Who has raptor amber light on there tundra..
Discussion in '2.5 Gen Tundras (2014-2021)' started by Young80i, Dec 12, 2017.
  1. Aug 7, 2021 at 10:04 PM
    #121
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Which kit are you using?
  2. Aug 8, 2021 at 4:19 AM
    #122
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    I built a bracket behind the grill to hold the 3/4” leds i order off ebay.
    Ryan
    pvn.beluga likes this.
  3. Aug 12, 2021 at 4:00 PM
    #123
    MRQZTNDR93
    MRQZTNDR93 New Member
    San Diego CA
    2022 TUNDRA SR5 TRD OFF ROAD
  4. Oct 26, 2021 at 4:06 PM
    #124
    chingyeunglo
    chingyeunglo New Member
  5. Oct 26, 2021 at 6:56 PM
    #125
    LATERAL G
    LATERAL G New Member
    2013 RCSB SR5 TRD Off-Road 5.7 4x4
    Recently installed on my Tundra
    I like them
  6. Oct 1, 2022 at 3:17 AM
    #126
    mav7021234
    mav7021234 New Member
    how'd you wire/install the marker lights under the headlights and on the running board? its badass
  7. Oct 1, 2022 at 4:34 AM
    #127
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    i tapped in at the trailer harness. The side lights all blink with the turn signals in addition to running lights.
    mav7021234[QUOTED] likes this.
  8. Oct 1, 2022 at 11:49 AM
    #128
    mav7021234
    Did you drill into the running board to install those lights?
  9. Oct 1, 2022 at 4:27 PM
    #129
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Drilled into the pinch panel that comes down from the body. 3/4” holes.
  10. Oct 2, 2022 at 3:38 AM
    #130
    mav7021234
    did you tap into the headlight for the two led marker lights on the bottom headlight cover panel?
  11. Oct 2, 2022 at 5:42 AM
    #131
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    No. I had already run the wires for the 3 grill lights so i just tapped into them.
    mav7021234 likes this.
  12. Oct 4, 2022 at 6:06 AM
    #132
    mav7021234
    Did you tap into the 7 pin? Or 4 pin for the trailer harness? I’m just confused, on my 7 pin the signal wire says “Right Stop/Turn”
    It’s going to illuminate when I brake and use a turn signal?
  13. Oct 4, 2022 at 5:48 PM
    #133
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Hmmmmm. Im not sure off the top of my head. Maybe i did splice off a turn signal lead at front. Will have to check and let you know. Stand by.
  14. Oct 5, 2022 at 7:20 AM
    #134
    mav7021234
    Were you able to check?
  15. Oct 5, 2022 at 8:48 AM
    #135
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    for my raptor lights I spliced into my turn signal. You should have 3 wires going to it, take a multimeter and figure out which wire comes on when you turn your DRL on, and which gets power when you hit your blinker. Tap into the wire that gets constant power when your DRL is on, not the one that gets power when the blinker is on (you'll know because the blinker power will... blink (on off on off))
    That is for a 2nd gen with the turn signal DRLs
    For the 2.5, if you have the DRL at the bottom of the headlight, you could just tap into whatever power wire is for that, and whenever those white DRLs are on, your raptor lights will also come on
  16. Oct 5, 2022 at 8:52 AM
    #136
    mav7021234
    Thanks for the reply, my question was in regards to his running board lights.
    I fused tapped my grill marker lights into the headlight low beams
  17. Oct 5, 2022 at 8:56 AM
    #137
    joseph_womack
    Joe
    Louisiana
    if your raptor lights only come on with your low beams, you could also tap into your brake lights for putting running board lights in, the "running light" portion of the brake light (not as bright a red as when braking) comes on when your DRLs or headlights are on, you could tap into those just like with the front DRLs and bring the wire to your running boards. Or if you wanted the running boards to blink like a blinker, tap into your rear turn signals on either side
  18. Oct 5, 2022 at 10:00 AM
    #138
    mav7021234
    Thank you, I just need to find a post on where to snake the wires to get them close to the rear lights.
