Where to add a switch
Discussion in '3rd Gen Tundras (2014+)' started by Steve Tundra, Feb 18, 2017.
  1. Feb 18, 2017 at 12:23 PM
    Steve Tundra
    Steve Tundra [OP] New Member
    Steven
    2014 Toyota Tundra platinum
    I have a 2014 platinum 4x4 Tundra. I don't have any blank switch spots. I want to add a switch for a winch and lights. Any ideas where i can add 2 more switches? They cant be added to the bottom right of the steering column cause I'm putting my break controller there with the custom cover. What other options do I have. Center console?
  2. Feb 18, 2017 at 12:37 PM
    joonbug
    joonbug bacon bastrd
    Joon
    NorCal - Dublin
    2015 DC 5.7 TRD off-road
    I think it was @Spvrtan who put switches in the sunglass holder. Looked good
    831Tun, dcsleeper408 and Spvrtan like this.
  3. Feb 18, 2017 at 12:49 PM
    Cat3ILS
    Cat3ILS The cheese goes on the bottom bun
    2014 platinum CrewMax 4x4 5.7L - white
    2.5 level, 285 Toyo OC, Or-Fab trans/cat skid, X2 Revolver, ESP storage, Husky's, Lock'er Down safe, OCD organizer, Interior LED's (red drivers), Glove and safe motion LED's, Rhino lined
    In the portion of the dash that holds the two power ports and USB/AUX (below the climate controls). Seen a few mounted facing down in the upper edge of that section. Easy to access for installation. Also in the upper sunglass holder like Joon said.
    joonbug likes this.
  4. Feb 18, 2017 at 1:57 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    2015 Inferno Ex-Pro
    Your mom
    I added one here
  5. Feb 18, 2017 at 4:32 PM
    NewImprovedRon
    NewImprovedRon SouthBoundSteve Fan Club President
    Ron
    Bentonville, AR
    2015 Radiant Red TSS Doublecab 4X4 Off Road
    Deck rail system, Bed divider, door sill protectors, LED reverse light bars, Aries Bull Bar with 28" 180 watt LED light bar, LED step lights, LED bed lights, driver-side grab handle, TRD Rear Sway Bar, BedRug bed mat and tailgate mat, Morimoto Fog Lights, more to come.....
    I like the console mount.
    Law323 likes this.
  6. Feb 18, 2017 at 6:58 PM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    Super white '16 CM LTD 4x4
    I added two here with the ability to put in another for my reverse lights, when I get them.
  7. Feb 18, 2017 at 11:10 PM
    Spvrtan
    Spvrtan Mod In Training | MIT
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 4.88s
    I have the sPOD kit with mount for the '14+ Tundras..
    Switch-Pros makes a universal kit that takes up less space but I like the tactile feel of actual switches so I went with the sPOD because of its rockers. I'm probably going to eventually get another sPOD kit and mount the switch panel onto my dashboard top here..
  8. Feb 20, 2017 at 4:15 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    4x4_Angel likes this.
  9. Feb 20, 2017 at 4:22 PM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    I would suggest looking into the Switch Pros, and now that I see it Bluebottle meantioned it above.
    The Switch Pros is nice because you don't have to run any relays, in line fuses, or have to buy any additional light harnesses. The unit is all solid state w/ 7 switches rated for 18 amps and 1 for 30 amps. If you need to run higher amperage off a smaller switch, you can micro relay it. It can be connected via Bluetooth to your phone and everything can be controlled from your phone. The only thing it pretty much can't handle is a winch. You can program stuff to be on/off, momentary, strobe, power only through ignition, power all the time, and you can do master switches such as hit 1 switch and turn 4 things on at once. They are really compact and save you money down the line.
    www.switchpros.com for more information that I haven't posted here. We run them in a lot of trucks here, so if you have any questions you can call the shop as well.
    4x4_Angel, 1UPPER, ep3Jee and 5 others like this.
  10. Feb 21, 2017 at 10:51 PM
    Steve Tundra
    Steven
    Thanks for all the great ideas. Now I just gotta figure out how many switches I'm gonna need.
    Lights, spots, leds, smokescreen,
    muffler to straights to scare to granny
    socal147 likes this.
  11. Feb 24, 2017 at 9:16 AM
    BOBONTUESDAY
    BOBONTUESDAY New Member
    2016 Limited Trd
  12. Feb 24, 2017 at 1:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  13. Jun 29, 2017 at 10:57 AM
    Sprinterboy
    Sprinterboy G'Day
    Alexandria, VA
    2015 Black 1794 Edition
    LED Bulbs, BakFlip Cover, X-Line Bedliner, Bed Rail Axe Mount, The list grows...
