bakersfield
    Ray10s are +25
  28. Jan 25, 2020 at 2:02 AM
    #118
    SprinterAE86
    Ian
    @JimboSlice413 Do you think you can put the mu guard back in with out rubbing?
  29. Jan 25, 2020 at 1:32 PM
    #119
    JimboSlice413
    Bakersfield
    I removed them before the tires went on but it looks like there's plenty of room. I'll give one side a test fit tomorrow and get back to you
    SprinterAE86[QUOTED] likes this.
  30. Jan 25, 2020 at 4:28 PM
    #120
    RustyShackelford
    RustyShackelford New Member
    2020 TRD Sport 4x4
    Fox front and rear, 3" in the front and Icon AAL in the rear. Removed the front mud flaps but otherwise no rubbing at all. Methods with 295/70/18
    drobb likes this.
