Why I wouldn't be worried about reliability.
Discussion in '3rd Gen Tundras (2022+)' started by Crimson Flam3s, Sep 21, 2021.
  1. Sep 23, 2021 at 8:42 PM
    shlunky
    shlunky New Member
    So, official price is unknown. ChrisFix posted a YouTube video about changing the battery pack in the Prius. He was able to find a quality refurbished pack that came with a warranty that was, I think, less than half of what the dealer cost was. I believe he got it for around 1200 and the dealer wanted like 2500-3000 for it.
    My numbers may be way off... Let me find the link..
    https://youtu.be/Q3RCdrh666w
  2. Sep 24, 2021 at 12:19 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Average hybrid battery life is way higher than people think. The battery they’re using in the tundra should last 10 years at least. Longer if you don’t let them get overheated. (Blocking the cooling system) there’s highlanders going 15 years with original batteries. When they do go figure 3k for Toyota replacement. Likely less sine the tundras setup appears to be much simiplier than a highlander
    Hell hybrid taxis with no maintenance and 300k miles are plentiful
  3. Sep 24, 2021 at 3:21 AM
    Retired...finally
    Just adding a turbo and removing cubic inches doesn't always equal better fuel efficiency. Two cars nearly identical. The Mazda Miata with the NA 2.0 L engine and the Fiat 124 using a 1.4 multiair turbo. Both cars get very similar real world MPG numbers. The Fiat with the smaller engine may have a slight edge traveling at slower than highway speeds on flat roads with no head winds. How often does that happen?
  4. Sep 24, 2021 at 4:59 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    EDIT: Control unit has been calibrated to current tire size. It also provides a really accurate speedometer function that matches the GPS exactly, unlike the dash speedometer which is off about 7% due to larger rubber.
    ;) This was July 17th. Took the photo because I had just replaced knock sensors (thank you mice and chipmunks). 7.3 mile drive to work. Neutral when I can, cruise control otherwise. Country roads, a few stop signs, lots of rolling hills. The tranny wasn’t even fully warmed up yet (159* vs the usual 180-190).
    Yep. It’s possible if you don’t drive like you stole it. Haha.
    That being said, I can knock that mpg down to 12-13 in a hurry if I choose to do so, but at the cost of saving 1-2 minutes on my drive? Meh.
  5. Sep 24, 2021 at 5:25 AM
    AZBoatHauler
    So.Arizona
    7 miles….
    I can probably get 30+ mpg rolling down 50+ mile stretch of I-17 … that doesn’t mean I get 30 mpg.
  6. Sep 24, 2021 at 5:52 AM
    Bear
    Bear
    Custer, SD
    You do you bud!
  7. Sep 24, 2021 at 7:05 AM
    AZBoatHauler
    So.Arizona
    You too! BTW, coasting in neutral is illegal most places if you care about that kind of thing… Guessing you don’t since you’re hypermiling a lifted Tundra…
    :hattip:
  8. Sep 24, 2021 at 7:14 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    People have been complaining about battery replacement costs for decades now, since the Prius was even first announced. Yet its never been a real issue. My dad got 360k on his Prius and it was a headgasket failure that put the nail in the coffin, battery health was still solid. Even with battery issues, servicing the battery yourself isn't as scary as people think. With EV's becoming the standard you're just gonna need to learn and become comfortable working on those systems.
    TMack77 and Cpl_Punishment like this.
  9. Sep 24, 2021 at 7:23 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It's also illegal to turn your vehicle off at stop lights but now every vehicle manufacturer requires you to do it.
  10. Sep 24, 2021 at 7:27 AM
    AZBoatHauler
    So.Arizona
    Technically the vehicle remains “on” even if the ICE cuts out while stopped.
  11. Sep 24, 2021 at 7:47 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Dammit... he got you on a technicality, which he can do, technically.
    Reload your artillery, adjust fire and fire for effect. One you have him bracketed you can drop shells directly upon him.
  12. Sep 24, 2021 at 7:58 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
