Where to add a switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by Steve Tundra, Feb 18, 2017.
  1. Sep 17, 2017 at 5:45 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    It's not to big about 3.75 by 2.75 inches. You'll need a longer vga btw the ones that came with it was like 2 feet.
  2. Oct 18, 2018 at 9:49 PM
    Pit_goral
    Pit_goral New Member
    Piotr
    Greeley, Colorado
    17 Tundra Limited TRD OFF ROAD
    ArmyGreen21, NWHmoob, Silv333 and 2 others like this.
  3. Oct 19, 2018 at 3:57 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    I know it’s an old thread but since someone else bumped it, I’ll butt in.
    How has the trigger switch been working for you?
  4. Oct 19, 2018 at 10:01 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Where did you get the liners for your cup holders?
  5. Oct 19, 2018 at 10:14 PM
    Pit_goral
    Piotr
    Greeley, Colorado
    Tufskinz.com
    Silv333 likes this.
  6. Oct 19, 2018 at 10:38 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Hmmmm
    Berdine likes this.
  7. Oct 20, 2018 at 10:37 AM
    n2deep
    n2deep Pavement Princess
    Works well the new version has 6 spots and indicator lights on the saitches I believe. I have an Android head unit and run from the app most of the time anyway.
  8. Feb 11, 2019 at 9:53 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    What is that switch panel?
  9. Feb 11, 2019 at 9:58 AM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    I mounted my switch pro here:
    41C2B0AE-08E0-4902-B8E3-F4E4AA3B8875_zps_841b9dccc2a8e3cc81fa907829e11c81729b1f86.jpg
    NewImprovedRon likes this.
  10. Feb 11, 2019 at 10:18 AM
    Pit_goral
    Piotr
    Greeley, Colorado
  11. Feb 11, 2019 at 12:28 PM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Thank you! Any tips on cutting out the hole for it to fit, other than being real, real careful?
  12. Feb 11, 2019 at 1:34 PM
    Pit_goral
    Piotr
    Greeley, Colorado
    No tips. Check everything twice. You may need to trim that panel too. I was using different parts to make my switch panel and i had more work.Screenshot_20190211-162923_Chrome.jpg
  13. Feb 11, 2019 at 7:49 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    NICE! This is what I need. From the looks of it, it's flush right? Where did you purchase the actual switch?
  14. Feb 11, 2019 at 8:23 PM
    Pit_goral
    Piotr
    Greeley, Colorado
  15. Feb 11, 2019 at 8:42 PM
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
  16. Feb 12, 2019 at 6:20 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    UPDATE- 3/4/19- I CAN CONFIRM THAT DIAGRAM 1 WORKS FOR 2019 TUNDRAS. I wired the red trigger wire into the under-hood fuse box using a Add-A-Circuit with 3 amp fuse in the HI Headlight fuse spot.
    I just ordered the switch plate housing off Amazon for $20. It's available other places for $12+ shipping. https://www.amazon.com/gp/product/B01GV8APBS/ref=ppx_yo_dt_b_asin_title_o01__o00_s02?ie=UTF8&psc=1
    Pit_goral- a quick question- on the AOB switch install, did you have to use a diode to get the switch to illuminate with dash lights? I'm trying to figure out if I need a diode and if the 2019 Tundra headlights are positive or negative switched. [​IMG]
  17. Feb 12, 2019 at 7:34 AM
    Pit_goral
    Piotr
    Greeley, Colorado
    ecm209 likes this.
  18. Feb 13, 2019 at 7:10 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    One more question, would you have had enough room vertically to get the AOB switches wired up and installed in the middle and passenger side holes? I removed the console cover and it looks pretty tight right above the AC duct going to the back seat. Hell, I guess it doesn't matter, I am going to give this a whirl either way.
  19. Feb 13, 2019 at 7:20 AM
    #49
    Pit_goral
    Piotr
    Greeley, Colorado
  20. Feb 13, 2019 at 7:34 AM
    #50
    Pit_goral
    Piotr
    Greeley, Colorado
    I had this switch mounded in passenger side before I move it to my side with no problems.
  21. Feb 13, 2019 at 7:36 AM
    #51
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Awesome, thank you. That Toyota OEM switch plate should be exactly what I have been looking for, assuming I can keep the dremel steady enough. Now I just have to figure out the wiring diagram on the AOB switches. So much conflicting information on the interwebs about it.
  22. Feb 15, 2019 at 11:51 AM
    #52
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    I've goten the pieces and cut the initial hole for the switch plate. The more I do on this, the more I realize just how great yours looks. The rounded corners are a PITA.
  23. Feb 15, 2019 at 12:24 PM
    #53
    Pit_goral
    Piotr
    Greeley, Colorado
    I used 2000 grid wet sandpaper
  24. Feb 15, 2019 at 12:34 PM
    #54
    Cthulhu
    I like the hidden ledge mount...
    Rica25 likes this.
  25. Feb 15, 2019 at 12:38 PM
    #55
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Man, you're not kidding. I decided that the spare opening where you have the Toyota Security insert was too hard for me to see. I had to look at your pic more than once to notice the ones that were actually hidden.
    Here's the plan and the first cut:
    Update- finished product: [​IMG]
  26. Feb 15, 2019 at 1:03 PM
    #56
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    This is exactly what I want to do...
  27. Feb 15, 2019 at 1:07 PM
    #57
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    The Toyota part with the three switch openings is right at 2"x4". Worst case if I screw up this attempt, AOB sells a 4 gang switch panel that is 4.4" x 2" and screws down rather than snaps in, so as long as I don't screw up the 2" part of the hole, I can use it and have an excuse to wire something else up to the extra switch. https://www.tundras.com/threads/where-to-add-a-switch.10751/page-2#post-1022164
    Pit_goral likes this.
  28. Feb 15, 2019 at 1:15 PM
    #58
    Pit_goral
    Piotr
    Greeley, Colorado
  29. Feb 15, 2019 at 1:16 PM
    #59
    Pit_goral
    Piotr
    Greeley, Colorado
    Or you can use a glue to mount this panel
  30. Feb 15, 2019 at 1:18 PM
    #60
    offshore2005
    offshore2005 New Member
    TEXAS
    2022 Tundra Limited 4x4 RC leveling kit and 295/65/20 Cooper STT PROs
    69E1AE73-27AD-45E0-BDEC-92895FBB4920.jpg This is where my light bar switches are.
