Why the obsession with 35's?
Discussion in 'Wheels & Tires' started by tundracap, Feb 21, 2019.
  1. Feb 22, 2019 at 1:19 PM
    #91
    Lars
    Lars Trail Communicatons Expert
    Lars
    Cedar Creek Texas
    2010 Tundra TRD RockWarrior
    Yaesu FTM-400XDR running APRS (so 2m all the time) Plus one additional frequency. Usually 146.520 while I'm on the road or 146.460 while I'm on the trail.
    Icom IC-7100 either doing HF, or VHF, or UHF as necessary. (that's the pair of VHF/UHF Antenna Pairs.)
    There's a dedicated GMRS radio in the truck. That's the fifth roof mounted antenna.
    The screwdriver on the back driver's side is the HF antenna for the Icom. (I've talked to Moscow Russia from Austin Texas while doing 70 down the highway.)
    And finally the CB antenna on the back passenger's side, because not enough of y'all are willing to get a GMRS license, or ham radio license. :)
  2. Feb 22, 2019 at 1:21 PM
    #92
    Lars
    Lars
    Cedar Creek Texas
    I switched to Mono-band quarter wave NMO antennas because I got tired of breaking $90 dual band antennas while off road. These are both very simple, very robust, and cost $9 each. They're small also which makes keeping a couple spares in the truck really easy.
    papasmurf[QUOTED] likes this.
  3. Feb 22, 2019 at 1:29 PM
    #93
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    willing, yup not willing.... do I consistently break FCC laws, yup... gotta catch me in the act while im moving.. .good luck! LOL
    but that is cool. Id do it when i have some free time, but that seems to be never.
  4. Feb 22, 2019 at 2:23 PM
    #94
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    In order to keep this thread as off-track as humanly possible....
    Do you know if APRS enabled rigs will be able to see each other on a map if they CAN'T hit a repeater to get back to the service? If they're all connected to each other on the same freq? I thought they all needed to ping the server, but someone said it should work without hitting a repeater...
    papasmurf likes this.
  5. Feb 22, 2019 at 2:26 PM
    #95
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    poop chute?
    Rica25, Prostar 190, 15whtrd and 3 others like this.
  6. Feb 22, 2019 at 2:36 PM
    #96
    Lars
    Lars
    Cedar Creek Texas
    If your receiver can hear their APRS Packets, ie you're either in range of them, or a repeater they are in range of. Your receiver will at a minimum give you bearing and distance to their truck. If you've added additional things (like a Laptop, or tablet with some software.) you will be able to plot them on a map. (I'll post more about this in my build thread in the next week or two.)
    KevinK[QUOTED] likes this.
  7. Feb 22, 2019 at 2:38 PM
    #97
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    Not exactly true... They put more square inches to the ground increasing traction.
    Weight of truck remains the same, so it equates to Lower lbs/in2
  8. Feb 22, 2019 at 2:43 PM
    #98
    KevinK
    Tundras to Sedona
    Yeah, I was thinking of running the software on all our tablets. So when we split up to search for campsites at the last second before dark we can find whoever discovers a good one.
    But hide-and-seek in the dark for an hour before dinner is kind of an SGU tradition now. :rofl:
    831Tun and papasmurf like this.
  9. Feb 22, 2019 at 2:49 PM
    #99
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    @DividedSky, well it sounded good, what about when you air them down?
  10. Feb 22, 2019 at 2:50 PM
    #100
    DividedSky
    Jeff
    Same... I bought a new set of wheels/tires for "wheelin" and kept my stock for DD'n
    Takes me about 30min to swap over all 4 wheels when Im headed off for an adventure (Coop STT Pro 295/70/18s). Around town, I get funny looks from the jeeps and dudes on 35's since I have nice suspension, sliders, skids and a bed rack while rockin stock tires, but know what... F'm. I'm not here to impress anyone. I just want a capable rig that will get me where I want to go off-road (and do it fast).
    Tundratoofun, KevinK and ChrisTRDPro like this.
  11. Feb 22, 2019 at 2:51 PM
    #101
    Lars
    Lars
    Cedar Creek Texas
    when you air down Pressure per square inch lowers even further as a direct result of the increased contact patch size.
    Samoan Thor[QUOTED] likes this.
  12. Feb 22, 2019 at 2:57 PM
    #102
    DividedSky
    Jeff
    Are we talking tire PSI or are we talking about the contact patch of the tire w/ the ground? Although, they are kinda the same...
    If you lower your tire PSI, then you get a bigger contact patch. Think about snow shoes. Your body weighs a certain weight. If you are wearing shoes, you sink through. If you wear snowshoes, you float on top bc there is less PSI on the ground. If your 100lb weight is on 10 square inches, then you are delivering 10 PSI. If you increase that to 50 sq in, then 2psi on the ground.
