When do you apply the ebrake when parking up or downhill?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Jul 20, 2024.
  1. Jul 28, 2024 at 7:45 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Yes
    ejes likes this.
  2. Jul 30, 2024 at 4:14 AM
    CMikeB
    CMikeB New Member
    There's only one correct way that makes any difference at all and THIS is it.:thumbsup: If you're actually using your Park Brake, you're as rare as those who read the Owner's Manual!
  3. Aug 1, 2024 at 8:23 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    It’s become a habit for me to always hold the brake, apply parking brake, then release brake pedal.
    Same as when before I put my truck into drive - hold down on brake, release parking brake, then shift into drive.
    CMikeB likes this.
  4. Aug 1, 2024 at 8:33 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I apply the ebrake before putting in park. Every time I stop, parking brake gets applied. In NH you use it or lose it. If it doesn’t get exercised it rusts up. Now it’s truly a waste of time because since day 1 the parking brake has sucked and wouldn’t hold the vehicle in place on level ground if relied on.
  5. Aug 1, 2024 at 8:39 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Have you tried adjusting it?
  6. Aug 2, 2024 at 6:20 AM
    ScenicRoute
    Yep. Just doesn’t have any holding power.
  7. Aug 2, 2024 at 6:32 AM
    Retired...finally
    That sucks. My 21 came from the dealer with too much slack in the cables. On day one I took up some slack to get it to hold and shortly afterwards did the correct procedure starting from the rear wheels and found the shoes were set correctly. All mine needed was the slack adjusted under the cab. It will hold fine on my 20-25% grade driveway.
