when do you use tow/haul mode
Discussion in 'General Tundra Discussion' started by Tomcat, May 23, 2017.
  1. May 23, 2017 at 7:58 AM
    Tomcat
    Tomcat [OP] Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    20170507_103914.jpg I recently completed a trip to Panama City with my motorcycle. The motorcycle weighs 625 lbs. The carrier with upgrades weighs 125 lbs. There was approximate 400 lbs. in the bed and 800 lbs. IN THE DOUBLE CAB. I used tow/haul all the way there and back. You can see the truck squatting in the back. I had no issues and the extra slowing from the transmission really helped. How much weight should you have before engaging tow/haul mode?
  2. May 23, 2017 at 8:03 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I use Tow/Haul anytime I wanna have fun or am towing. I wouldn't recommend loading down your truck that much, there is a Payload weight limit on DC's. Check the inside of your drivers door frame, it should tell you there as well as the owner's manual...
  3. May 23, 2017 at 8:05 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Good question. I towed my MX bike with my aluminum 2 place ATV trailer and was wondering if that was heavy enough to justify tow/haul.
    I use it with my boat, but that's obviously heavier.
  4. May 23, 2017 at 8:10 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I use it for passing sometimes and merging on to the freeway where the ramp is short. I tow fairly frequently too. But if it's flat and I'm just cruising down the freeway while towing, I turn it off. I definitely use it on hills while towing, usually I have a total of roughly 4,500 lbs.
    Darth Tundra likes this.
  5. May 23, 2017 at 8:28 AM
    Tomcat
    Bakflip
    [Qwould
    ="TruckinIt, post: 251564, member: 5188"]I use Tow/Haul anytime I wanna have fun or am towing. I wouldn't recommend loading down your truck that much, there is a Payload weight limit on DC's. Check the inside of your drivers door frame, it should tell you there as well as the owner's manual...[/QUOTE]
    I wouldn't try it with any other truck. It was mostly highway driving. I didn't want to pull a trailer so that is why I bought and reinforced a carrier. I did load it up a do a test drive as I was a little concerned.
  6. May 23, 2017 at 8:31 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When an F150 pulls up next to me at a light.
    Krezz, Noodle, AxelsHumanDad and 9 others like this.
  7. May 23, 2017 at 8:34 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Or a shitty Dodge Ram.
  8. May 23, 2017 at 9:56 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I don't know the weight but í wouldn't tow more than 2500lbs in six gear..I have played with the tow mode and it seems to turn off six gear, change the shift points on the trainny..it does make the truck more exciting to drive..so I'm assuming it triggers the vvt at very low rpm..my odessey had vtech when it kicked on it was on..
    Tomcat[OP] likes this.
  9. May 23, 2017 at 11:17 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I've only used it when climbing mountains passes on I70. I don't tow anything.
    NewImprovedRon likes this.
  10. May 23, 2017 at 11:25 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    It's never necessary to use it. The truck will haul and tow just fine without it. It can be used whenever you want. I think the recommendation is anything over 4,000 lbs. If you feel like your truck is bogging down when you are towing turn it on, it won't hurt anything, if you don't want to use it again it won't hurt anything.
    Wynnded likes this.
  11. May 23, 2017 at 1:50 PM
    McReef
    McReef '17 Tundra TRD Pro Crewmax
    Eastern MA
    A better question for me would be when do I not use it.
    Answer: When she is parked.
    PR_02 and TXMiamiFan like this.
  12. May 23, 2017 at 2:00 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    2016 CrewMax Platinum
    I agree, rule of thumb... anytime the truck is on, tow/haul is useful.
    ...unless you like to save your gas.
  13. May 23, 2017 at 2:02 PM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    All the time! Have I overloaded its payload capacity at some point? God I hope so.
    IMO, If I cannot load at least 1500 pounds in my truck, I do not want it... Unless it is a show truck/race truck (oxymoron).
    NJ-Mark and PR_02 like this.
  14. May 23, 2017 at 2:24 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