    Road bikes w/ super skinny tires need to run 100psi+ Mountainbikes with wider tires run 25psi Both are supporting my fat ass!!
    Tundratoofun, KevinK and Lars like this.
  13. Feb 22, 2019 at 5:37 PM
    #103
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    I have about 3/4 of an inch to spair on each side with 38’s in the fenders, so it is tight fit . I would think anything larger would require cutting the panels and gone with the liner 4B91DA26-7CF0-495F-AB27-B880A0542F45.jpg
    Rica25, SoCal619, Ted4311 and 2 others like this.
  14. Feb 22, 2019 at 6:19 PM
    #104
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Nice! Yeah I have fiberglass bed sides and fenders and no fender liners... so way more room than stock.. but there are still limits w long travel I already rub on the front and rear on certain flex movements and big hits
  15. Feb 22, 2019 at 6:27 PM
    #105
    KevinK
    Tundras to Sedona
    With a little less offset you can tuck inside the fenders. Here’s our 37x12.5 on 0 offset.
    equin, joeguam[QUOTED] and 15whtrd like this.
  16. Feb 22, 2019 at 6:29 PM
    #106
    KevinK
    Tundras to Sedona
    Pavement Princess only for my wife’s baby. Notice the urban flex setting.
  17. Feb 22, 2019 at 6:34 PM
    #107
    joeguam
    joeguam New Member
    JOE
    I have followed and looked at your group of friends builds. Are you trying to make me spend more money on new wheels;). So I am stuck with the -44 off set for a while. If I was, I would be to go down to 18" wheels.
  18. Feb 22, 2019 at 6:42 PM
    #108
    KevinK
    Tundras to Sedona
    :rofl::bananadance::anonymous::sawzall::mudding:
    15whtrd and papasmurf like this.
  19. Feb 22, 2019 at 6:50 PM
    #109
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I added the lift and tires to keep the short fat girls out. That's why there are no steps too.
    SWIPE likes this.
  20. Feb 22, 2019 at 6:50 PM
    #110
    SWIPE
    SWIPE New Member
    You mean Red Snapper(s).
    Boerseun[QUOTED] likes this.
  21. Feb 22, 2019 at 6:51 PM
    #111
    ussdgates
    ussdgates New Member
    Dave
    2018 TRD Sport
    TRD Pro Exhaust
    I just went with what I thought the vehicle need(aka looked the best).
    Honestly, when I had my Jeep I just wanted to go 37s because I really wanted the clearance. What it came down to was the Jeep just couldn’t handle that big and heavy of a tire with stock composes, i.e. gears, axle shafts, axles, brakes, etc.
    The Tundra is such a better built more capable vehicle that when I put my 35s on I barely noticed the difference. I even think the speedometer is more accurate.F3FBA3F4-E04B-4A81-A164-E6CBEEBB105F.jpg E8882A0D-5E43-4A54-88E0-0C90CA6B9DD2.jpg
  22. Feb 22, 2019 at 6:52 PM
    #112
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    In the spirit of needing more of this...I bid you a good evening gents....
    https://www.youtube.com/watch?v=Hd5trM5DvTQ
  23. Feb 22, 2019 at 7:00 PM
    #113
  24. Feb 22, 2019 at 7:04 PM
    #114
    15whtrd, BlackSheep, Krezz and 2 others like this.
  25. Feb 22, 2019 at 7:11 PM
    #115
    :rofl: those are some NICE 35's!!!!!!!:D
  26. Feb 22, 2019 at 7:26 PM
    #116
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Like this song so much more now.
    I feel dirty, but I think I'm ok with that... :anonymous:
  27. Feb 22, 2019 at 7:54 PM
    #117
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    well. there’s your first mistake...
    @KevinK :eek: :D :thumbsup: :cheers:
    15whtrd, KevinK, Black Wolf and 2 others like this.
  28. Feb 22, 2019 at 7:57 PM
    #118
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    4D2D3725-9F0D-4255-8C8D-EA4303729DFA.jpg 35E6CCA8-D36C-4E9C-8EED-08DFE1223FCF.jpg
    They take me where I want to go
    DZ_, TheBeast, equin and 5 others like this.
  29. Feb 22, 2019 at 8:20 PM
    #119
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    No joke! I just spent the past hour poring through it. @KevinK, you are a doer. I wish I had a tenth of your gumption.
    15whtrd, KevinK and Rica25 like this.
  30. Feb 23, 2019 at 3:29 AM
    #120
    joeguam
    joeguam New Member
    JOE
    I would not say a mistake but learning curve:) . Since I was already in the spending and modification mood the ideas got going. I started with 35's but after a while and standing about 30 ft away it looked small.
    KevinK and Black Wolf like this.