    G'day mate,
    Did you have any troubles removing the centre consol to wire everything up?
    Where did you get the switch mounting plates/holes from?
  14. Jun 29, 2017 at 11:17 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    For now, I ordered the factory panel thats used with the OEM brake controller. Then I made a nice little panel from aluminum.
    4x4_Angel and Coolhardy like this.
  15. Jun 29, 2017 at 11:23 AM
    CaptObvious
    CaptObvious New Member
    Patrick
    2015 Black Tundra SR5 Crewmax TRD
    I hooked up a wireless controller for lights, from speedtech lights. Not too bad 6 button remote that is a little bigger than the key fob.
  16. Jun 29, 2017 at 11:45 AM
    Sprinterboy
    Sprinterboy G'Day
    Alexandria, VA
  17. Jun 29, 2017 at 11:57 AM
    Spvrtan
    Kris
    San Diego, CA
    I see that SDHQ is now offering a fitment that places the Switch-Pros kit in the coin holder next to the shift knob. That's a good option.
  18. Jun 29, 2017 at 12:09 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    The bezel PN is 55447-0C020-C0 and runs about $25
    Sprinterboy likes this.
  19. Jun 29, 2017 at 12:13 PM
    n2deep
    n2deep Overlander - Speed Glamper
    Mojave Desert
    2010 Tundra DC
    Camburg Long Travel -Front King/King Secondary Triple Bypass - McNeil Fiberglass Rear -ADS Triple Bypass Deaver K37 Method Mesh 35x12.5x18 Cooper SST Maxx
    I am using the Trigger switch. Wireless and can be put anywhere.
    2 - 30amp and 2 - 15 amp circuits
    http://www.rogue-offroad.com/product-p/2001.htm
    Also has an app to control from phone. Little less expensive than the spod or switch pro
  20. Jun 29, 2017 at 12:16 PM
    Spvrtan
    Kris
    San Diego, CA
    @n2deep, how's the charge and range on that thing?
  21. Jun 29, 2017 at 12:19 PM
    n2deep
    Mojave Desert
    2010 Tundra DC
    Charge ???? The wireless switches run on batteries - and the range is bluetooth range. I would guess the batteries last a year or so but super easy to install being wireless.
  22. Jun 29, 2017 at 12:21 PM
    Spvrtan
    Kris
    San Diego, CA
    That's what I meant, haha. Is the wiring unit itself analog (ie. like the older sPOD kits, individual fuses/relays) or digital (Switch-Pros)?
  23. Jun 29, 2017 at 12:46 PM
    Sprinterboy
    Sprinterboy G'Day
    Alexandria, VA
  24. Sep 14, 2017 at 4:29 PM
    Berdine
    Berdine New Member
    Binghamton, NY
    2016 MGM Crewmax TRD
    How do you like this? I've looked at it, just wish you can get better stickers for the touch panels
  25. Sep 14, 2017 at 7:08 PM
    BOBONTUESDAY
    2016 Limited Trd
    It's been awesome. It looks almost stock and no one notices it till I point it out. The location is perfect for turning lights on and off fast while driving. I don't run stickers, I just know which number does what from memory.
    Berdine likes this.
  26. Sep 16, 2017 at 7:36 PM
    Berdine
    Berdine New Member
    Binghamton, NY
    Did you have to drill a hole for the harness to plug into the back of it?
  27. Sep 17, 2017 at 9:11 AM
    BOBONTUESDAY
    2016 Limited Trd
    Yes I did, it uses a vga plug so it was a good size hole.
    Berdine likes this.
  28. Sep 17, 2017 at 2:45 PM
    poheller
    poheller Blue Tundra, Project Thor!
    Scot
    The great state Ohio
    2017 TUNDRA SR5
    AFE. COI and Throttle Body Spacer. Blue dash board components, Blue Halo Bulge and emblem. Iboards running boards. VLED’s switch backs and headlights. Back flip cover. Etc, etc.
    Done mine today, light up blue.
    ecm209, 4x4_Angel and Berdine like this.
  29. Sep 17, 2017 at 3:48 PM
    Berdine
    Berdine New Member
    Binghamton, NY
    That's what I was curious about, looks huge in the pictures of it.
  30. Sep 17, 2017 at 3:48 PM
    Berdine
    Berdine New Member
    Binghamton, NY
    That blue dash looks awesome!