  19. Oct 5, 2022 at 1:52 PM
    #139
    joseph_womack
    Joe
    Louisiana
    when I routed my reverse cam, I snaked it through the frame rail, then once you get to above the rear suspension, you should be able to travel upwards in the bedside to reach the taillight pocket
    ElNopal likes this.
  20. Oct 5, 2022 at 2:55 PM
    #140
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    I did tap into the front turn signal light circuit for the turn signals on them. Sorry about the misspeak. It has been a minute.
  21. Oct 5, 2022 at 3:00 PM
    #141
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    Another option is also creating a T-harness instead of splice into turn signal plug to get the raptor lights switched with your parking lights (2014-17 SR5/PRO/Limited models only) for 2014-17 Platinum/1794 and 2018-21 SR5 models you have to splice into the side maker violet wire to get this same functionality.
    Parts needed
    1x Toyota 90980-11020
    https://www.corsa-technic.com/item.php?item_id=900
    PIN2, SL2 in the selection list
    1x Toyota 90980-11607
    https://www.corsa-technic.com/item.php?item_id=1041
    - The RED wire in the Raptor Lights > Violet wire in turn signal plug
    - Black (ground) wire Raptor lights > White wire in turn signal plug or simply grounded to any metal chassis part.
    That’s how my custom lights are wired so the lights only work with the parking lights.
  22. Oct 5, 2022 at 10:38 PM
    #142
    joseph_womack
    Joe
    Louisiana
    yep, thats exactly how I have mine wired in, minus the custom T harness
  23. Oct 6, 2022 at 5:35 AM
    #143
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    Toyota didn’t do it because it “caught on” lol it’s required by the DOT for vehicles over a certain width. Same reason the TRX has them.
    boomsling and ElNopal like this.
  24. Oct 6, 2022 at 6:33 AM
    #144
    coTony
    Tony
    Montrose, CO
    If it is required then why has none of the other generation vehicles have them? ‍♂️
  25. Oct 6, 2022 at 10:47 PM
    #145
    Redline870
    Ian
    Central NY
    Because it’s wider than 80” and 1.4” wider than other trims
  26. Oct 12, 2022 at 4:47 AM
    #146
    mav7021234
    Thank you. For those marker lights in the pitch panel. Do you have an issue where your turn signal will only blink once if your DRL are not on?
    I installed my OPT7 sidekick lights and I’m not super happy about them. I tapped into the front turn signal signal wire and DRL wire. I have an issue where my DRL needs to be on all the time otherwise my turn signal will only blink once
    Where did you tap into for the side marker lights in the pitch panel to function as both DRL and turn signal? I see you tapped into the front turn signal.
  27. Oct 12, 2022 at 2:33 PM
    #147
    Punisher29073
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    My 3/4” lights have 3 leads. 1) ground, 2) dim running light spliced into tail lights at trailer connector, 3) bright turn signal spliced into turn signals at bottom front of headlights.
    No issues that i am aware of.
  28. Oct 17, 2022 at 2:23 PM
    #148
    SuthrnTundra
    SuthrnTundra New Member
    Kyle
    2020 Cement Tundra Limited 4x4
    TRD Off-Road Grille TRD Off-Road LED Headlights
    What kind of lights are those?
  29. Oct 30, 2022 at 3:25 PM
    #149
    Young80i
    Young80i [OP] New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Where did you get those led lights?
  30. Oct 30, 2022 at 5:55 PM
    #150
    iHacker
    iHacker SW TRD PRO
    Mario
    AR
    The lights are good but the wiring needs a few modifications to make it fully waterproof ohh and fit only for the 2019-2021 TRD PRO grille
    AUXLIGHT Car Accessories, 3PCS LED Center Grille Raptor/Marker Lights For Toyotaa Tundra TRD Pro Grill 2018 2019 2020, Come with Wiring Harness & Add-a-Fuse & Screws (Amber) https://www.amazon.com/dp/B0BBFLXG15
